几乎是按照官方例子配出来的程序. 我是想设置4个字节到缓冲区后产生接收传输完成中断. 然后一次处理4个字节,但是PC只要向STM32发送1个字节,DMA_FLAG_TCIF1马上就置位了, 缓冲区里面也没有数据,但是看USART-DR里是收到那个字符的.
下面是初始化代码,为了简化我没有中断,配置好串口后一直查询 DMA_FLAG_TCIF1 标志位. // 初始化函数,外面会传一个BUF首地址和长度进来作为DMA接收缓冲区 void HAL_UARTDevInit (const UINT8 *p_rec_buf, UINT32 num) { UINT8 err; DMA_InitTypeDef dma_init_structure; GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE); /* Connect PXx to USARTx_Tx*/ GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_USART3); /* Connect PXx to USARTx_Rx*/ GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_USART3); /* Configure USART Tx as alternate function */ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_Init(GPIOB, &GPIO_InitStructure); /* Configure USART Rx as alternate function */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; GPIO_Init(GPIOB, &GPIO_InitStructure); /* USART configuration */ USART_InitStructure.USART_BaudRate = 115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART3, &USART_InitStructure); // USART_ClearFlag(USART3, USART_FLAG_TC | USART_FLAG_RXNE); /* 清除已有的标志位, 防止使能后直接进入该中断 */ USART_Cmd(USART3, ENABLE); /* 当配置DMA时初始化DMA接收通道 */ DMA_DeInit(DMA1_Stream1); dma_init_structure.DMA_Channel = DMA_Channel_4; dma_init_structure.DMA_PeripheralBaseAddr = (uint32_t)(USART3 + 0x04); dma_init_structure.DMA_Memory0BaseAddr = (uint32_t)p_rec_buf; dma_init_structure.DMA_DIR = DMA_DIR_PeripheralToMemory; dma_init_structure.DMA_BufferSize = num; dma_init_structure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; dma_init_structure.DMA_MemoryInc = DMA_MemoryInc_Enable; dma_init_structure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; dma_init_structure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; dma_init_structure.DMA_Mode = DMA_Mode_Normal; dma_init_structure.DMA_Priority = DMA_Priority_VeryHigh; dma_init_structure.DMA_FIFOMode = DMA_FIFOMode_Disable; dma_init_structure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full; dma_init_structure.DMA_MemoryBurst = DMA_MemoryBurst_Single; dma_init_structure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; DMA_Init(DMA1_Stream1, &dma_init_structure); USART_DMACmd(USART3, USART_DMAReq_Rx, ENABLE); DMA_Cmd(DMA1_Stream1, ENABLE); } //测试代码 unsigned char buffer[4]; HAL_UARTDevInit(buffer, 4); while (DMA_GetFlagStatus(DMA1_Stream1, DMA_FLAG_TCIF1) == RESET) { ; } while(1); // 设个断点程序达到此处后停下来观察内存. 只要串口接受到1个字节就会到这里, buffer里全是0, 而USART3->DR里有我发过来的数据. 详细对比了几遍和例程 USART_TwoBoardsDataExchangeDMA. 几乎没有不同. 我禁止掉了FIFO模式, 如果启用FIFO也是一样 请高人帮忙! |
5个回答
你可以这用判断发送完成标志, 只判断DMA的发送长度是否为0就可以了。我在F10x,F4xx都是这样做的,性能很可靠。
将USART_Cmd(USART3, ENABLE);放在DMA_Cmd(DMA1_Stream1, ENABLE);后面试试
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
242 浏览 1 评论
664 浏览 0 评论
MCU友好过渡MPU,米尔基于STM32MP135开发板裸机开发应用笔记
600 浏览 0 评论
自定义系统时钟频率后,用库函数和微带两种方式点亮LED灯,为什么灯的闪烁频率不一致?
1389 浏览 2 评论
1612 浏览 2 评论
GMT+8, 2024-4-18 20:45 , Processed in 0.441409 second(s), Total 45, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
