在为任何项目选择目标FPGA时需要考虑哪些事项。
我们计划从其他供应商那里购买几个IP内核,每个内核都为不同的设备系列提供资源利用率。 有了这些数据,我是否只需要在更安全的一侧添加LUT,FF等一些额外的数字来选择新设备? FPGA怪胎 以上来自于谷歌翻译 以下为原文 What are the things to be considered while selecting the target FPGA for any project. We planned to buy couple of IP cores from other vendors and each provides the resource utilization for different family of devices. With those data, should I have to just add the LUTs, FFs, etc with some additional numbers at safer side to select the new device? FPGA freak |
5个回答
嗨Sridar,
FPGA的基本构建块实际上是SLICE。 实际上,它们是由几个LUT和FF组成的,但我建议查看所有核心使用多少个切片然后将它们加在一起。 你可以添加一个保证金,但实际上,这些工具将能够以一点点性能为代价来共享SLICE ...... 最好的祝福, 德赖斯 -------------------------------------------------- -------------------------------------------------- ----------------如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子并通过点击星标回复导向 在帖子旁边。 以上来自于谷歌翻译 以下为原文 Hi Sridar, the basic building blocks of FPGAs are actually SLICEs. So indeed, they are made out of several LUTs and FFs, but I would recommend to look how many slices all the cores use and then add those together. You could add a margin, but in reality, the tools will be able to share SLICEs at the cost of a little bit of performance... Best regards, Dries -------------------------------------------------------------------------------------------------------------------- Please mark the Answer as "Accept as solution" if the information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post. |
这里有一些关于切片与LUT的更多信息,您可能会发现它们很有用
http://forums.xilinx.com/t5/Spartan-Family-FPGAs/how-to-find-no-of-slices-utilized-from-the-no-of-slice-registers/m-p/74159 BT 以上来自于谷歌翻译 以下为原文 Here's some more information on slices vs LUTs that you may find useful http://forums.xilinx.com/t5/Spartan-Family-FPGAs/how-to-find-no-of-slices-utilized-from-the-no-of-slice-registers/m-p/74159 bt
但是,spartan-3系列每片有2个LUT,而spartan-6每片有4个LUT和6位架构。 所以,它不具有直接可比性,对吧? FPGA怪胎 以上来自于谷歌翻译 以下为原文 >> the basic building blocks of FPGAs are actually SLICEs. But, spartan-3 family has 2 LUT per slice and spartan-6 has 4 LUT per slice and of 6-bit architecture. So, it is not directly comparable, right? FPGA freak |
Sridar,
正确。 “等效逻辑单元”试图使其正常化,但也会导致一些潜在的混淆。 http://forums.xilinx.com/t5/Spartan-Family-FPGAs/How-does-Xilinx-come-up-with-number-of-Logic-Cells-for-Spartan-6/td-p/72461 尽管如此,理解底层架构肯定有帮助。 BT 以上来自于谷歌翻译 以下为原文 Sridar, Correct. "Equivalent logic cells" is attempt to normalize this but also results in some potential confusion. http://forums.xilinx.com/t5/Spartan-Family-FPGAs/How-does-Xilinx-come-up-with-number-of-Logic-Cells-for-Spartan-6/td-p/72461 It definitely helps to understand the underlying architecture though. bt |
sridar写道:
>> FPGA的基本构建块实际上是SLICE。 但是,spartan-3系列每片有2个LUT,而spartan-6每片有4个LUT和6位架构。 所以,它不具有直接可比性,对吧? 正确。 但是,如果您知道要使用的架构中的IP切片数量(Spartan-3 / Spartan-6),您将获得完整设计的准确估计值。 最好的祝福, 德赖斯 -------------------------------------------------- -------------------------------------------------- ----------------如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子并通过点击星标回复导向 在帖子旁边。 以上来自于谷歌翻译 以下为原文 sridar wrote: Correct. However, if you know the amount of slices for your IP in the architecture you're going to use (Spartan-3/Spartan-6), you will get accurate estimates for your complete design. Best regards, Dries -------------------------------------------------------------------------------------------------------------------- Please mark the Answer as "Accept as solution" if the information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post. |
只有小组成员才能发言,加入小组>>
2163 浏览 7 评论
2605 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2079 浏览 9 评论
3149 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2193 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
424浏览 1评论
1524浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2177浏览 0评论
509浏览 0评论
1641浏览 0评论
GMT+8, 2024-4-25 04:03 , Processed in 0.962165 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
