我正在为CY8CKE-EVE模块(CY8CKIT-143A)设计一个承载卡,我想确保在两个安装连接器之间有正确的尺寸。有人有EACT维度吗?如果我测量引脚1到引脚1,它看起来是21mm。好像是一个奇数,所以我想查一下。谢谢!
以上来自于百度翻译 以下为原文 I'm designing a carrier card for the CY8CKIT eval module (CY8CKIT-143A specifically) and I want to make sure I have the correct dimension between the two mounting connectors. Does anyone have the eact dimension? It appears to be 21mm if I measure pin 1 to pin 1. Seems like an odd number, so I wanted to check. Thanks! |
6个回答
最接近的I可以用千分尺测量,放大镜有点大于-21.33毫米或0.84英寸。你说得对,很奇怪!我期待它是一个圆形的数字英寸,或在2.54毫米的网格本身的连接器。连接器壳之间的间隙约为15.5mm=0.61,但这对于铺设PCB并不是特别有用。
以上来自于百度翻译 以下为原文 Nearest I can measure with a micrometer and magnifying lens is a bit more - 21.33mm or 0.84". You are right - it is very odd! I was expecting it to be a round number in inches, or on the 2.54mm grid of the connectors themselves. The gap between the connector shells is about 15.5mm = 0.61", but that is not particularly useful for laying out a PCB. |
对,我看到了零件号,但是我需要从一个零件到另一个零件的间隔。
以上来自于百度翻译 以下为原文 Right, I saw the part numbers, but I need the spacing from one part to the other. |
Lancy雪蜜紫 发表于 2019-1-22 08:50 我只看了一遍,发现21.33毫米不等于0.84。你是说“0.54”吗? 以上来自于百度翻译 以下为原文 I just looked at this again and noticed that 21.33mm does not equal 0.84". Did you mean 0.54"? |
你好,
从模块提供的钻孔文件中,头部之间有740毫弧度18.796mm。 X92000 Y121000 X102000 X18000 0Y121000 X8000 920MIL-180MIL=740MIL(内引脚) 如果你的测量方法从左到左,它当然是840MIL或21.336mm。 亲切的问候, 阿希姆 以上来自于百度翻译 以下为原文 Hi, from the drill files provided with the Module it is 740mil or 18.796mm between the headers. X92000Y121000 X102000 X18000Y121000 X8000 920mil - 180mil = 740mil (inner pins) If your measure from left to left side it is of course 840mil or 21.336mm. kind regards, Achim |
我站在我的源头!21.33毫米=0.83976378。 这当然是每个连接器上类似的销中心之间的距离,所以J1的左边列的引脚与J2的左列中的引脚(或每种情况下的右列)之间的距离。 以上来自于百度翻译 以下为原文 I stand by my sources! 21.33mm = 0.83976378". This of course is the distance between similar pin-centres on each connector, so the pins in the left column of J1 to those in the left column of J2 (or the right column in each case). |
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-20 14:26 , Processed in 0.708386 second(s), Total 71, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
