嗨,我想从BT-BASIC控制继电器板,电路板插入USB,它有一个驱动程序(现在可以看到端口像Com端口,它是一个VCP)板的设置是
:9600波特,8个数据位,无奇偶校验,一个停止位。 BT-BASIC是否支持VCP? 以上来自于谷歌翻译 以下为原文 Hi, I want to control a relay board from the BT-BASIC, the board is plug in the USB, and it has a driver( a can now see the port like a Com port, its a VCP) The setup for the board is: 9600 baud, 8 databits, no parity, one stop bit. Does BT-BASIC support VCP? |
2个回答
有一点需要考虑,如果这是您正在使用的PC控制器:com端口号有一个限制。
你不能在COM12上使用comport。 我被告知在最新版本的软件中已经纠正了这个问题,但不是我能说的。 以上来自于谷歌翻译 以下为原文 One thing to consider, if this is a PC controller you are using: there is a limit to the com port numbers. You can not employ a comport over COM12. I have been told that this has been corrected in the latest version of software, but not that I can tell. |
如果你有5系列或ASRU N卡,你有额外的功能来控制夹具通信,有USB信号路由与Cover Extend一起使用,所以虽然这些不是'官方'USB - 它可以用于与继电器板通信
还有一个专用的夹具电源,可以从测试计划打开和关闭,虽然这不是直接解决你的VPC查询,然后它是VPC的另一个选项,我的建议是做一个小的bt基本例程并尝试它 在您的笔记本电脑上 - 测试开发软件相对便宜,您可以尝试这些体验,而不会占用您的测试头,谢谢 以上来自于谷歌翻译 以下为原文 If you have series 5, or ASRU N card, you have additional cabilities to control in fixture communications there is USB signals routed for use with Cover Extend, so whilst these are not 'official' USB - it will work for communicating with a relay board there is also a dedicated fixture power supply, that can be turned on and off from testplan, whilst this is not directly addressing your VPC query, then its another option for VPC, my recommendation would be to make a small bt basic routine and try it on your laptop - test development software is relatively inexpensive and you can try these experiements without tying up your testhead, thanks |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 00:44 , Processed in 1.070626 second(s), Total 73, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
