大家好,我使用MPLAB X 4,但问题也发生在这个版本之前。我设置了两个配置。一个是模拟器的SIM,另一个是程序员的ICD3。有时我将配置切换到SIM并点击编译和构建图标(锤子/扫帚),什么也没有发生。我试着运行模拟,什么也没发生。我看到一个感叹号在右下角,这就是它显示的细节(请参阅下面的PLS)。我通常必须重新启动MPLAB X才能再次工作。BTW我用XC8 1.43,但我也看到了问题XC16V1.31.有人知道如何解决这个问题吗?感谢---------------------------------------------------------------java. Lang.NullPoPosivExistin AT com。Microchip。MPLAB。NBID.NET.MaCudio.UI。定制器。.MPLCab.NbID.MaCeCuStudioServices .CuffCueSudioWorkWorks.(MakECuStudioServices提供程序.java:298)在COM.Microchip .MPLAB .nbID.Entv.MaCudio.API .MaKeCuStudioServices .COM.MicroChIP.MPLAB.NBIDE.EndoDeD.MakeCouStui Access 100美元(MakECuSuthIsRealPosiv.java:107).ZeServices $ 2。在Org .OpenID.UpL.ReestEdvest.BaseRun.Run(MakECuStudioServices提供程序.java:203).org .OpenID.UTI.RealEdvestPortual$Port.Run(RealEdvestPurtual.java:2033)中运行(Rebug Studio.java:1423)[ catch ]
以上来自于百度翻译 以下为原文 Hi all, I'm using mplab x 4.0 but the problem happened before this version as well. I have two configurations set up. One is named SIM for the simulator and the other ICD3 for the programmer. Some times I switch the configuration to SIM and click the compile and build icon (hammer/broom) and nothing happens. I try to run the simulation and nothing happens. I see an exclamation symbol on the bottom right and this is what it shows for the details (see below pls). I usually have to restart mplab x to work again. BTW I'm using it with XC8 1.43 but I've also seen the problem with XC16 v1.31. Does anyone know how to fix this? Thanks ----------------------------------------------- Exception details below this line ------------------------------------------------- java.lang.NullPointerException at com.microchip.mplab.nbide.embedded.makeproject.ui.customizer.MakeCustomizer. at com.microchip.mplab.nbide.embedded.makeproject.api.MakeCustomizerProvider.showCustomizerWorker(MakeCustomizerProvider.java:298) at com.microchip.mplab.nbide.embedded.makeproject.api.MakeCustomizerProvider.access$100(MakeCustomizerProvider.java:107) at com.microchip.mplab.nbide.embedded.makeproject.api.MakeCustomizerProvider$2.run(MakeCustomizerProvider.java:203) at org.openide.util.RequestProcessor$Task.run(RequestProcessor.java:1423) [catch] at org.openide.util.RequestProcessor$Processor.run(RequestProcessor.java:2033) |
1个回答
我不知道问题是什么。但是我可以说这个例外与实际的模拟器无关。它似乎与构建子系统有关。为了解决这个问题,这个问题可能会从MPLAB X IDE论坛而不是模拟器论坛得到更好的响应。另外,每个人都希望看到你的配置的所有细节。你能把你的项目打包并附上吗?这样我们就能看到我们自己的进展了。
以上来自于百度翻译 以下为原文 I don't know what the problem is. But I can say that this exception has nothing to do with the actual simulator. It appears to have something to do with the build sub-system. To wit, this question might get better response from the MPLAB X IDE forum rather than this simulator forum. Also, everyone is going to want to see all the details of your configuration. Can you possibly package your project and attach it so we can see what is going on for ourselves? |
只有小组成员才能发言,加入小组>>
4814 浏览 9 评论
1823 浏览 8 评论
1743 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2949 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2055 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1777浏览 0评论
GMT+8, 2024-4-19 19:08 , Processed in 1.143878 second(s), Total 69, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
