你好,
我是CyPress CY7C67 300 EZ-主机控制器的新用户,它提供了XILIXXML605开发工具包。 为了在主机模式下运行,我需要编写我想的固件。 你们谁能让我知道该怎么办?这些工具是免费的吗?如果可以的话,你能提供相同的链接吗? 谢谢你 以上来自于百度翻译 以下为原文 Hi, I am a new user of the Cypress CY7C67300 EZ-HOST controller provided with the xilinx ML605 development kit. In order to operate in the Host mode I need to write the firmware I suppose. Could any of you please let me know how to go about it ? Are the tools for free ? If so could you please provide the link for the same ? Thank you |
11个回答
你好,
您可以从HTTP://www. xLimx.com /产品/板/ML403/RealthySudio.HTM中参考键盘设计,其中,CY7C6300作为主机,因此您可以重用相同的固件。将此文件夹复制到独立文件夹中并编译它。SETHIPP//www. CyPress?COM/?软件工具ID=187和rTID= 119。通过“获得STARTE指南”HTTP//www. CyPress?Re= 14316获取有关设备的更多信息。 谢谢普拉吉斯 以上来自于百度翻译 以下为原文 Hi, You can download reference design for Keyboard from http://www.xilinx.com/products/boards/ml403/reference_designs.htm, in which CY7C67300 acts as Host, therefore you can reuse the same firmware. Copy this folder into standalone folder and compile it. See http://www.cypress.com/?id=187&rtID=119 for software tools. Go through "Getting Starte Guide" http://www.cypress.com/?rID=14316 for more information about the device. Thanks Prajith |
你好,普拉吉斯,
谢谢你的邮件。这真的很有用。 然而,我有一个小疑问-在Xilinx文件“UbSpHPIIAL测试”和“UBSX打印机”中,从Flash中的内容读取BIN文件,并通过HPI接口最初发送到EZ主机。 我的理解是,这是一种固件存储在Flash中,这是发送到EZ主机。我的理解正确吗?如果是这样,假定bin文件对外围设备是特定的,那么我怎么才能将它用于我自己的外围设备呢? 谢谢你 以上来自于百度翻译 以下为原文 Hi Prajith, Thanks for your post. It was really useful. However I had a small doubt - In the xilinx files "u***_hpi_test" and "u***_printer", a bin file is read from a content in the flash and sent to the EZ-Host via HPI interface initially. My understanding is that this is some kind of firmware which is stored inside Flash and this is being sent to the EZ-Host. Is my understanding correct ? If so presumably the bin files are specific to a peripheral and how could I reuse it for my own peripheral ? Thank you |
你好,
我在找Linux的CY7C6300开发软件。 请帮忙!? 以上来自于百度翻译 以下为原文 Hi, i'm looking for the CY7C67300 Development Softwares for linux. Any help please !? |
你好,
我们不需要Linux上的7C6300开发软件,但我们提供Linux驱动程序,它可以在C:CyPress USB OTG主机源协处理器 Linux 驱动程序 USB CY7C6300目录下找到,在您的系统上安装了3663—EZ-OTG/EZ主机开发KITAS之后。 谢谢 普拉吉斯 以上来自于百度翻译 以下为原文 Hi, We don't have [size=10.909090995788574px]CY7C67300 Development softwares for Linux but we provide Linux driver, it can be found in the C:CypressUSBOTG-HostSourcecoprocessorlinuxdriversu***cy7c67300 directory after the CY3663 - EZ-OTG / EZ-Host Development Kit has been installed on your system. Thanks Prajith |
Linux驱动程序还有其他路径吗?路径:CyPress USB OTG主机源协处理器 Linux 驱动程序 USB CY7C6300似乎不起作用?
以上来自于百度翻译 以下为原文 Is there another path for the Linux driver? The path :CypressUSBOTG-HostSourcecoprocessorlinuxdriversu***cy7c67300 does not seem to work? |
您好!
我是CyPress CY7C67 300 EZ-主机控制器的新用户,它提供了XILIXXML605开发工具包。 我想让它在外围模式下运行,不知道开发软件,你能告诉我怎么做吗?这些工具是免费的吗?如果可以的话,你能提供相同的链接吗? 谢谢你 杰克 以上来自于百度翻译 以下为原文 Hi I am a new user of the Cypress CY7C67300 EZ-HOST controller provided with the xilinx ML605 development kit. I want to make it operate in the peripheral mode,,but I do not know the developement software.Could any of you please let me know how to go about it ? Are the tools for free ? If so could you please provide the link for the same ? Thank you jack |
您好,我必须在CY7C6300开发软件上工作。我没有软件。请给我建议。如何获得软件。
以上来自于百度翻译 以下为原文 hi, i have to work on cy7c6300 development software.i don't have the software.please give me suggestioon.how to get the software. |
您好,我是CY7C6300 EZ-HOST控制器的新用户。我必须用该控制器开发固件代码。我需要CY7C6300控制支持的软件。请给我信息,如何得到…
以上来自于百度翻译 以下为原文 hi, iam new user for cy7c67300 EZ-HOST controller.i have to develop firmware code using that controller.i need cy7c67300 control supported software.please give me information,how to get..... |
HTTP://www. CyPress?COM/?ID=187和rTID=119 -PRGI
以上来自于百度翻译 以下为原文 http://www.cypress.com/?id=187&rtID=119 -PRJI |
我需要和CY7C6300控制器一起工作。我是这个控制器的新用户。我将如何为这个控制器编写Bootloader程序,以及如何将Bootloader代码构建到EEPROP中。请任何人给我提建议。
以上来自于百度翻译 以下为原文 hai...i need to work with cy7c67300 controller.iam a new user for this controller.how would i write bootloader program for this controller and how would i built the bootloader code into eeprom.please anyone can give me suggestion. |
你好。我使用CY7C6300在我的卡,当我连接我的板与我的电脑,我已经安装了EZ主机,但司机不工作。有谁能解决这个问题吗??
以上来自于百度翻译 以下为原文 Hi. I am using CY7C67300 in my card, When I connect my board with my PC in which I already installed the EZ-host but the driver doesn't work. Any one have a solution for this?? |
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-20 05:37 , Processed in 0.602998 second(s), Total 81, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
