我就是在原有的工程中加入了一段代码,有一个比较大的结构体,然后编译总是有如下问题
>> error: C60 section .sddata precedes .bss, file E:CHYGPS_PseudoliteDSPGPS_Receiver_C2_160510_RTCM_DebuggingDebugnav_fix.obj >> error: 15-bit displacement fffff6b9 is negative. Located in E:CHYGPS_PseudoliteDSPGPS_Receiver_C2_160510_RTCM_DebuggingDebugnav_fix.obj, section .text, SPC offset 00001090 >> error: C60 section .sddata precedes .bss, file E:CHYGPS_PseudoliteDSPGPS_Receiver_C2_160510_RTCM_DebuggingDebugnav_fix.obj >> error: 15-bit displacement fffff6b9 is negative. Located in E:CHYGPS_PseudoliteDSPGPS_Receiver_C2_160510_RTCM_DebuggingDebugnav_fix.obj, section .text, SPC offset 0000111c >> error: C60 section .sddata precedes .bss, file E:CHYGPS_PseudoliteDSPGPS_Receiver_C2_160510_RTCM_DebuggingDebugnav_fix.obj >> error: 15-bit displacement fffff6b9 is negative. Located in E:CHYGPS_PseudoliteDSPGPS_Receiver_C2_160510_RTCM_DebuggingDebugnav_fix.obj, section .text, SPC offset 00001128 >> error: C60 section .sddata precedes .bss, file E:CHYGPS_PseudoliteDSPGPS_Receiver_C2_160510_RTCM_DebuggingDebugnav_fix.obj >> error: 15-bit displacement fffff6b9 is negative. Located in E:CHYGPS_PseudoliteDSPGPS_Receiver_C2_160510_RTCM_DebuggingDebugnav_fix.obj, section .text, SPC offset 00001170 >> error: C60 section .sddata precedes .bss, file E:CHYGPS_PseudoliteDSPGPS_Receiver_C2_160510_RTCM_DebuggingDebugnav_fix.obj >> error: 15-bit displacement fffff6b9 is negative. Located in E:CHYGPS_PseudoliteDSPGPS_Receiver_C2_160510_RTCM_DebuggingDebugnav_fix.obj, section .text, SPC offset 000011a0 >> error: C60 section .sddata precedes .bss, file E:CHYGPS_PseudoliteDSPGPS_Receiver_C2_160510_RTCM_DebuggingDebugnav_fix.obj >> error: 15-bit displacement fffff6b9 is negative. Located in E:CHYGPS_PseudoliteDSPGPS_Receiver_C2_160510_RTCM_DebuggingDebugnav_fix.obj, section .text, SPC offset 00001204 >> warning: output file './Debug/DSPFile.out' is not executable 我的cmd文件如下 MEMORY [ VECS : o = 00000000h l = 00200h ROM_PMEM : o = 00000200h l = 2DDFFh ROM_CINIT : o = 0002DFFFh l = 02000h BMEM : o = 00030000h l = 0A000h STACKHEAP : o = 00040000h l = 0B000h SDMEM_CODE : o = 08000000h l = 300000h SDMEM_DATA : o = 08300000h l = 100000h SECTIONS [ .vectors > VECS .text > ROM_PMEM .tables > BMEM .data > BMEM .sdcode : SDMEM_CODE .sddata : SDMEM_DATA .bss > BMEM .cinit : load = ROM_CINIT .const : load = ROM_CINIT .switch : load = ROM_CINIT .cio > BMEM .far > BMEM .stack > STACKHEAP .sysmem > STACKHEAP Memory Models选的是第一个:Far Aggregate。这个错误的原因是什么?有办法解决吗?我的编译环境是CCS 2.2 |
2 个讨论
谢谢,问题已经解决了 实际上我在之前还遇到了relocation overflow这个问题,原因是程序中有比较大的结构体和数组,而程序计数器(PC)不能寻址大于64K的地址空间。我把一部分代码放置到SDRAM后,就出现了帖子中的问题,而relocation overflow这个问题却不再提示了。 解决方法是将部分大数组定义为 far 类型,但这样访问它就需要3个系统时钟了,这是我不期望的。另一个方法就是适当减小数组的大小,这个勉强能接受。 |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1897 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3647 浏览 4 评论
5031 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1734 浏览 1 评论
9372 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
669浏览 2评论
714浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
675浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1197浏览 1评论
1772浏览 1评论
GMT+8, 2024-4-24 17:44 , Processed in 0.526539 second(s), Total 39, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
