扫一扫,分享给好友
我正在寻找一些示例代码或良好的文档,用于将USB端点卸载到具有DMA的SRAM。App注意到“开始使用DMA”是好的,但不包括USB端点,组件数据表也几乎忽略了这个主题,或者只是用很少的解释来美化它。DMA向导不支持USB。还有什么其他建议吗?谢谢
以上来自于百度翻译 以下为原文 I'm looking for some sample code or good documentation for unloading a USB endpoint to SRAM with DMA. The App note "getting started with DMA" is good but doesn't cover USB endpoints, the component data sheets also pretty much leave out this topic or just gloss over it with little explanation. The DMA Wizard doesn't support USB. Any suggestions on where else to look? Thanks |
9个回答
我所经历的u***_loadinep() API。它有代码的自动DMA和曼努拉DMAMODE的数据传输。设置DMA的USB端点编码是目前。伤心,柏树没有记载这地方。
以上来自于百度翻译 以下为原文 I was going through the USB_LoadInEP() API. It has code for the Auto DMA and Manula DMA mode of data transfer. Code for setting up DMA for USB Endpoints is present there. Sad that Cypress has not documented this anywhere. |
当*什么*帮助和大师没有回答你可以创建一个案例(支持-技术支持- >;>;创建案例),将由赛普拉斯员工通常有一个良好的技术背景,回答。
试一试(在这里发布解决方案) 鲍勃 以上来自于百度翻译 以下为原文 When *NOTHING* helps and none of the gurus had an answer yet you may always create a case (support -> Technical Support -> Create a Case) that will be answered by a Cypress employee who usually have an excellent technical background. Give it a try (and post the solution here for us) Bob |
有一个原因,它没有突出任何地方。USB的数据源只能是SRAM。任何其他外围不能作为数据的USB直接来源。如果你打算数据从ADC转USB接口,你必须使用一个中间的SRAM缓冲器作为一个公共的场所,ADC转储数据和将数据从USB。我们有一个新的应用笔记,这正是这一点。
以上来自于百度翻译 以下为原文 There is a reason why it is not highlighted anywhere. The source of data for USB can only be SRAM. ANY OTHER PERIPHERAL can not be used as direct source of data for USB. If for example you intend to transfer data from ADC to USB, you have to use an intermediate SRAM buffer as a common place where ADC dumps data to and USB takes data from. We have a new App Note coming up which does exactly this. |
嗨,u2,
我在本应用笔记很感兴趣,因为它描述的正是我想实现。它已经可用了吗? 最好的问候 沃尔特 以上来自于百度翻译 以下为原文 Hi U2, I'm very interested in this application note because it would describe exactly what I like to implement. Is it already available? Best Regards Walt |
是U2的这将是一个传奇应用笔记我们怎么知道这是完成了吗??
以上来自于百度翻译 以下为原文 Yeah U2 this will be a legend app note how could we know it is finished and became available?? |
这条线已有几年的历史了。问题被回覆并在这里回答:
鲍勃 以上来自于百度翻译 以下为原文 This thread is alredy some years old. Question was repeted and answered here:www.cypress.com/ Bob |
非常感谢鲍伯先生,我没有等到你的回复通知的日期。你能更具体的我是新来这个网站,这个社区我怎么能在这里找到它。
以上来自于百度翻译 以下为原文 Thanks alot mr.Bob i didn't notice the date until you reply. Can you be more specific I am new to this website and this community how can i find it in here. |
第一:请不要先生。只是“鲍伯”
第二点:点击我之前帖子中的蓝色链接,你会转到我剩下的答案。 鲍勃 以上来自于百度翻译 以下为原文 1st: No Mr., please. Just "Bob" 2nd: Click on the blue link on my previous post and you woill be directed to your other question where I left an answer. Bob |
嗨,我认为应用笔记是an56377纠正我,如果我错了。最大伤害最大伤害
以上来自于百度翻译 以下为原文 Hi, I think the app note is AN56377 correct me if i am wrong. Best Regards maxdamage |
只有小组成员才能发言,加入小组>>
713个成员聚集在这个小组
加入小组1888 浏览 1 评论
1637 浏览 1 评论
3392 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1556 浏览 6 评论
1371 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
170浏览 2评论
170浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
304浏览 2评论
323浏览 1评论
45浏览 1评论
GMT+8, 2024-3-29 01:20 , Processed in 0.629953 second(s), Total 84, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
