我觉得我在勘误表中找不到这个问题的明确答案。我注意到SPC56具有5V容限ADC,但我想知道我是否可以将5VDC逻辑用于GPIO引脚?我有一些传统的5V移位寄存器,我想知道GPIO输入是否是5V安全的......
以上来自于谷歌翻译 以下为原文 I feel like I am not finding an explicit answer to this question in the errata. I notice that the SPC56 has a 5V tolerant ADC, but I am wondering if I can use 5VDC logic for the GPIO pins? I have some legacy 5V shift registers and I am wondering if the GPIO inputs are 5V safe... |
2个回答
马修你好,
您可以在SPC56EL70的数据表中找到一些有用的信息 http://www.st.com/content/ccc/resource/technical/document/datasheet/7a/58/72/a0/1c/45/4a/1b/DM00070691.pdf/files/DM00070691.pdf/jcr:内容/翻译/ en.DM00070691.pdf 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Matthew , you can find some useful information in the datasheet for SPC56EL70 http://www.st.com/content/ccc/resource/technical/document/datasheet/7a/58/72/a0/1c/45/4a/1b/DM00070691.pdf/files/DM00070691.pdf/jcr:content/translations/en.DM00070691.pdf Best regards Erwan |
我不认为该数据表是明确的。据我所知,当ADC参考电压为5V时,ADC引脚的容差为5 V,但我想这主要是出于ADC寄存器转换的原因,而不是硬件? ADC焊盘与GPIO复用。这让我相信硬件可能是宽容的,至少在多路复用之前。根据数据表的模糊程度,假设任何GPIO都具有5伏容限,即使引脚在配置为ADC时能够容忍,也不是明智之举。我没有使用任何ADC,我知道可接受的逻辑电平与实际硬件容差之间存在差异。有没有更明确的答案,GPIO输入引脚是否有5伏TTL容限?
VDD_HV_ADR最大值为6.4V VDD_HV_IO max为4.5V < - 这用作输入参考和输出电流源(我认为)。 GPIO [输入]最大值是? 以上来自于谷歌翻译 以下为原文 I don't feel like that data sheet is explicit. I understand that the ADC pins are 5 Volt tolerant when the ADC Reference is 5V, but I guess this is mostly for ADC register conversion reasons, not hardware?. ADC pads are multiplexed with GPIO. This leads me to believe that maybe the hardware is tolerant, at least prior to mux. Based on how vague the datasheet is, it wouldn't be wise for me to assume that any of the GPIO is 5 Volt tolerant, even if the pin is tolerant when configured for ADC. I'm not using any ADC, and I understand that there is a difference between accepted logic levels, verse actual hardware tolerance. Is there a more definitive answer, are GPIO input pins 5 Volt TTL tolerant? VDD_HV_ADR max is 6.4V VDD_HV_IO max is 4.5V <- this serves as an input reference and output current source (i think). GPIO [Input] max is ? |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1408 浏览 1 评论
2058 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1507 浏览 1 评论
2803 浏览 6 评论
5186 浏览 21 评论
351浏览 4评论
503浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
561浏览 3评论
479浏览 3评论
GMT+8, 2024-4-20 10:56 , Processed in 1.131166 second(s), Total 71, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
