发 帖
张飞软硬开源基于STM32 BLDC直流无刷电机驱动器开发视频套件, 👉戳此立抢👈
[问答] 16x2 LCD PIONEER套件屏蔽
113 LCD 调节器
分享
在购买了三个先锋套件(初夏)后,我需要一个更好的方法来快速原型项目。这包括一个LCD显示器和一个类似于Cy310 PSOC EVAL1的柏树工具箱的电路板。
我个人使用12的PCB生产。PCB布局使用单独的电压调节器,16X2液晶模块使用HD44 7805V控制器,缺少光,跳线选择几种连接电源的方式。屏蔽可以被配置为使用面包板或线缠绕端子。
我在LCD问题上没有问题,如CY8CKIT-042 PSoC’s中所指出的。屏蔽与绿森LCM所以1602dsr /液晶显示模块(用于赛普里斯包)没有背光。然而,我还没有尝试过使用splc780d控制器3.3v模块。特定的控制器使用了一个额外的8引脚集成电路焊接在LCD板的背面。资料表明,splc780d控制器与HD44780兼容。然而,上电时序/初始化可能不同。
见所附的盾构与线路板文件。
杰姆斯B
LCDShield
977.2 K
以上来自于百度翻译
     以下为原文
  After purchasing three Pioneer kits (early summer) I needed a better way to quickly prototype projects. This included having an LCD display and a breadboard similar to lot of the Cypress Kits like the CY310-PSoC EVAL1.
    I produce 12 PCB for personal use. The PCB layout uses a separate voltage regulator, 16x2 LCD module using theHD44780 5V controller with lack light, and jumpers to select several ways to connect power.     The shields can be configured to use a breadboard or wire wrap terminals.
    I’ve had no problems with LCD issues as indicated in thread CY8CKIT-042 PSoC 'ES'. The shield works with the LUMEX LCM SO 1602DSR/A LCD module (used in Cypress kits) with no back light. However, I have not tried it with a 3.3V module using the SPLC780D controller. That particular controller uses an extra 8 pin IC soldered on the back of the LCD board.  Data sheets indicate that the SPLC780D controller is compatible with the HD44780. However, the power up timing/initialization may be different.
    See attached file of shield with breadboard.
    James B
2019-1-16 15:09:31   评论 分享淘帖 邀请回答
2个回答
谢谢你,尼斯Pix
以上来自于百度翻译
     以下为原文
          Thank you, Nice Pix
2019-1-16 15:28:45 评论
举报
看起来不错。也可以贴上PCB设计,供他人使用。
以上来自于百度翻译
     以下为原文
   looks good. May be you can post the PCB design for other to use as well.
2019-1-16 15:42:01 评论
举报
只有小组成员才能发言,加入小组>>
306个成员聚集在这个小组
加入小组
创建小组步骤
关闭
站长推荐 上一条 /8 下一条
快速回复 返回顶部 返回列表
