我已经遵循了CAPSESESECCSD[V3.10]数据表或PSoC(R)3和PSoC(R)5 CAPSENSE(R)设计指南(ZH)数据表的所有指令。总线连接已被连接,所有参数都遵循指令。但是它不能传输数据。你能帮我解决这个问题吗?谢谢您!
20130704155916.JPG 32.4 K 以上来自于百度翻译 以下为原文 I have already followed all the instructions from on the CapSense_CSD[v3.10] datasheet or PSOC(R) 3 AND PSOC(R) 5 CAPSENSE(R) DESIGN GUIDE (ZH) datasheet. The bus connection has been connectted,and all Parameter are followed from instructions. But it can not transfer data. can you help me solve this problem? Thank you!
5个回答
嗯,一定是错的,如果我们不想什么,最好是上传你的完整的项目,这使我们大家都可以看看。使用造物主的功能”创建工作捆绑”并上传生成的归档文件在这里。
鲍勃 以上来自于百度翻译 以下为原文 Well, something must be wrong and if we are not trying to guess what, best would be to upload your complete project here so that we all can have a look at. Use Creator's function "Create Workspace Bundle" and upload the resulting archive-file here. Bob |
谢谢你的回复。我是PSOC3的CasSeple的初学者。我已经设计了四个按钮的CasSoC和线性滑块的CAPSENSE。我使用MixPrime3作为T2OB转换的I2C桥,并且我已经成功地连接了MyPrim3和我设计的PCB布局,但是它不能传输数据。附件中的具体设计。非常感谢!
PSOC3-CAPENSEX.ZIP 2.6兆字节 以上来自于百度翻译 以下为原文 Thanks for your reply . I am the beginner of Psoc3's Capsense . I have designed four buttons of Capsense and linear sliders of Capsense . I use MiniProg3 as I2C bridge in order to USB conversion ,and I have successfully connected MiniProg3 and the PCB layout which I have designed, but it can not transfer data . Specific design in Annex . thank you very much !
我还没有使用调谐器,但请记住:它只是一个调谐器,以适应参数为您的CAPSENSE按钮和滑块。
使用调谐器的程序看起来与我在文档中发现的完全不同,看看这个线程,有一个CasSoq调谐器的例子:HTTP://wwwyCysP.com/?APP =论坛和ID ID=2232和;RID=53237 另外,我建议您更新您的(以及示例项目)!)到Creator的用户模块的最新版本,到目前为止已经发生了变化。 快乐编码 鲍勃 以上来自于百度翻译 以下为原文 I did not use the tuner yet, but remember: it is just a tuner to adapt the parameters for your capsense buttons and sliders. The program to use the tuner looks quite different from what I've found in the docs, have a look at this thread, there is a capsense tuner example: http://www.cypress.com/?app=forum&id=2232&rID=53237 Additionally I would suggest you to update your (and the example project!!) to the latest version of Creator's usermodules, there have been changes made so far. Happy coding Bob |
非常感谢你的建议,我会再试一次。如果我仍然有问题,我不得不麻烦你帮我回答。非常感谢。祝你有美好的一天!
以上来自于百度翻译 以下为原文 Thanks very much for your suggestions,I would try again . If I still have problems,I have to trouble you to help me answer.Thanks very much.Have a good day ! |
只有小组成员才能发言,加入小组>>
717个成员聚集在这个小组
加入小组1901 浏览 1 评论
1653 浏览 1 评论
3406 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
188浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
325浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-25 19:33 , Processed in 0.788099 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
