您好,我正在上面提到的示波器上运行最新的固件。
(6.16.0001)我试图通过'CHAN1:COUP AC'远程命令改变从DC到AC的通道耦合。 但是当我尝试通过ACE交互式窗口进行操作时,我收到了“221设置冲突错误”。 但是当我在示波器上手动更改它时,它让我这样做! 所以我不明白为什么我被阻止远程更改它。 我查阅了编程指南中的错误,但它只是参考波形子系统查询(页66)来讨论它。 我确实检查了'tiMEBASE:MODE?' 它被设置为'MAIN'。 任何想法为什么以及如何让它工作? 谢谢,rok 以上来自于谷歌翻译 以下为原文 Hello, I am running the latest firmware on the above mentioned oscilloscope. (6.16.0001) I'm trying to change the channel coupling from DC to AC by the 'CHAN1:COUP AC' remote command. But when I try to do it via the ACE interactive window, I get a '221 Settings conflict error'. But when I change it manually on the oscilloscope itself, it lets me do it! So I don't understand why I being blocked from changing it remotely. I looked up the error in the programming guide, but it only talks about it in reference to a waveform subsystem query (Page66). I did check the 'TIMEBASE:MODE?' and it is set to 'MAIN'. Any ideas why and how to get it to work? Thanks, rok |
4个回答
你是50欧姆模式吗?
在用户指南中,“交流耦合对于查看具有较大直流偏移的波形很有用。选择交流耦合时,不能选择50欧姆模式。这样做是为了防止损坏示波器。” 人 以上来自于谷歌翻译 以下为原文 Are you in 50 Ohm mode? From the User's Guide, "AC coupling is useful for viewing waveforms with large DC offsets. When AC coupling is chosen, you cannot select 50 Ohm mode. This is done to prevent damage to the oscilloscope." Al |
嗯...你提到能够从前面板更改设置,但不能从远程命令更改。
这很奇怪,但我猜你正在访问前面板Mode / Coupling菜单中的Coupling软键而不是[Ch1]菜单中的那个(假设Ch1也是50欧姆)? 我曾经混淆了两个不同的“耦合”软键 - 一个控制:TRIG:COUP而另一个控制:CHAN:COUP。 好吧,只是我的猜测。编辑:bret于2013年5月15日上午8:36 以上来自于谷歌翻译 以下为原文 Hm ... you mentioned being able to change the setting from the front panel, but not from the remote command. That is weird, but I'm gonna guess that you are accessing the Coupling softkey in the Mode/Coupling menu of the front panel instead of the one in the [Ch1] menu (assuming Ch1 is in 50-ohms as well)? I used to mix up the two different "Coupling" softkeys -- one controls :TRIG:COUP while the other controls :CHAN:COUP. Well, just my guess. Edited by: bret on May 15, 2013 8:36 AM |
嗨,谢谢你的回复。
我将检查50欧姆模式是否启用。 另外,您提到了触发耦合。 有可能我可以将它与通道耦合模式混合,所以我会仔细检查它。 但是,在更改通道耦合之前,是否必须先将触发耦合更改为AC? 也许这就是为什么它给我一个设置冲突。 谢谢,rok 以上来自于谷歌翻译 以下为原文 Hi, Thanks for the replies. I'll check to see if the 50ohm mode is enabled or not. Also, you mentioned trigger coupling. It could be possible that I could be mixing it with the channel coupling mode, so I'll double-check that. But do I have to change the trigger coupling to AC first before changing the channel coupling? Maybe that is why it is giving me a settings conflict. Thanks, rok |
看起来触发耦合和通道耦合设置彼此独立
以上来自于谷歌翻译 以下为原文 It seems like the Trigger Coupling and Channel Coupling settings are independent of each other |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 12:02 , Processed in 1.171734 second(s), Total 74, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
