我有几年前购买的E4419A功率计,直到现在只用于8487传感器,问题是如果我将E4413A传感器连接到通道A并降低功率从+10到-60dBm,一切都看起来很棒直到你
达到-30dBm标记,如果你降低,电表上的电平读数会下降到-70dBm并保持在那里,一旦你回到-30dBm再次读数就可以了,这个问题不会出现在B频道上 测量板! 我正在寻找这个单元的原理图,看看我是否能找到问题,但如果有人对板上的问题有任何建议,那么id很感激,也有人有原理手册的#部分吗? 第二个问题是关于测量板上的EPROM,几年前有一个升级套件可以使用E9300系列传感器,但它现在已经过时了,有没有这个EPROM的immage或hex文件可用或者 有人有可以复制的EPROM吗? 以上来自于谷歌翻译 以下为原文 i have a E4419A powermeter i bought a few years ago and up until now only used with 8487 sensors , the issue is that if i connect a E4413A sensor to channel A and step down power from +10 to -60dBm everything looks great up until you hit the -30dBm mark , if you go lower the level reading on the meter jumps down to -70dBm and stay there, as soon as you go back to -30dBm the reading is ok again , this problem does not appear on Channel B and follows the measurement board ! I was looking for the schematics on this unit to see if i can find the issue but if somebody has any suggestions on what the issue might be on the board then id appreciate it , also does anyone have the part# for the schematic manual ? Second question is in regards to the EPROM on the measurement board, there was a upgrade kit available a few years ago to enable to use of E9300 Series sensors but it is now obsolete , is there a immage or hex file for this EPROM available somewhere or does anyone have a EPROM that can be copied ? |
2个回答
嗨,我有一个额外的EPM-A系列功率计EEPROM升级套件E4418-90045。
据我所知,它也与E4419A / E4418A系列兼容。 它包括一个编程的E4418-80023 EEPROM(rev A.01.11)和E4418-90045安装说明。 对于E4419A,您需要两个相同的EEPROM。 如果你仍然需要它,请告诉我。 BR,Jaakko 以上来自于谷歌翻译 以下为原文 Hi I have an extra EPM-A-series power meter EEPROM upgrade kit E4418-90045. To my understanding it is also compatible to E4419A/E4418A-series. It includes one programmed E4418-80023 EEPROM (rev A.01.11) and E4418-90045 installation note. For E4419A you need two identical EEPROMs. PM me for details if you still need it. BR, Jaakko |
我将在一个月内复制它,并测试它是否可以升级A到B.
以上来自于谷歌翻译 以下为原文 I will copy it within one month, and test it if can upgrade A to B |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 11:59 , Processed in 1.138375 second(s), Total 74, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
