您好,我需要通过串行通信接口arduino和vee pro,我需要从arduino微控制器发送和获取数据。
任何人都可以帮助我并告诉我如何开始,因为我在这种事情上有点新意。 谢谢 以上来自于谷歌翻译 以下为原文 Hello, I need to interface arduino and vee pro through serial communication where i need to send and acquire data to and from the arduino microcontroller. Can anybody help me and tell me how to start because im kind of new in this kind of thing. thanks |
1个回答
激活串行通信 - 文件>首选项> Vee8.5 legacy查找串口 - 启动>程序> Agilent IO库> Agilent IO连接专家>刷新如果有任何错误,它将不再继续。
当Arduino董事会通过Arduino软件进行通信时,我曾经有过一次。 停止并关闭Arduino软件,然后重试。 如果仍然存在通信错误,我可能无法回答。 如果没有错误,运行Vee pro,在直接IO中找到com port - IO manager> find> direct IO,添加要读取的事务。 就我而言,我从DHT22传感器获取温度和湿度数据。 进入com端口的数据是一个包含4个数据元素的数组。 它正在读取数据,我已经能够获取数据并用它来控制连接到加热元件的电源,以通过GPIB控制温度。 并且数据已保存在excel文件中。 祝你好运。 以上来自于谷歌翻译 以下为原文 activate serial communication - file>preference>Vee8.5 legacy find the serial port - start>programs>Agilent IO library>Agilent IO connection expert>refresh if there is any error, it won't go any further. I had once when Arduino board was communicating through Arduino software. Stop and close Arduino software and try again. If still there is communication error, I may not be able to answer. If there is no error, run Vee pro, find com port - IO manager>find>direct IO in the direct IO, add transaction to read. In my case, I was getting temperature and humidity data from DHT22 sensor. The data coming to com port was an array with 4 data elements. it is currently reading the data and I have been able to get the data and use it to control power supply connected to a heating element to control temperature through GPIB. and the data has been saved in excel file. Good luck. |
只有小组成员才能发言,加入小组>>
2082 浏览 1 评论
1846 浏览 1 评论
1700 浏览 5 评论
2563 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1547 浏览 4 评论
关于Keysight x1149 Boundary Scan Analyzer
349浏览 0评论
1386浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
262浏览 0评论
2248浏览 0评论
1103浏览 0评论
GMT+8, 2024-3-29 15:17 , Processed in 1.002659 second(s), Total 66, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
