嗨,我想控制开发的燃烧器,请告知我,这板附近matchmy要求。!
我想控制的压力和温度传感器和3台燃烧器火焰燃烧器的工作上。一:系统启动(控制:监控传感器的压力和温度):预热塞12v 17a(控制:打开/关闭定时器+温度传感器):风机12v 11a,(控制:开/关+ PWM调速+温度传感器:燃油泵12V,4A,PWM开关(控制:开/关+可变速度开关D +温度传感器燃烧器系统启动时所需的压力和温度将达到的水平。1st辉光插头会在产生火焰,2nd鼓风机将在低流量,3rd燃油泵将用于产生连续的火焰,一:单片机32bit Cortex M4 200mhz 2:闪存2mb +加速器三:内存512四:2u*** +2五:以太网IEEE1588六:ADC 8 7:开/关六mofsets功率:温度传感器6 9:P压力传感器6 10:JTAG头11:TFT控制器+液晶10:I / O 20 11:多功能报警4个+ RTC 12:PWM 8 等待您的帮助答复。问候安德烈·萨米 以上来自于百度翻译 以下为原文 Hi, I want to develop control unit for burner, kindly advise me, which board kit is near to match my requirements .! I want to control burner flame with pressure and temperature sensors and three units are attached with burner working. 1: System start up with ( control : Monitor pressure and Temp by sensors ) 2: Glow Plug 12v 17A (control : switch on/off with timer + Temp sensor ) 3: Blower fan 12V 11A, ( Control : switch on/off + PWM variable speed + temp sensor 4: Fuel Pump 12V, 4A, PWM ( Control : Switch on/off + variable speed + temp sensor Burner system will start up when Pressure and Temp will reached at desired level. 1st glow plug will on for produce flame , 2nd blower will on with low flow, 3rd fuel pump will on for produce continuous flame, 1: MCU 32Bit Cortex M4 200Mhz 2: Flash 2mb + Accelerator 3: Ram 512 4: 2USB + 2 CAN 5: Ethernet IEEE 1588 6: ADC 8 7: Power on/off 6 Mofsets 8: Temperature Sensor 6 9: Pressure Sensor 6 10: Jtag header 11: TFT controller + LCD 10: I/O 20 11: Multi Function AlARMs 4 +RTC 12: PWM 8 Awaiting your helpful reply. Regards Sami |
2个回答
在同一个问题上到处张贴论坛真的是一个坏习惯!
鲍勃 以上来自于百度翻译 以下为原文 Spamming the forum with the same question all over is really a bad habit! Bob |
目前,PSoC没有以太网IEEE 1588的支持。
以上来自于百度翻译 以下为原文 Presently ,PSoC has no Ethernet IEEE 1588 support |
只有小组成员才能发言,加入小组>>
713个成员聚集在这个小组
加入小组1888 浏览 1 评论
1637 浏览 1 评论
3392 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1556 浏览 6 评论
1371 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
170浏览 2评论
170浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
304浏览 2评论
323浏览 1评论
45浏览 1评论
GMT+8, 2024-3-29 00:12 , Processed in 0.538707 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
