1,使用定时中断、外部中断,解码红外;
2,红外接收管正对着发射管时,程序正常; 3,红外接收管偏离发射管时(临界状态),CPU会自动复位重启,串口检测到“s”字符、pass_lamp = 0亮(已按按钮,进入while循环); 4,看门狗已关闭; 5,各位请帮忙看看,是怎么回事???(外部频繁触发中断会导至CPU复位????) 文件1: #include #include #include #include "system.h" #include "command.h" #include "delay.h" #define Uchar unsigned char #define Uint unsigned int #define Ulong unsigned long sfr WDT_CONTR = 0xE1; Uchar Uart_Buffer[8]; //串口接收数据缓存 Uchar RI_NUM = 0; //接收字符计数器 bit Uart_Receive_Flag = 0; //串口接收到数据标志 bit RI_String_Start = 0; bit Dispose_String_End = 0; bit RI_Start = 0; #define char_Start 64 //'@' 40H #define char_End 10 //'LF' 0AH Uint timer_1 = 0; Uint timer_2 = 0; char irtime = 0; unsigned char irpro_ok,irok = 0; unsigned char irdata[33]; //33个高低电平的时间数据 unsigned char IRcord[4]; //处理后的红外码,分别是 客户码,客户码,数据码,数据码反码 bit timerout_enable = 0; bit flag_0 = 0; bit flag_1 = 0; bit flag_2 = 0; bit flag_3 = 0; bit flag_4 = 0; void sys_init(void) { //WDT_CONTR = 0x3C; //11.0592M,溢出时间1.1377S,开启看门狗、使能重新计数、使能空闲计时模式、32预分频,使能看门狗,看门狗溢出时间11.38ms PCON = 0x80; //串口通讯波特率加倍,为定时器1溢出率/16 SCON = 0x50; //串口工作方式1 ( 1位起始位0,8位数据位,1位停止位1 ),使能接收允许 //波特率=2^smod*定时器1的溢出率/32 TMOD = 0x21; //T1为定时器方式2,8位自动重装,T0为定时器方式1,16位定时,定时/计数器工作于定时方式 TH1 = BAUD_9600;//256 - (OSC_FREQ/192L)/9600L //256-Fosc(SMOD+1)/(384*baud) TL1 = TH1; //定时器1计数初值 TR1 = 1; //波特率发生器,定时器1开启 ET0 = 1; //定时器0中断使能 // TH0 = 0xFF; // TL0 = 0xA4; //(100us)定时器0初值=65535+1-计数值 //计数值=(定时时间*晶振*1000*1000)/12 // TH0 = 0xFF; // TL0 = 0x48; //200us TH0 = 0xFF; TL0 = 0x1A; //250us定时 //TH0 = Timer0_Reload / 256; //TL0 = Timer0_Reload % 256; TR0 = 1; //定时器0开启 TI = 0; //串口发送中断请求标志位 RI = 0; //串口接收中断标志 //ES = 1; //串口中断使能 //PS = 1; //串口中断设置为高优先级 EA = 1; //CPU中断使能开启 //EX0 = 1; //外部中断0使能 IT0 = 1; //下降沿触发外部中断0 } void Ircordpro(void)//红外码值处理函数 { unsigned char i, j, k; unsigned char cord,value; k=1; //(me:屏蔽引导码时间,从用户码开始) for(i=0;i<1;i++) //处理4个字节 { for(j=1;j<=8;j++) //处理1个字节8位 { cord=irdata[k]; if(cord>7) //大于某值(1.8ms)为1,这个和晶振有绝对关系,这里使用12M计算,此值可以有一定误差 { value=value|0x01; } else { value=value; } if(j<8) { value=value<<1; } k++; } IRcord[i]=value; //IRcord[i]为波形值(me) value=0; } irpro_ok = 1;//处理完毕标志位置1 } void main() { sys_init(); send_char('s'); pass_lamp = 0; //WDT_CONTR = 0x3C; while(1) //主循环 { out_3 = 1; if( !start_SW ) //启动按钮 { pass_lamp = 1; fail_lamp = 0; } } } 文件2: #include #include #include #include #include #include "reg52.h" #include "command.h" #include "delay.h" #include "absacc.h" #define Uchar unsigned char #define Uint unsigned int #define Ulong unsigned long //sfr WDT_CONTR = 0xE1; //send_char:直接发送字符函数 void send_char ( char s_data ) { SBUF = s_data; while( TI==0 ) ; TI=0; } extern bit timerout_enable; extern Uint timer_1; extern Uint timer_2; #define ONE_SEC 4000 unsigned int run_timer = 0; extern Uint timer_1; extern Uint timer_2; extern char irtime; extern char irok; extern unsigned char irdata[33]; //33个高低电平的时间数据 void TimeOut_ISR (void) interrupt 1 using 3 //12*(0xFFFF+1-0xFFA4)/11059200=250us { //TR0 = 0; //关闭Timer0 // TH0 = Timer0_Reload / 256; // TL0 = Timer0_Reload % 256; TH0 = 0xFF; TL0 = 0x1A; //TR0 = 1; //开启Timer0 //WDT_CONTR = 0x3C; //11.0592M,568.6ms溢出 run_timer ++; timer_1 ++; timer_2 ++; irtime ++; if( run_timer >= ONE_SEC ) //1秒闭烁 { run_timer = 0; LED_RUN = !LED_RUN; } EX0 = 1; //外部中断0使能 } void Ext0(void) interrupt 0 { static unsigned char i; //接收红外信号处理 EX0 = 0; //外部中断0关闭 out_3 = 0; if(irtime<60&&irtime>=44) //引导码 TC9012的头码,9ms+4.5ms //(me:检测两次中断触发的时间250us) i = 0; irdata[i]=irtime; //存储每个电平的持续时间,用于以后判断是0还是1 irtime = 0; i++; if( i==9 ) //(me:引导码+用户码+用户码+数据码+数据码) { irok=1; } } 其它头文件: #ifndef __SYSTEM_H__ #define __SYSTEM_H__ #ifdef __cplusplus //如果是C++编译器,就使用该定义 extern "C" //强制使用C方式编译以下函数 { #endif #define uchar unsigned char #define uint unsigned int #define ulong unsigned long #define MAIN_Fosc 11059200L //晶振 #define Timer_0 250 //定时器0定时时间,us #define freq_base (MAIN_Fosc / 1200) #define Timer0_Reload ( 65536 - (Timer_0 * freq_base / 10000)) //定时器0计数初值 ***it LED_RUN = P2^7; //CPU运行指示灯 ***it start_SW = P1^0; //IN0 ***it switch_1 = P1^1; //IN1 ***it switch_2 = P1^2; //IN2 ***it switch_3 = P1^3; //IN3 ***it pass_lamp = P2^5; //OUT0 ***it fail_lamp = P2^4; //OUT1 ***it buzzer = P3^5; //OUT2 ***it out_3 = P3^4; //OUT3 |
3个回答
应该是电流的问题
供电的问题了
电源设计的域量不足
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【每周推荐】采用11代Intel CPU,基于youyeetoo X1开发板搭建少儿AI智能STEAM积木平台
752 浏览 0 评论
2208 浏览 2 评论
【youyeetoo X1 windows 开发板体验】+ 影音处理和AI模型移植
2084 浏览 5 评论
I.MX6ULL-飞凌 ElfBoard ELF1板卡- 移植zbar的方法
1682 浏览 0 评论
2636 浏览 3 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
5453 浏览 31 评论
GMT+8, 2024-4-18 08:32 , Processed in 0.559255 second(s), Total 68, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
