步进电机驱动器IC
我们实施了 我们通过SPI在STM32F072单片机上向POWERSTEP01发送命令。 当我们发送方向为0x58或0x59的命令时。电机轴变为HOLD但它会改变轴的位置。 我们正在寻找应用stepclock命令后电机轴位置变化的原因。 #powertep01#stepper-motor #stepclockmode 以上来自于谷歌翻译 以下为原文 Stepper Motor Driver IC We implemented We are sending command to POWERSTEP01 through on board STM32F072 microcontroller through SPI. When we sendcommand with direction that is 0x58 or 0x59 . The motor shaft gets HOLD but it change the position of the Shaft. We are finding the reason behind the change of position of the motor shaft after applying stepclock command. #powerstep01 #stepper-motor #stepclockmode |
3个回答
多少变化?总是一致的方向?你是否在两者之间取消了StepClock模式?如果您发送一系列StepClock指令,它会提前,还是什么?尝试更好,更完整地描述正在发生的事情,而不是让我提出大量问题。
通常,如果您向不在您正在做的事情前面的人彻底描述问题,您通常会看到您遗失的内容(如果您确实遗漏了某些内容)或者可能意识到答案。通常我们的假设阻止我们看到答案。 以上来自于谷歌翻译 以下为原文 how much change? Always same direction? Are you unsetting StepClock mode in between? If you send a series of StepClock instructions does it advance , virbrate or what? Try to give a better, more complete description of what is happening, rather than making me ask loads of questions. Often if you describe a problem thoroughly to someone who is not in front of what you are doing, you will often see what you are missing ( if indeed you are missing something ) or may realise the answer. It's often our assumptions which prevent us from seeing the answer. |
我们没有给出任何步进时钟脉冲。我们只想把电机抱起来。但是一旦我们应用了stepclock模式命令,电机轴就会改变位置,然后电机就会停止。
以上来自于谷歌翻译 以下为原文 We are not giving any step clock pulses. we just want to HOLD the motor. But as soon as we apply stepclock mode command , motor shaft will change the position and after that motor gets hold. |
您似乎没有回答我提出的一个具体问题。如果你自己不问问题而不回答可能有助于了解正在发生的事情的问题,那么你就不会有任何问题。
以上来自于谷歌翻译 以下为原文 It does not appear that you have answered a single one of the specific questions I have asked. If you do not ask questions yourself and do not answer questions which may help see what is happening you are not going to get anywhere. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1408 浏览 1 评论
2058 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1507 浏览 1 评论
2803 浏览 6 评论
5186 浏览 21 评论
351浏览 4评论
503浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
552浏览 3评论
479浏览 3评论
GMT+8, 2024-4-19 22:12 , Processed in 0.865052 second(s), Total 72, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
