您好,我不知道还有其他人发布这个,所以我在这里做。
我对Benchlink软件有几个问题。 在我们的实验室中,我们仍然使用Benchlink 1.4作为Benchlink-3 4.3的最爱。 为什么,因为它更易读,线条更清晰,时间标记更好,另外几件事。 我也遇到了新软件和Agilent 34970A设备与USB2RS232接口相结合的问题。 它在Windows 7中仍然运行良好。最新的Benchlink与时间标记不兼容,每次单击标记时,您必须再次将其调整为所需的时间(令人沮丧)。 在Benchlink 1.4中,您可以设置一次,然后只需单击所有通道进行检查,标记就会保留在时间位置设置上。 新的Benchlink可能有一些优势,但是,即使单独出现标记问题,我们也不会使用新的Benchlink,除非该软件具有与Benchlink 1.4完全相同的可能性。 我们将新版本视为退一步。 现在最大的问题是,我们无法在Windows 8上安装Benchlink 1.4(来自原始cd)(即使不是兼容模式),尽管它在Windows 7上运行得非常好。 有没有人有这方面的解决方案,所以我们能够在Windows 8上安装它? 如果没有,那么我们将不得不重新安装Windows 7。 感谢您的帮助!编辑:Jerry003于2014年4月7日上午6:50 以上来自于谷歌翻译 以下为原文 Hello, i don't know were else to post this so i do it here. I have a few questions about the Benchlink software. In our lab we still use Benchlink 1.4 in favorite of Benchlink-3 4.3. Why, because it is better readable, the lines are sharper, the time markers work better and another few things. I also encounter problems with the new software and our Agilent 34970A devices in combination with USB2RS232 interfaces. It still works good in Windows 7. The latest Benchlink doesn't work well with the time markers, every time you click a marker you have to adjust it again to the elapsed time you need(frustrating). In Benchlink 1.4 you can set it once and then just simply click all the channels to check and the markers stay on the time position set. The new Benchlink may have some advantages but, but even alone on the marker issue, we are not going to use the new Benchlink, unless the software will have exactly the same possibilities as Benchlink 1.4. We see the new version more as a step back. The biggest issue now is, we can't install Benchlink 1.4 (from original cd) on windows 8 (even not in compatibilty mode), alltough it does work on Windows 7 very well. Does anyone have a fix for this, so we are able to install it on Windows 8? if not then we will have to put Windows 7 back on it. Thanks for your help! Edited by: Jerry003 on Apr 7, 2014 6:50 AM |
5个回答
不幸的是,BLDL 1.4不会像你发现的那样在Windows 8上运行。
这个旧版本的BLDL来自不再经营的第三方。 它已经过时且不受支持,但它是您发现的好软件。 以上来自于谷歌翻译 以下为原文 Unfortunately BLDL 1.4 will not run on Windows 8 as you have discovered. This old version of BLDL came from a third party that is no longer in business. It is obsolete and out of support, but it is good software as you have discovered. |
lanziji 发表于 2019-1-4 15:44 谢谢你的回答TomC好吧我们把Windows 7放回机器上,然后让Windows 8保持原样。 并再次安装1.4版本,效果最好! 我们可以忍受它。 等待Windows 9,Windows 8无法使用。 或许那时候必须有Linux支持。 许多公司现在正在逐步使用Linux / Ubuntu,而不是Windows 8用于实验室或研讨会环境。 然后也许希望有一个更好的Benchlink计划和/或我们将在那时拥有一些新设备。 谢谢。 以上来自于谷歌翻译 以下为原文 Thanks for your answer TomC ok we putted back Windows 7 on the machine and leave windows 8 for what it is. And installed the 1.4 version again which works the best! We can live with it. Wait for Windows 9, windows 8 is unworkable. Or maybe there must be Linux support by then. Lots of companies are stepping over to Linux/Ubuntu now instead of Windows 8 for their Lab or workshop environment. and then maybe hopefully there will be a better Benchlink program and/or also we will have some new equipment by then. Thanks. |
我们正在为34970A / 72A的新BenchVue 2.5版本寻找beta测试客户。
这将取代BenchLink DataLogger软件,并将具有客户要求的许多增强功能以及更好的图形功能。 如果你有兴趣的话,请让我知道。 您可以通过bv_support@keysight.com直接与我联系。 布赖恩 以上来自于谷歌翻译 以下为原文 We are looking for beta test customers for the new BenchVue 2.5 release for the 34970A/72A. This will replace the BenchLink DataLogger software and will have many of the enhancements that customers have requested as well as much better graphing capability. Please let me know if you are interested. You can reach me directly at bv_support@keysight.com. Brian |
我们已将Benchlink 1一直推向Windows 7.哪个程序具有相同的功能。
我们很乐意购买这样的程序。 我正在尝试使用开关卡并使用温度值来控制输出。 Benchlink 1我可以做到这一点,但是Bl 3和BenchVue没有这个功能。 寻求帮助! 以上来自于谷歌翻译 以下为原文 We have pushed Benchlink 1 all the way to windows 7. What program has all the same function. We would be glad to purchase a program like that. I am trying to use the switch card and have a temperature value control the output. Benchlink 1 I can do just that but with Bl 3 and BenchVue do not have that capability. Looking for help! |
旧巷幽草香 发表于 2019-1-4 16:21 你能提供一些关于你想做什么的更多信息吗? 我是BenchVue支持工程师,所以我对BenchLink的了解,特别是ver。 1,是有限的。 你能告诉我其他人缺乏BL1的具体情况吗? 例如,您是指警报还是其他一些控制机制? 你试图控制什么输出? 布赖恩 以上来自于谷歌翻译 以下为原文 Can you provide a little more information about what you are trying to do? I am the BenchVue Support engineer, so my knowledge of BenchLink, especially ver. 1, is limited. Can you tell me what BL1 had that the others are lacking, specifically? For example, are you referring to alarms or some other control mechanism? What output are you trying to control? Brian |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 09:50 , Processed in 1.166357 second(s), Total 75, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
