发 帖
张飞软硬开源基于STM32 BLDC直流无刷电机驱动器开发视频套件, 👉戳此立抢👈
[问答] HP8568B和HP8566的模糊格线问题
114 crt
分享
嗨,我有HP8568B和HP8566A / B,它们都受到模糊格线问题的影响。
即,主要的痕迹是美观,明亮和锐利,但在亮度按钮上的格子“早期出现”,当我的主要痕迹很好,清晰和聚焦时,刻度已经失去焦点。
我知道这是一个常见的问题,许多人说它只是CRT进入老年时期,因为它不能保持长短矢量等的焦点。但有趣的是,格子在较低的强度下看起来很可爱和锐利。
所以我想知道是否有办法改变固件或硬件中的刻度强度。
我可以关闭前面板上的刻度,主迹线保持清晰锐利。
那么有人知道是否有电阻器或微调器设置刻度强度水平?
如果在固件中设置,则可以更改固件以将其关闭一点。
另一件事是,可能有某个组件在某个地方老化并导致格线和主要轨迹之间的这种不平衡。
在此先感谢任何回复:)问候杰里米
以上来自于谷歌翻译
     以下为原文
  Hi
I have an HP8568B and a HP8566A/B and they both suffer slightly from the fuzzy graticule problem.
i.e. the main trace is nice and bright and sharp but the graticule 'comes on early' on the brightness button and by the time I have the main trace nice and clear and focussed, the graticule has gone out of focus.
I know this is a common issue and many say it is just the CRT entering old age as it can't maintain focus for long and short vectors etc. But the interesting thing is that the graticule looks lovely and sharp at a lower intensity.
So I'm left wondering IF there is a way to alter the graticule intensity in the firmware or the hardware. I can turn OFF the graticule on the front panel and the
main trace stays clear and sharp.
So does anyone know if there is a resistor or a trimmer that sets the graticule intensity level? If it is set in the firmware then maybe the firmware can be altered to turn it down a bit. The other thing is that maybe there is a component somewhere that ages and causes this imbalance between the graticule and the main trace.
Thanks in advance for any replies :)
Regards
Jeremy
2019-1-4 15:34:17   评论 分享淘帖 邀请回答
5个回答
一些额外的信息:HP8568B在启动时屏幕上显示7-4-87 HP8566AB在启动时屏幕上显示10-10-89,我认为这些是固件版本的日期。
我有点紧张的关于移除内存芯片以转储ROM所以有人有这些修订的内存内容的hex文件吗?
以上来自于谷歌翻译
     以下为原文
  Some additional Info:
The HP8568B says 7-4-87 on the screen during bootup
The HP8566AB says 10-10-89 on the screen during bootup and I assume these are the dates for the firmware version.
I'm a bit nervous about removing the memory chips to dump the ROM so does anyone have a hex file of the memory contents for these revisions please?
2019-1-4 15:50:18 评论
举报
随着管老化,显示器上的聚焦控制问题很常见。
发生的事情是焦点网格已被氧化,其中你有明亮的焦点和次亮焦点不能一起工作。
当您将强度调低时,子角膜会聚焦,但明亮的痕迹会变暗。
一些人试图通过用CRT再生器燃烧氧化物来使显示器恢复活力,然而,这通常是短暂的。
您可以在线查看本系列的LCD更换套件,这将是您问题的永久解决方案。
以上来自于谷歌翻译
     以下为原文
  The focus control problem on the displays are common as the tubes age.   What has happened is the focus grid has oxidized in which you have both the bright focus and sub-bright focus not working together.   When you turn the intensity down the sub-graticles are focused but the bright trace is dim to see.  Some have tried to rejuvenate the display by flash burning the oxidation with a CRT rejuvenator, however, this is generally short lived.
You can check online for LCD replacement kits for this series that will be a permanent solution to your problem.
2019-1-4 16:05:32 评论
举报
很抱歉找到一个旧帖子但我今天在我的两台分析仪上设法解决了这个问题。
我决定在里面看一看。
在他们两个上都有一些不稳定的电阻导致了这个问题。
现在,CRT迹线和刻度以及文本在两个分析仪上都非常清晰。
之前的8568B格线特别模糊(并且痕迹很暗)但现在分析仪看起来很棒了:)
以上来自于谷歌翻译
     以下为原文
  Sorry to dig up an old post but I managed to cure this issue on both my analysers today. I decided to have a look and play inside them. On both of them there were a couple of erratic resistors that were causing the problem. Now the CRT trace and graticule and text are pin sharp in focus on both analysers. The 8568B graticule was especially fuzzy (and the trace was dim) before but now the analyser looks fabulous again :)
2019-1-4 16:23:42 评论
举报
您好,我知道这是一篇旧帖子,但请您详细说明您做了什么以及您发现哪些部分有缺陷?
Sam W3OHM P.S.
G0HZU我也想对此有所了解,但我还没有找到联系方式。
感谢Yahoo的所有Sam Moderator LeCroy_Owners_Group!
以上来自于谷歌翻译
     以下为原文
  Hello,
I know this is an old post but would you please describe exactly what you did and what parts you found to be defective?
Sam
W3OHM
P.S. G0HZU I would like to have your input on this as well but I have not found a way to contact you.
Thanks to all
Sam
Moderator LeCroy_Owners_Group on Yahoo! Groups
2019-1-4 16:34:36 评论
举报
我决定在里面看一看。
你好,你还记得你改变了哪些电阻来解决焦点问题>谢谢Sam W3OHM
以上来自于谷歌翻译
     以下为原文
  Hello,
Do you remember what resistors you changed to fix the focus problem>
Thank you,
Sam
W3OHM
2019-1-4 16:51:20 评论
举报
只有小组成员才能发言,加入小组>>
35个成员聚集在这个小组
加入小组
创建小组步骤
关闭
站长推荐 上一条 /8 下一条
快速回复 返回顶部 返回列表
