扫一扫,分享给好友
找到一个类似的帖子,要求我们允许java手动连接,但我确实允许java在Windows上自由访问,但是这个安装程序仍然失败...我不知道现在该做什么... 3天后得到一个作业
我甚至无法在我的新电脑上启动vivado!天啊! 以上来自于谷歌翻译 以下为原文 find a similar post to ask us allow java connect manually,but I did allow java to access freely on windows, but this installer still fails...I'm not sure what to do now... got an assignment due 3 days later and I even cannot get vivado started on my new computer!OMG! |
20个回答
@ rass96 @ shanhr @ jellis @ tedd,
感谢您报告此问题,现在已修复。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @rass96 @shanhr @jellis @tedd, Thanks for reporting the issue and it is fixed now. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).View solution in original post |
是啊。
我有同样的问题。 我绝对尝试过一切。 甚至创建了一个新的帐户。 以为它可以释放一个webpack让我得到,但无济于事。 当我试图启动设计套件时,我的麻烦开始了,由于一些微软的视觉工作室协议,它无法加载它。 然后我按照步骤来缓解我在网上找到的这个问题,但没有任何效果。 所以我在计算机上卸载了所有Xilinx,然后尝试重新安装。 什么都行不通。 以上来自于谷歌翻译 以下为原文 Yeah. I'm having this exact same problem. I've tried absolutely everything. Even created a new acct. thinking it might free up a webpack for me to get, but to no avail. My trouble started when I tried to start up the design suite, and it couldn't load it up because of some microsoft visual studio deal. I then followed the steps to mitigate this problem I found online, and nothing worked. So I uninstalled all Xilinx on my computer, and then attempted a reinstall. Nothing works. |
实际上这是我第二次安装这些,第一次在我的旧笔记本电脑上跟随我的教授,一切正常,但这一个,确切的方法,搞砸了。
以上来自于谷歌翻译 以下为原文 actually it's my second time installing these, first time following my professor on my old laptop, everything works fine, but this one, exact approach, screwed up. |
是啊。
我的笔记本电脑上个月没有问题。 Idk这是怎么回事。 以上来自于谷歌翻译 以下为原文 Yeah. Had no problem on my laptop last month. Idk what's up with this. |
我们当中有几个人今天在课堂上也有同样的错误。
希望只是服务器暂时中断。 以上来自于谷歌翻译 以下为原文 A few of us are having the same error in class today too. Hopefully just a server went down temporarily. |
@ rass96 @ shanhr @ sn_hughes,
您是否可以尝试下载单个文件下载zip文件,看看是否可以继续安装? 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @rass96 @shanhr @sn_hughes, Can you try to download the Single File Download zip file and see if you are able to proceed with installation? Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
嗨@ shanhr,
[“实际上这是我第二次安装这些,第一次在我的旧笔记本电脑上跟随我的教授,一切正常,但这一个,确切的方法,搞砸了。”] 由于这工作较早,您现在使用哪台机器和操作系统? 以上来自于谷歌翻译 以下为原文 Hi @shanhr, ["actually it's my second time installing these, first time following my professor on my old laptop, everything works fine, but this one, exact approach, screwed up."] Since this worked earlier, which machine and OS are you using now? |
我的两台笔记本电脑都使用windows10.1,不同之处在于我以前的旧款笔记本电脑从win8.1升级而且最新的笔记本电脑不能正常工作是新安装的原装10.1系统。
以上来自于谷歌翻译 以下为原文 both of my laptops uses windows10.1,the difference is that my old laptop which used to be good was upgraded from win8.1 and the newest one which don't work is an original 10.1system newly installed. |
我只想插手并说我在尝试安装SDx IDE 2016.3时遇到了完全相同的问题。
我正在运行Windows 7 SP1 64位。 我宁愿不必下载那个20 + GB文件,但是如果必须要那样那么哦。 以上来自于谷歌翻译 以下为原文 I just want to drop in and say that I am having the exact same problem when trying to install the SDx IDE 2016.3. I am running Windows 7 SP1 64 bit. I would prefer to not have to download that 20+GB file, but if it has to come to that then oh well. |
我也有同样的问题。
随着所有的软件包。 即便是大人物。 以上来自于谷歌翻译 以下为原文 I am also having that same issue. With all the software packages. Even the big one. |
此外,只是尝试连接到Xilinx信息中心会产生同样的错误。
以上来自于谷歌翻译 以下为原文 Also, just trying to connect to the Xilinx Information Center gives the same error. |
nupurs写道:
@ rass96 @ shanhr @ sn_hughes, 您是否可以尝试下载单个文件下载zip文件,看看是否可以继续安装? 是。 我回家后会尝试这个。 我确实*不*希望下载一个巨大的文件,但如果我必须这样做,我会。 好像我不是唯一有这个问题的人。 以上来自于谷歌翻译 以下为原文 nupurs wrote:Yes. I will try this when I get home. I really do *not* want to have to download a file that huge, but I will if I have to do so. It seems as if I am not the only person with this problem. |
nupurs写道:
@ rass96 @ shanhr @ sn_hughes, 您是否可以尝试下载单个文件下载zip文件,看看是否可以继续安装? 是的,我下班回家时可以尝试这个。 但它似乎并不适合其他人。 以上来自于谷歌翻译 以下为原文 nupurs wrote:Yeah, I can try this when I get home from work. It doesn't appear to be working for other people though. |
我只是再次尝试,终于能够让它工作。
他们必须解决他们自己的问题。 以上来自于谷歌翻译 以下为原文 I just tried again and was finally able to get it working. They must have fixed the problems on their side. |
感谢您报告此问题,现在已修复。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @rass96 @shanhr @jellis @tedd, Thanks for reporting the issue and it is fixed now. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-20 03:56 , Processed in 1.168213 second(s), Total 91, Slave 78 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
