我按照链接和第7.1节http://www.wiki.xilinx.com/reVISION+Getting+Started+Guide+2017.4在zcu102_es2中构建光流示例应用程序。
在这里,我在“创建sdx项目窗口”中选择项目名称并给出下一个。 现在出现平台对话框,但不显示平台。 我只是尝试使用“自定义平台项目”添加。 但它给出的错误是“没有平台可用”。 启动sdx时,它为SDAccel提供许可证错误。 许可是否是平台不可用的问题。 我为SDSoc生成了许可证,但我没有SDAccel的许可证。 如何生成? 请澄清。 我附上了有关此问题的屏幕截图。 提前致谢。 以上来自于谷歌翻译 以下为原文 I follow the link and section 7.1 http://www.wiki.xilinx.com/reVISION+Getting+Started+Guide+2017.4 to build the optical flow sample application in zcu102_es2. In this, I select project name in "create sdx project window" and give next. Now platform dialog appears but no platform is displayed. I just try to add using "Custom platform project". But it is giving error as "No platform available". when launching sdx, It is giving licence error for SDAccel. Whether licensing is the problem for platforms unavailability. I generated license for SDSoc but I dont have license for SDAccel. How It can be generated? Please clarify. I have attached screenshots about this issue. Thanks in Advance. |
2个回答
要了解下载和安装相关信息,请参阅UG1238.https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug1238-sdx-rnil.pdfno可用于SDAccel的EVAL许可证。您可以联系Xilinx FAE / Sales
了解更多信息。 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 To know about download and installation related information please refer UG1238. https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug1238-sdx-rnil.pdf no EVAL license available for SDAccel. You can contact Xilinx FAE/ Sales for more information. Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
嗨@ sankareswari,
似乎SDSoClicense也没有被采用。 你能否附上以下内容: SDSoClicense 输出Tcl命令的xinfo.txt报告report_environment -file xinfo.txt 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @sankareswari, It seems the SDSoC license is also not taken. Can you please attach the following:
Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2162 浏览 7 评论
2605 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2077 浏览 9 评论
3149 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2192 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-23 16:10 , Processed in 1.055338 second(s), Total 74, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
