之前程序是在KEIL5环境下的,运行没有问题;
现在改到IAR8.30环境,配置后编译,有3个告警,如下标黑; Warning[Pa082]: undefined behavior: the order of volatile accesses is undefined in this statement 因为这个是变量相关的,没有处理 //system_LPC17xx.c文件 void SystemCoreClockUpdate (void) /* Get Core Clock Frequency */ { /* Determine clock frequency according to clock register values */ if (((LPC_SC->PLL0STAT >> 24) & 3) == 3) { /* If PLL0 enabled and connected */ switch (LPC_SC->CLKSRCSEL & 0x03) { case 0: /* Int. RC oscillator => PLL0 */ case 3: /* Reserved, default to Int. RC */ SystemCoreClock = (IRC_OSC * ((2 * ((LPC_SC->PLL0STAT & 0x7FFF) + 1))) / (((LPC_SC->PLL0STAT >> 16) & 0xFF) + 1) / ((LPC_SC->CCLKCFG & 0xFF)+ 1)); break; case 1: /* Main oscillator => PLL0 */ SystemCoreClock = (OSC_CLK * ((2 * ((LPC_SC->PLL0STAT & 0x7FFF) + 1))) / (((LPC_SC->PLL0STAT >> 16) & 0xFF) + 1) / ((LPC_SC->CCLKCFG & 0xFF)+ 1)); break; case 2: /* RTC oscillator => PLL0 */ SystemCoreClock = (RTC_CLK * ((2 * ((LPC_SC->PLL0STAT & 0x7FFF) + 1))) / (((LPC_SC->PLL0STAT >> 16) & 0xFF) + 1) / ((LPC_SC->CCLKCFG & 0xFF)+ 1)); break; } } else { switch (LPC_SC->CLKSRCSEL & 0x03) { case 0: /* Int. RC oscillator => PLL0 */ case 3: /* Reserved, default to Int. RC */ SystemCoreClock = IRC_OSC / ((LPC_SC->CCLKCFG & 0xFF)+ 1); break; case 1: /* Main oscillator => PLL0 */ SystemCoreClock = OSC_CLK / ((LPC_SC->CCLKCFG & 0xFF)+ 1); break; case 2: /* RTC oscillator => PLL0 */ SystemCoreClock = RTC_CLK / ((LPC_SC->CCLKCFG & 0xFF)+ 1); break; } } //---------------------------------------------------------------------------------- 下载运行后,前边初始化时没有问题的,每次运行到下边标黑处就卡死了 int main(void) { BSP_Init (); BSP_Start (); OSInit(); Timer0_Init(); OSTaskCreate(LEDON, (void *)0, &stkLEDON[sizeof(stkLEDON)/4-1], 5); OSTaskCreate(LEDOFF, (void *)0, &stkLEDOFF[sizeof(stkLEDOFF)/4-1], 4); OSStart(); } 卡死到下边标黑处 //startup_LPC177x_8x.s文件 PUBWEAK HardFault_Handler SECTION .text:CODE:NOROOT:REORDER(1) HardFault_Handler B HardFault_Handle 有如下提示: Fri Dec 28, 2018 17:15:45: A precise data access error has occurred (CFSR.PRECISERR, BFAR) at data address 0x40034000. |
1个回答
你查了0x40034000这个地址的数据有什么问题吗
3 条评论
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
784 浏览 0 评论
ElfBoard ELF 1板卡-开发板启动后打印random: nonblocking pool is initialized
524 浏览 0 评论
G2D图像处理硬件调用和测试-基于米尔-全志T113-i开发板
3391 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡- 减少uboot阶段的等待时间
1538 浏览 0 评论
嵌入式学习-飞凌ElfBoard ELF 1板卡 - 重新打包文件系统发现ftp无法正常连接
1830 浏览 0 评论
GMT+8, 2024-4-25 01:32 , Processed in 0.771272 second(s), Total 95, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
