#include #define uchar unsigned char ***it RS=P2^0; //必须有,子程序才可调用 ***it RW=P2^1; ***it E=P2^2; ***it led1=P2^3; ***it led2=P2^4; int count,fen,miao,shi,key=0,i,a; voiddelay(unsigned int n) //延时函数 {unsigned int x,y; for(x=0;x for(y=0;y<123;y++);} void write_command(char com) //写命令的子函数 { E=0; RS=0; RW=0; P1=com; E=1; E=0; delay(1); } void write_data(char dat) //写数据的子函数 { E=0; RS=1; RW=0; P1=dat; E=1; E=0; delay(1); } void lcd_initial(void) //lcd初始化 { write_command(0x38); write_command(0x0c); write_command(0x06); delay(1); } void string(uchar position,uchar *s) //显示的子函数 { write_command(position); while(*s>0) {write_data(*s++); delay(1); } } /****************************************** 按键扫描程序 单片机:STC89C52 P2为扫描按键口 S1-4= e7 eb ed ee S5-8= d7 db dd de S9-10= b7 bb bd be S13-16= 77 7b 7d 7e *****************************************/ unsigned char keyscand(void) { unsigned char a,b; P3=0xf0; if((P3&0xf0)!=0xf0) { delay(2); if((P3&0xf0)!=0xf0) { a=P3&0xf0; P3=0x0f; b=P3&0x0f; } } return(a+b); } void main(void) { a=0; led1=0; led2=0; lcd_initial();//初始化调用 EA=1; //总开关 ET0=1; //计数器T0允许中断 TMOD=0x01; //T0方式1 TH1=(65536-50000)/256;//设置我要的实践50ms TL1=(65536-50000)%256; TR0=1; write_command(0x81); write_data('A'); write_command(0x82); write_data('3'); write_command(0x83); write_data('3'); write_command(0x84); write_data('a'); write_command(0x86); write_data('B'); write_command(0x87); write_data('3'); write_command(0x88); write_data('3'); write_command(0x89); write_data('b'); write_command(0xce); write_data('6'); write_command(0xcf); write_data('4'); while(1) { key=keyscand(); //读取返回值 switch(key)//判断键值(那一个键按下) { case0xee: i=0; break; //对键值赋值 case0xde: i=1; break; case0xbe: i=2; break; case0x7e: i=3; break; case0xed: i=4; break; case0xdd: i=5; break; case0xbd: i=6; break; case0x7d: i=7; break; case0xeb: i=8; break; case0xdb: i=9; break; case0xbb: i=10; break; case0x7b: i=11; break; case0xe7: i=12; break; case0xd7: i=13; break; case0xb7: i=14; break; case0x77: i=15; break; } if(fen==15&&shi==0||fen==15&&shi==1||fen==15&&shi==2) { led1=1; } if(i==10) {led1=0; delay(10); } if(fen==30&&shi==0||fen==30&&shi==1||fen==30&&shi==2) {led2=1; } if(i==11) {led2=0; delay(10); } } } voidtimer0() interrupt 1 //中断 { TH1=(65536-50000)/256; TL1=(65536-50000)%256; count++; //设置这个数来控制时间为1S write_command(0xC1); //显示shi的十位 write_data(0x30+shi/10); write_command(0xC2); //显示shi的个位 write_data(0x30+shi%10); string(0xC3,":"); write_command(0xC4); //显示fen的十位 write_data(0x30+fen/10); write_command(0xC5); //显示fen的个位 write_data(0x30+fen%10); string(0xC6,":"); write_command(0xC7); write_data(0x30+miao/10); write_command(0xC8); write_data(0x30+miao%10); if(count==1) //20ms*50=1S {count=0; miao++;} //每秒钟miao+1 if(miao==60) {miao=0; fen++;} //每分钟fen+1 if(fen==60) {fen=0; shi++;} if(shi==24) {shi=0;}}
4个回答
儿科知识了哦
加油了哦,
都需要经验的啊
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
609 浏览 0 评论
【每周推荐】采用11代Intel CPU,基于youyeetoo X1开发板搭建少儿AI智能STEAM积木平台
855 浏览 0 评论
2574 浏览 2 评论
【youyeetoo X1 windows 开发板体验】+ 影音处理和AI模型移植
2274 浏览 5 评论
I.MX6ULL-飞凌 ElfBoard ELF1板卡- 移植zbar的方法
1708 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
5818 浏览 31 评论
GMT+8, 2024-4-25 17:51 , Processed in 0.643015 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
