我正在从Network Analzyer(S21)获取数据,我想绘制它。
我有数据,但我想反转Y轴,在刻度顶部显示0(零),在底部显示2。 是否可以使用X VS Y显示器或VEE中的任何其他显示器。 无需进入matlab路线。 我知道它可以转储到Excel并更改轴参数(我也在做)但我想在VEE前面板上显示数据以用于视觉目的。 我希望图表看起来像这样:Y轴是损耗(dB),X轴是频率(MHz)0。 。 。 。 2 60450 ................................................ .. 64450我目前有这个:2。 。 。 。 0 60450 ................................................ .. 64450感谢Damian Goderich表示感谢 以上来自于谷歌翻译 以下为原文 I am grabbing data from a Network Analzyer (S21) and I want to plot it. I have the data, But I want to reverse the Y-Axis to show 0 (zero) on the top of the scale and 2 on the bottom. Is that possible with the X VS Y Display or any other display in VEE. Without having to go the MATLAB route. I know it can be dumped into Excel and change the axis parameters (which I am also doing) but I would like to display the data on the VEE front panel for visual purpose. I would like the graph to look like this: Y-AXIS is the loss (dB), X-Axis is the frequency (MHz) 0 . . . . 2 60450 .................................................. 64450 I currently have this: 2 . . . . 0 60450 .................................................. 64450 Any input is appreciated Thanks Damian Goderich |
2个回答
您可能已经完成了这项工作,但在我看来,您有几个选项,包括外部或MATLAB图形;
称之为增益(!)并直接使用S21,或者您可以反转数据,然后通过为图表制作自己的标签来“伪造”它。 以上来自于谷歌翻译 以下为原文 You've probably worked this out already but in my view you have a few options, including the external or MATLAB graph; call it gain(!) and use S21 directly or you could invert the data and then 'fake' it by making your own labels for the graph. |
bgvywerq 发表于 2018-12-27 14:58 我最后保留了原始的S21数据,这是负数并绘制它。 0。 。 。 。 -2我只是想用VEE面板上的可视显示/图形保持与Excel数据表相同的比例/格式。 这应该是安捷伦需要在其图表中包含的选项,以便能够像在Excel中一样反转轴/数据。 谢谢你的意见。 以上来自于谷歌翻译 以下为原文 I just ended up keeping the raw S21 data which was negative and plotted it. 0 . . . . -2 I was just trying to keep the Visual Display/graph on the VEE Panel with the same scale/format that the Excel Data sheet had. This should be an option that Agilent needs to include in its graph to be able to reverse the axis/data just like in Excel. Thanks for input. |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 06:26 , Processed in 1.110191 second(s), Total 71, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
