所有,我正在寻找一对2.4毫米NMD耦合器螺母或其零件号。
我怀疑它们在很多平台上很常见。 一个教育组织我的导师已经捐赠了70820a微波过渡分析仪,它缺少耦合器螺母,我想尝试更换它们,所以我可以获得零件编号,图纸,供应商甚至是零件 对真的很有帮助! 谢谢鲍勃 以上来自于谷歌翻译 以下为原文 All, I'm searching for a pair of 2.4mm NMD coupler nuts or the part number thereof. I suspect they are common across a large number of platforms. An educational organization I mentor has been donated a 70820a Microwave Transition Analyzer that is missing the coupler nuts, and I would like to try to replace them, so any leads I can get on a part number, a drawing, a supplier, or even a pair would be really helpful! Thanks Bob |
6个回答
两个人都很奇怪。
你确定它有用吗? 有中心针吗? 你能拍一下这个单位的照片并关闭一下这个港口吗? 以上来自于谷歌翻译 以下为原文 very odd to be missing both. Are you sure it is functional? Is there a center pin? Can you take a picture of the unit and a close up of the port and post it here? |
对不起,我对这一点没有任何线索,也许别人会知道。 以上来自于谷歌翻译 以下为原文 Sorry, I don't have a clue about that one, maybe someone else will know. |
讨厌鬼。 我已经确认线程不是M12x1.5,所以我不知道它们应该是什么。 是否可以拉出库存NMD联轴器螺母而无需完成重新校准/连接器校准? 谢谢,鲍勃 以上来自于谷歌翻译 以下为原文 Drat. I've confirmed that the threads are not M12x1.5, so I've no idea whatsoever what they are supposed to be. Can the stock NMD coupling nuts be pulled off without having to go through a complete re-alignment/connector calibration? Thanks, Bob |
这是你想要的东西这个8720D VNA究竟需要更换什么 - 是可用的部件那个损坏的线程在我的VNA上。
它是3.5毫米NMD而不是2.4毫米,但我怀疑它是相似的。 如该线程中所述,改变该线程需要重新调整以接近公差。 安捷伦引用了大笔资金来解决这个问题。 我忘了确切的金额,但它超过3000英镑,大约5000美元。 一位朋友使用文件为我修复了它 - 类似于Dr_Joel在该帖子中所说的内容。 我有你在那里看到的部分。 如果你愿意,我可以拍照。 尽管已经更换了损坏部件,但由于对齐要求,我没有更换它。 您需要的部件很可能与我的相似,所以如果您想要照片,请告诉我。 以上来自于谷歌翻译 以下为原文 Is this what you want What exactly needs replacing on this 8720D VNA - is the parts available That thread which is damaged is on my VNA. It is 3.5 mm NMD not 2.4 mm, but I suspect it is similar. As noted in that thread, changing that threa requires realignment to close tolerances. Agilent quoted me a huge amount of money to sort that out. I forgot the exact amount but it was over £3000, which is around $5000. A friend fixed it for me using a file - similar to what Dr_Joel said in that thread. I have the part you see there. I could photograph it if you wish. Despite having a replacement for the damaged part, I have not replaced it due to the requirements for alignment. There is a good chance that the part you need is similar to what I have, so if you want a photo let me know. |
60user7 发表于 2018-12-27 13:50 Yup drkirby,就是这样,但2.4mm的变种。 我想我现在看到发生了什么。 可能有人将连接器内部冲洗并将它们拉出来,然后将内部互连硬线电缆从前面拉出。 如果我理解正确的话,我想我可以加工一个可以工作并可以对齐的替代品,但它会很有趣。 可能更容易尝试寻找一些2.4毫米NMD隔板连接器。 多谢你们 以上来自于谷歌翻译 以下为原文 Yup drkirby, that would be it, but the 2.4mm variant. I think I now see what happened. Probably someone hosed the connector innards and pulled them out, then pulled the internal interconnect hardline cables out through the front. If I understand it correctly, I think I can machine up a replacement that will work and can be aligned, but it's going to be fun. Probably easier to try to hunt down some 2.4mm NMD bulkhead connectors. Thanks guys |
阳光790105 发表于 2018-12-27 13:56 我错了这个。 当我找到它时,我会拍照。 戴夫 以上来自于谷歌翻译 以下为原文 I've mislaid this. When I find it, I will photograph it. Dave |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 10:05 , Processed in 5.401956 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
