我的PC上安装了ISE Design Suite 14.7和Vivado 2016.4。
(我保持安装ISE Design Suite 14.7,因为这是我的Spartan-6产品的开发平台.Vivado 2016.4与Spartan-6不兼容。据Xilinx称,Vivado不支持任何早于7系列的设备系列。) 根据以下说明,Xilinx System Generator可以嵌套在ISE Design Suite下。 在我的PC上,Xilinx System Generator嵌套在Vivado下。 可以使用基于Vivado的System Generator来开发ISE系统吗? 或者是否有必须安装到ISE的独立Xilinx系统生成器? 参考:DSP设计流程研讨会Atlys Board(XUP) 验证安装 通过选择开始>所有程序> Xilinx设计工具> ISE Design Suite 14.2>系统生成器> System Generator matlab配置器并选择Matlab 2012a,为Matlab 2012a配置System Generator 选择开始>所有程序> Xilinx设计工具> ISE Design Suite 14.2>系统生成器>系统生成器启动Matlab在matlab命令提示符下输入simulink以调用simulink 我意识到研讨会列出了Matlab2012a。 我安装了Matlab R2016b和Matlab R2017a。 哪一个与Xilinx System Generator兼容? 我是否需要删除所有工具,并从干净安装完整的ISE Design Suite 14.7开始,而不是Web包,并摆脱Matlab R2017a? 以上来自于谷歌翻译 以下为原文 I have ISE Design Suite 14.7 and Vivado 2016.4 installed on my PC. (I'm keeping ISE Design Suite 14.7 installed as that is my development platform for Spartan-6 products. Vivado 2016.4 is not compatible with Spartan-6. According to Xilinx, Vivado will not support any device families older than the 7 series.) According to the instructions below, Xilinx System Generator is found nested under ISE Design Suite. On my PC, the Xilinx System Generator is nested under Vivado. Can the Vivado based System Generator be used to develop systems for ISE? Or is there an independent Xilinx System Generator that must be fitted to ISE? Reference: DSP Design Flow Workshop Atlys Board (XUP)
I realize the workshop lists Matlab2012a. I have Matlab R2016b and Matlab R2017a installed. Which one of these is compatible with Xilinx System Generator? Do I need to delete all the tools, and start with a clean install of a full ISE Design Suite 14.7, not the web pack, and get rid of Matlab R2017a? |
3个回答
您需要分别为ISE和Vivado配置sysgen对于ISE,请参阅此ARs https://www.xilinx.com/support/answers/17966.html对于Vivado,请参阅此ARs https://www.xilinx.com/support/answers/
55830.html 您需要为ISE和Vivado工具分别安装两个matlab版本 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 you need to configure sysgen for ISE and Vivado separately For ISE refer this ARs https://www.xilinx.com/support/answers/17966.html For Vivado refer this ARs https://www.xilinx.com/support/answers/55830.html you need to install two matlab versions separately for ISE and Vivado tools Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我认为另一个问题是我最初安装了Xilinx 14.7 ISE Suite Web Pack。
Web Pack不包括System Generator,对吧? 我卸载了与Xilinx相关的所有内容并安装了ISE Design Suite System Edition。 其中一个弹出窗口说“System Generator目前对[MATLAB]版本R2016b有Beta支持。” 这是正常的吗? 最后,我仍然收到一条错误,上面写着“无法打开用于编写C: Program Files MATLAB R2016b / toolbox / local / classpath.txt.tmp的临时文件。目录可能存在权限问题。” 我注意到的一件事是使用了正斜杠和反斜杠。 该脚本可能混合了Linux和Windows目录链接分配? 您能否推荐一个更好的位置来安装ISE Design Suite? 在C:驱动器而不是Program Files目录? 请参阅附注为PDF文件的注释。 20170630新安装的ISE 14.7.pdf 191 KB 以上来自于谷歌翻译 以下为原文 Another problem I think is that I originally had Xilinx 14.7 ISE Suite Web Pack installed. Web Pack does not include System Generator, right? I uninstalled everything related to Xilinx and installed ISE Design Suite System Edition. One of the pop-up windows said "System Generator currently has Beta support for [MATLAB] version R2016b." Is this normal? At the end, I still got an error that said "Failed to open temporary file for writing C:Program FilesMATLABR2016b/toolbox/local/classpath.txt.tmp. Possible permission problems with directory." One thing I notice is that both front-slash and back-slash are used. The script may be mixing up Linux and Windows directory link assignments? Can you recommend a better location to install ISE Design Suite? On the C: drive and not the Program Files directory? See notes attached as a PDF file. 20170630 new installation of ISE 14.7.pdf 191 KB |
您好
是Web包不包含系统生成器,您需要使用系统版。 任何带有空格和特殊字符的目录路径都可以。 但是你需要安装兼容版本的matlab,ISE14.7支持的最新版本的Matlab是AR17966中提到的R2013b 之后的任何其他版本都不兼容,可能无法正常工作。 R2016b不是14.7的兼容版本。 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 HI Yes web pack doesn't include system generator and you need to use System edition. Any directory path with out spaces and special characters is fine. However you need install compatible versions of matlab the latest version of Matlab that is supported by ISE14.7 is R2013b as mentioned in AR17966 Any other versions later than that are not compatible and may not work. R2016b is not a compatible version for 14.7. Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2163 浏览 7 评论
2605 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2079 浏览 9 评论
3149 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2193 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
424浏览 1评论
1524浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2177浏览 0评论
509浏览 0评论
1641浏览 0评论
GMT+8, 2024-4-25 02:02 , Processed in 1.041450 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
