嗨,我正在考虑设计一个WiFi通信系统来发送和接收来自智能手机等站的信息。我建议使用ATWIN 1500模块。还有另一种选择,比如PIC32 WK。你认为它比以前的模块好吗?PIC32 MZ板的好奇心具有MRF24WG0M模块,但我认为使用该模块不是一个好主意。因为根据下面的线程,该模块没有未来:HTTP://www. McCHIP.COM/FUMMS/M99042.ASPXONE注释欢迎。谢谢。
以上来自于百度翻译 以下为原文 Hi. I am thinking of designing a system with WiFi communication to send and receive information from stations such as smart cell phones. I have been suggested to use the ATWINC1500 module. There is another option like the PIC32WK. Do you think it's better than the previous module? The Curiosity of PIC32MZ board has the MRF24WG0M module, but I think it would not be a good idea to use that module. because according to the following thread, that module has no future: http://www.microchip.com/forums/m999042.aspx Any comment is welcomed. Thanks. |
7个回答
我会使用MRF,但看起来像是ATWIc的未来——不确定原因。还有,网上有一些非常便宜的东西……现在记不起它的名字了。
以上来自于百度翻译 以下为原文 I would have used MRF, but looks like ATWINC is the future - not sure about the reasons why. Also, there's something available on the net for very cheap... can't remember its name now. |
MRF24WG0M不推荐用于新的设计。我要和阿特温一起去。
以上来自于百度翻译 以下为原文 MRF24WG0M is not recommended for new designs. I'd go with ATWIN. |
还有关于PIC32 WK的评论吗?我认为Atmel产品的到来影响了一些MCHP和VICEVESA。我希望SAM32不能取代PIC32。谢谢。
以上来自于百度翻译 以下为原文 And any comments about the PIC32WK? I think that the arrival of Atmel products affected some of MCHP and viceversa. And I hope the SAM32 doesn't replace the PIC32. Thanks |
如果你去了ATWIc,你必须准备要么端口司机到另一个RTOS或坚持FrRetos,我不知道为什么它只在一个RTOS内工作。不管怎样,还有几个其他的嵌入式模块,如中文(非常便宜和FCC认证)的ESP8266,我曾经使用过,没有任何问题,我用它在我的控制板和iOS/ Android应用程序之间发送数据。我个人认为这取决于你的产品需求。
以上来自于百度翻译 以下为原文 If you go for the ATWINC, you must be prepared to either port the driver to another RTOS or stick with freeRTOS, I don't know why it only works inside an RTOS. Anyways there are several other modules with an embedded stack like the chinese (very cheap and FCC certified) ESP8266 which I've used once with no issues whatsoever, I used it to send data between my control board and an iOS/Android app. I personally think it depends on your product needs. |
嗨,PIC32 WK从来没有真正启动…Atmel的收购带来了AtWiC1500和ATAMSW25。所以,如果你想使用PIC32处理器,ATWC1500现在可能是正确的选择,因为它与内部或外部堆栈=和谐(旁路模式)的支持是一致的。
以上来自于百度翻译 以下为原文 Hi, PIC32WK was never really launched...ATMEL acquisition brought ATWINC1500 and also ATSAMW25. So if you want to use a PIC32 processor, the ATWINC1500 is probably the right choice at this time as it is supported in Harmony both with internal or external stack=Harmony (bypass mode) Regards |
我在PIC32 WK中保持了希望,因为它仍然在最新版本的Orth.MCHP中提到,应该指出哪些产品不会继续支持。最坏的事情是设计一个产品,经过测试、批准等,你会发现你的设计的一部分(或所有东西)都有C。不适合新设计和支持的组件已经结束。
以上来自于百度翻译 以下为原文 I kept hope in the PIC32WK because it's still mentioned in the latest version of harmony. MCHP should indicate which products aren't going to continue with the support. The worst thing is to design a product and after tests, approvals, etc, you discover that a part of your design (or everything) has components that aren't recommended for new designs and the support has come to an end. |
只有小组成员才能发言,加入小组>>
4779 浏览 9 评论
1815 浏览 8 评论
1733 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2941 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2043 浏览 5 评论
420浏览 1评论
1101浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
344浏览 0评论
253浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1751浏览 0评论
GMT+8, 2024-3-29 09:24 , Processed in 1.110426 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
