你好,
我在使用Xilinx网站的IP核时遇到了一些问题。 我已经下载了Vivado Webpack,也为此同时下载了IP-Core的许可证。 Vivado Webpack工作正常,但我看不到我下载的IP-Cores。 我只能看到Webpack包含的Cores。 如果我打开IP-Cores的设置并想要添加存储库,我会得到按钮“无IP或接口”。 我究竟做错了什么? 请帮忙。 以上来自于谷歌翻译 以下为原文 Hello, I have some problem to use the IP-Cores from Xilinx Website. I have download the Vivado Webpack, and also the licens for this and in the same time for the IP-Cores. The Vivado Webpack works fine, but I can`t see the IP-Cores i had downloaded. I can only see the of the Webpack included Cores. If I open the settings of the IP-Cores and want to add repository, I get the massage "No IPs or interfaces". What am I doing wrong? Please help. |
8个回答
嗨@ mathias_kotulla1,
请分享Tcl命令的许可文件和输出文件xinfo.txt report_environment -file xinfo.txt 谢谢,Arpan 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @mathias_kotulla1, Please share the license file and output file xinfo.txt of Tcl command report_environment -file xinfo.txt Thanks, Arpan Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
你能否在tcl控制台中找到这个命令并提供env.txt文件: report_environment -file env.txt 另外,你试图使用哪个IP? 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @mathias_kotulla1, Can you please ru n this command in the tcl console and provide the env.txt file: report_environment -file env.txt Also, which Ip are you trying to use? Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
嗨,
我尝试使用“HDMI”和“AVB Endpoint”IP-Core。 如果我打开IP-Cores的设置并想要添加存储库,我会得到按钮“无IP或接口”。 (见图) 我不能上传许可证。 (我收到错误) 我会在哪里找到您需要的报告? 谢谢你的帮助!! 以上来自于谷歌翻译 以下为原文 Hi, I try to use the "HDMI" and "AVB Endpoint" IP-Cores. If I open the settings of the IP-Cores and want to add repository, I get the massage "No IPs or interfaces". (see on picture) I can`t uploaded the licens. (I get an error) Where I will find the reports you need? Thanks for your help!! |
你好@ mathias_kotulla1
你想做什么???? “添加IP存储库”选项用于向Vivado IP目录添加自定义IP。 如果要加载IP许可证,可以使用Vivado License Manager(即Vivado GUI - >帮助 - >管理Xilinx许可证 - > VLM GUI - >加载许可证) 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @mathias_kotulla1 What are you trying to do???? "Add IP repository" option is used to add custom IPs to Vivado IP catalog. If you want to load IP license, you to do it using Vivado License Manager (i.e., Vivado GUI --> help --> Manage Xilinx Licenses --> VLM GUI --> Load License) Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,谢谢你回答,
我已经通过Vivado License Mangager加载了IP-Core,但是我可以在IP目录中找到这个核心。 (见图) 谢谢, 马蒂亚斯 以上来自于谷歌翻译 以下为原文 Hi thanks for you answere, I had load the IP-Core over the Vivado License Mangager, but i can`t find this Cores in the IP-Catalog. (see on picture) Thanks, Mathias |
您好@ mathias_kotulla1
IP核因设备而异。 那么您要定位哪种设备? 您是否检查了您所定位的设备是否受IP支持? 运行以下tcl命令后,还要共享生成的文件:report_environment -file env.txt 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @mathias_kotulla1 IP cores varies from device to device. So which device are you targeting? Did you check whether the device you are targeting is supported by the IP? Also share the generated file after running the following tcl command: report_environment -file env.txt Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
@ mathias_kotulla1,
你是说你加载了自定义IP。 如果是,那么只有在Vivado IP存储库管理器中正确添加IP时,您才会在用户存储库部分下的IP catlog中找到它们。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @mathias_kotulla1, Are you saying you have loaded the custom IP. If Yes, then you will find them in IP catlog under user Repository section only if the IP is properly added in Vivado IP repository Manager. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
嗨,
我想将AVB端点IP核与Eval一起使用。 套件:“智能视觉开发套件” 有一个Xilinx XC7Z015-1CLG485C器件。 是不是可以将此板用于AVB解决方案? 谢谢 马蒂亚斯 以上来自于谷歌翻译 以下为原文 Hi, I want to use the AVB Endpoint IP-Core with the Eval. Kit: "Smart Vision Development Kit" There is an Xilinx XC7Z015-1CLG485C device. it is not possible to use this board for a AVB solution? thanks Mathias |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-20 01:16 , Processed in 0.944447 second(s), Total 80, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
