你好:
我们在配置AD9854工作在ASK模式下,梯形可以正常输出, 矩形输出不了,按程序配置后输出的是正弦波。 给你发的程序UD_CLK都是外部更新的,内部更新的程序我也做了,效果和这个一样。 我们是用FPGA配置的,代码使用verilog实现。 麻烦看哈我是那个寄存器配置的有问题或者那不对,非常感谢。。。。谢谢。。 always @(posedge CLK) if(RST) mst_rst_cnt <= 8'h00; else if(mst_rst_cnt == 8'h13) mst_rst_cnt <= 8'h13; else mst_rst_cnt <= mst_rst_cnt + 1'b1; always@(posedge CLK) if(RST) mst_rst<=1'b0; else if(mst_rst_cnt >= 8'h01 && mst_rst_cnt <= 8'h12) mst_rst<=1'b1; else mst_rst<=1'b0; always@(posedge CLK) if(RST) mst_rst_ok <= 1'b0; else if(mst_rst_cnt > 8'h12) mst_rst_ok <= 1'b1; else; // ----------------------------------------------------- reg [1:0] wrb_cnt; always@(posedge CLK) if(RST) wrb_cnt <= 2'b00; else if(ad_9854_init_ok) wrb_cnt <= 2'b00; else if(mst_rst_ok) wrb_cnt <= wrb_cnt + 1'b1; else; assign wrb = wrb_cnt[1]; // ---------------------------------------------------- always@(posedge CLK) if(RST) ctrl_cnt <= 8'h0; else if(mst_rst_ok) if(ctrl_cnt == 8'd49) ctrl_cnt <= 8'd49; else if(wrb_cnt == 2'b00) ctrl_cnt <= ctrl_cnt+ 1'b1; else; else; always@(posedge CLK) if(RST) io_ud <= 1'b0; else if(ctrl_cnt== 8'd40) io_ud <= 1'b1; else if(ctrl_cnt== 8'd48) io_ud <= 1'b0; else; always@(posedge CLK) if(RST) ad_9854_init_ok <= 1'b0; else if(ctrl_cnt== 8'd48) ad_9854_init_ok <= 1'b1; else; // --------------- 输出 AD_FSK_BPSK_HOLD 信号-------------------------- // 0 --- FTW1; 1 --- FTW2; always@(posedge CLK) // 25M if(RST) fsk_div_cnt <= 16'h0; else if(ad_9854_init_ok) if(fsk_div_cnt == SPEED_DELAY_CNT) fsk_div_cnt <= 16'h0; else fsk_div_cnt <= fsk_div_cnt + 1'b1; else fsk_div_cnt <= 16'h0; // 0 --- FTW1; 1 --- FTW2; always@(posedge CLK) if(RST) need_mod_out <= 1'b1; else if(fsk_div_cnt > SPEED_DELAY_DIVID2) need_mod_out <= 1'b1; else need_mod_out <= 1'b0; // ----------------------------------------------------------------------- ///* always@(posedge CLK) if(RST) state <= 20'h0; else state <= state + 1'b1; assign ask_out_range = 16'h0FF0; assign AD_SHAPEDK = state[19]; // ----------------------------------------------------------------------- // FSK F1 = 70.5M F2 = 69.5M always@(posedge CLK) if(RST) address <=6'b00_0000; else if(mst_rst_ok) case(ctrl_cnt) // ************** 写寄存器 *********************** // FTW1 8'd2 : address <= 6'b00_0100; //0x04 FTW1_5 8'd3 : address <= 6'b00_0101; //0x05 FTW1_4 8'd4 : address <= 6'b00_0110; //0x06 FTW1_3 8'd5 : address <= 6'b00_0111; //0x07 FTW1_2 8'd6 : address <= 6'b00_1000; //0x08 FTW1_1 8'd7 : address <= 6'b00_1001; //0x09 FTW1_0 // 输出幅度乘法器 8'd8 : address <= 6'b10_0001; //0x21 8'd9 : address <= 6'b10_0010; //0x22 8'd10 : address <= 6'b10_0011; //0x23 8'd11 : address <= 6'b10_0100; //0x24 // 写控制寄存器 8'd14 : address <= 6'b01_1101; //0x1D 8'd15 : address <= 6'b01_1110; //0x1E 配置PLL时钟 8'd16 : address <= 6'b01_1111; //0x1F 8'd17 : address <= 6'b10_0000; //0x20 // 输出边沿变化率控制器 //8'd19 : address <= 6'b10_0101; //0x25 default:address <= 6'b00_0000; endcase else; always@(posedge CLK) if(RST) data <=8'b1111_1011; else if(mst_rst_ok) case(ctrl_cnt) // FTW1 8'd2 : data <= FTW1[47:40]; //0x04 FTW1_5 8'd3 : data <= FTW1[39:32]; //0x05 FTW1_4 8'd4 : data <= FTW1[31:24]; //0x06 FTW1_3 8'd5 : data <= FTW1[23:16]; //0x07 FTW1_2 8'd6 : data <= FTW1[15:8]; //0x08 FTW1_1 8'd7 : data <= FTW1[7:0]; //0x09 FTW1_0 // 输出幅度乘法器 8'd8 : data <= ask_out_range[15:8];//0x21 8'd9 : data <= ask_out_range[7:0]; //0x22 8'd10 : data <= 8'h0;//0x23 8'd11 : data <= 8'h0; //0x24 // 写控制寄存器 输出梯形的ASK调制模式 8'd14 : data <= 8'h10; //0x1D 8'd15 : data <= 8'h47; //0x1E 配置PLL时钟 280M 8'd16 : data <= 8'h00; //0x1F single tone 外部更新 8'd17 : data <= 8'h70; //0x20 // 输出边沿变化率控制器 //8'd19 : data <= 8'h03; //0x25 // OSK RAMP rate控制字来决定从0幅度到满幅度的转换时间, // 控制子最小只能到0x03,再小就不能正常输出波形。 // 写控制寄存器 输出矩形的ASK调制模式 //8'd14 : data <= 8'h14; //0x1D //8'd15 : data <= 8'h47; //0x1E 配置PLL时钟 280M //8'd16 : data <= 8'h01; //0x1F single tone 外部更新 //8'd17 : data <= 8'h60; //0x20 default:data <= 8'h00; endcase else; 矩形输出不了,按程序配置后输出的是正弦波。(相同部分的程序就不贴了,矩形和梯形相比只是更改了0x20寄存器的配置) always@(posedge CLK) if(RST) address <=6'b00_0000; else if(mst_rst_ok) case(ctrl_cnt) // ************** 写寄存器 *********************** // FTW1 8'd2 : address <= 6'b00_0100; //0x04 FTW1_5 8'd3 : address <= 6'b00_0101; //0x05 FTW1_4 8'd4 : address <= 6'b00_0110; //0x06 FTW1_3 8'd5 : address <= 6'b00_0111; //0x07 FTW1_2 8'd6 : address <= 6'b00_1000; //0x08 FTW1_1 8'd7 : address <= 6'b00_1001; //0x09 FTW1_0 // 输出幅度乘法器 8'd8 : address <= 6'b10_0001; //0x21 8'd9 : address <= 6'b10_0010; //0x22 8'd10 : address <= 6'b10_0011; //0x23 8'd11 : address <= 6'b10_0100; //0x24 // 写控制寄存器 8'd14 : address <= 6'b01_1101; //0x1D 8'd15 : address <= 6'b01_1110; //0x1E 配置PLL时钟 8'd16 : address <= 6'b01_1111; //0x1F 8'd17 : address <= 6'b10_0000; //0x20 default:address <= 6'b00_0000; endcase else; always@(posedge CLK) if(RST) data <=8'b1111_1011; else if(mst_rst_ok) case(ctrl_cnt) // FTW1 8'd2 : data <= FTW1[47:40]; //0x04 FTW1_5 8'd3 : data <= FTW1[39:32]; //0x05 FTW1_4 8'd4 : data <= FTW1[31:24]; //0x06 FTW1_3 8'd5 : data <= FTW1[23:16]; //0x07 FTW1_2 8'd6 : data <= FTW1[15:8]; //0x08 FTW1_1 8'd7 : data <= FTW1[7:0]; //0x09 FTW1_0 // 输出幅度乘法器 8'd8 : data <= ask_out_range[15:8];//0x21 8'd9 : data <= ask_out_range[7:0]; //0x22 8'd10 : data <= 8'h0;//0x23 8'd11 : data <= 8'h0; //0x24 // 写控制寄存器 输出矩形的ASK调制模式 8'd14 : data <= 8'h14; //0x1D 8'd15 : data <= 8'h47; //0x1E 配置PLL时钟 280M 8'd16 : data <= 8'h00; //0x1F single tone 外部更新 8'd17 : data <= 8'h60; //0x20 default:data <= 8'h00; endcase else; 给你发的程序UD_CLK都是外部更新的,内部更新的程序我也做了,效果和这个一样。 我们是用FPGA配置的,代码使用verilog实现。 麻烦看哈我是那个寄存器配置的有问题或者那不对,非常感谢。。。。谢谢。。 |
1个回答
请问正弦波输出的幅度由多大?改变REG0x21~0x22是否能否改变输出幅度?OSK引脚输入信号波形是否是想要的波形?
只有小组成员才能发言,加入小组>>
ADP5092 SYS端口为2.09V,但是REG_OUT为0是什么原因?
1290 浏览 1 评论
ad7193差分输入ain1与ain2差是正值时,读到电压与实际值误差小,但为负值值,误差就变的很大
3917 浏览 2 评论
8574 浏览 1 评论
2914 浏览 1 评论
6703 浏览 2 评论
ADC3442采集,分析数据出现有规则毛刺,请问是哪方面的问题啊?
699浏览 3评论
AD7190状态寄存器一直是0x80,连续转换模式下RDY不拉低
1023浏览 2评论
3917浏览 2评论
938浏览 2评论
722浏览 1评论
GMT+8, 2024-4-21 00:18 , Processed in 0.634123 second(s), Total 71, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
