发 帖
原厂入驻New
实战多通道高速精密测温仪的全系列设计教程,以实际项目为依托,提升工程师核心竞争力!→点击立即抢购←
[问答] 无法在Windows10上启动Vivado 2016.1
147 xilinx vivado Windows10
分享
单击“开始”菜单中的“Vivado 2016.1”按钮后:
然后我点击修复,然后:
但事情并没有好转,因为Vivado没有按照应有的方式发布,相反,几秒钟之后,这就出现了:
经过多次尝试但只得到了相同的结果,Itried在启动Vivado之前运行C:\ Xilinx \ Vivado \ 2016.1 \ tps \ win64 \ vcredist_x64.exe,然而,没有任何改变。
希望有人能帮帮我。谢谢你。
附:
这个问题出现在我大约两周前升级Windows 10之后。
在此之前,一切都很精细。
我当时正在Win10上使用Vivado 2015.4。今天我安装了Vivado 2016.1,看看这个问题是否能够解决,但........帮助。
以上来自于谷歌翻译
以下为原文
After clicking the button " Vivado 2016.1" in Start Menu :
then I click Repair, and :
But things did not get better because Vivado didn't launch as it should be, instead, several second later, this come :
After many times trying but only got the same result, I tried to run C:\Xilinx\Vivado\2016.1\tps\win64\vcredist_x64.exe before launching Vivado, however, nothing changed.
Hope someone could help me out.Thanks a lot.
P.s. this issue come out after I updeted Windows 10 about 2 weeks ago. Before that, everything was fine.
I was using Vivado 2015.4 on Win10 at that time. Today I instalLED Vivado 2016.1 to see whether this problem be solved but........help.
2018-12-21 11:02:24   评论 分享淘帖 邀请回答
4个回答
请确保您满足软件要求。
如果默认启用,则禁用Web Talk数据。
请查看这些ARshttp://www.xilinx.com/support/answers/59304.htmlhttp://www.xilinx.com/support/answers/56148.html
谢谢和RegardsBalkrishan -----------------------------------------------
---------------------------------------------请将帖子标记为
一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。
以上来自于谷歌翻译
以下为原文
please make sure you are fulfilling the software requirement. Disable web talk data if enabled by default.
Check these ARs
Thanks and Regards
Balkrishan
Please mark the post as an answer "Accept as solution" in case it helped resolve your query.
Give kudos in case a post in case it guided to the solution.
2018-12-21 11:21:39 评论
举报
在微软的最新更新(2016年6月25日前一周)之后,我收到同样的消息。
它在更新之前有效。
谁有运气?
以上来自于谷歌翻译
以下为原文
I'm getting the same message, following microsoft's latest update (week before 6/25/2016).
It worked before the update.
anyone having any luck?
2018-12-21 11:35:31 评论
举报
嗨@ severusitach,
您是否可以尝试删除2012年之后发布的Microsoft可再发行组件?保留Microsoft Visual C ++ 2012 Redistributable(x64)并删除2013或2015版本(如果有)。
谢谢,Nupur -----------------------------------------------
--------------------------------------------- Google在发布之前提问
如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。
以上来自于谷歌翻译
以下为原文
Hi @severusitach,
Can you try removing the Microsoft redistributables that came after 2012?
Keep Microsoft Visual C++ 2012 Redistributable(x64) and delete the 2013 or 2015 version if you have them.
Thanks,
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).
2018-12-21 11:41:09 评论
举报
我终于能够通过将xvcredist.exe重命名为xvcredist_save.exe来运行vivado 2016.1,从而有效地隐藏它。
此文件位于C:\ Xilinx \ Vivado \ 2016.1 \ tps \ win64中
以上来自于谷歌翻译
以下为原文
I was finally able to get vivado 2016.1 running by renaming xvcredist.exe to xvcredist_save.exe, effectively hiding it.
This file is in  C:\Xilinx\Vivado\2016.1\tps\win64
2018-12-21 11:50:52 评论
举报
只有小组成员才能发言,加入小组>>
36个成员聚集在这个小组
加入小组
创建小组步骤
关闭
站长推荐 上一条 /10 下一条
快速回复 返回顶部 返回列表
