这个模块用于完成程序中所有有关寄存器的操作,代码如下:
- always @ (posedge clk)
- begin
- tx_successful_q <=#Tp tx_successful;
- overrun_q <=#Tp overrun;
- transmit_buffer_status_q <=#Tp transmit_buffer_status;
- info_empty_q <=#Tp info_empty;
- error_status_q <=#Tp error_status;
- node_bus_off_q <=#Tp node_bus_off;
- node_error_passive_q <=#Tp node_error_passive;
- end
- //模式寄存器
- wire [0:0] mode;
- wire [4:1] mode_basic;
- wire [3:1] mode_ext;
- wire receive_irq_en_basic;
- wire transmit_irq_en_basic;
- wire error_irq_en_basic;
- wire overrun_irq_en_basic;
- can_register_asyn_syn #(1, 1'h1) MODE_REG0
- ( .data_in(data_in[0]),
- .data_out(mode[0]),
- .we(we_mode),
- .clk(clk),
- .rst(rst),
- .rst_sync(set_reset_mode)
- can_register_asyn #(4, 0) MODE_REG_BASIC
- ( .data_in(data_in[4:1]),
- .data_out(mode_basic[4:1]),
- .we(we_mode),
- .clk(clk),
- .rst(rst)
- can_register_asyn #(3, 0) MODE_REG_EXT
- ( .data_in(data_in[3:1]),
- .data_out(mode_ext[3:1]),
- .we(we_mode & reset_mode),
- .clk(clk),
- .rst(rst)
- //命令寄存器
- wire [4:0] command;
- can_register_asyn_syn #(1, 1'h0) COMMAND_REG0
- .data_out(command[0]),
- .we(we_command),
- .clk(clk),
- .rst(rst),
- .rst_sync(tx_request & sample_point)
- can_register_asyn_syn #(1, 1'h0) COMMAND_REG1
- ( .data_in(data_in[1]),
- .data_out(command[1]),
- .we(we_command),
- .clk(clk),
- .rst(rst),
- .rst_sync(abort_tx & ~transmitting)
- can_register_asyn_syn #(2, 2'h0) COMMAND_REG
- ( .data_in(data_in[3:2]),
- .data_out(command[3:2]),
- .we(we_command),
- .clk(clk),
- .rst(rst),
- .rst_sync(|command[3:2])
- can_register_asyn_syn #(1, 1'h0) COMMAND_REG4
- ( .data_in(data_in[4]),
- .data_out(command[4]),
- .we(we_command),
- .clk(clk),
- .rst(rst),
- .rst_sync(tx_successful & (~tx_successful_q) | abort_tx)
- assign self_rx_request = command[4] & (~command[0]);
- assign clear_data_overrun = command[3];
- assign release_buffer = command[2];
- assign abort_tx = command[1] & (~command[0]) & (~command[4]);
- assign tx_request = command[0] | command[4];
- always @ (posedge clk or posedge rst)
- begin
- if (rst)
- single_shot_transmission <= 1'b0;
- else if (we_command & data_in[1] & (data_in[1] | data_in[4]))
- single_shot_transmission <=#Tp 1'b1;
- else if (tx_successful & (~tx_successful_q))
- single_shot_transmission <=#Tp 1'b0;
- end
- //状态寄存器
- wire [7:0] status;
- assign status[7] = node_bus_off;
- assign status[6] = error_status;
- assign status[5] = transmit_status;
- assign status[4] = receive_status;
- assign status[3] = transmission_complete;
- assign status[2] = transmit_buffer_status;
- assign status[1] = overrun_status;
- assign status[0] = receive_buffer_status;
- begin
- if (rst)
- transmission_complete <= 1'b1;
- else if (tx_successful & (~tx_successful_q) | abort_tx)
- transmission_complete <=#Tp 1'b1;
- else if (tx_request)
- transmission_complete <=#Tp 1'b0;
- end
- begin
- if (rst)
- transmit_buffer_status <= 1'b1;
- transmit_buffer_status <=#Tp 1'b0;
- else if (~need_to_tx)
- transmit_buffer_status <=#Tp 1'b1;
- end
- begin
- if (rst)
- overrun_status <= 1'b0;
- else if (overrun & (~overrun_q))
- overrun_status <=#Tp 1'b1;
- else if (clear_data_overrun)
- overrun_status <=#Tp 1'b0;
- end
- begin
- if (rst)
- receive_buffer_status <= 1'b0;
- else if (release_buffer)
- receive_buffer_status <=#Tp 1'b0;
- else if (~info_empty)
- receive_buffer_status <=#Tp 1'b1;
- end
- //总线时序寄存器 1
- wire [7:0] bus_timing_0;
- can_register #(8) BUS_TIMING_0_REG
- ( .data_in(data_in),
- .data_out(bus_timing_0),
- .we(we_bus_timing_0),
- .clk(clk)
- assign baud_r_presc = bus_timing_0[5:0];
- assign sync_jump_width = bus_timing_0[7:6];
- //总线时序寄存器 2
- wire [7:0] bus_timing_1;
- can_register #(8) BUS_TIMING_1_REG
- .data_out(bus_timing_1),
- .we(we_bus_timing_1),
- .clk(clk)
- assign time_segment1 = bus_timing_1[3:0];
- assign time_segment2 = bus_timing_1[6:4];
- assign triple_sampling = bus_timing_1[7];
- //错误提示寄存器
- can_register_asyn #(8, 96) ERROR_WARNING_REG
- .data_out(error_warning_limit),
- .we(we_error_warning_limit),
- .clk(clk),
- .rst(rst)
- //时钟分频寄存器
- wire [7:0] clock_divider;
- wire clock_off;
- wire [2:0] cd;
- reg [2:0] clkout_div;
- reg [2:0] clkout_cnt;
- reg clkout_tmp;
- //reg clkout;
- can_register #(1) CLOCK_DIVIDER_REG_7
- ( .data_in(data_in[7]),
- .data_out(clock_divider[7]),
- .we(we_clock_divider_hi),
- .clk(clk)
- assign clock_divider[6:4] = 3'h0;
- can_register #(1) CLOCK_DIVIDER_REG_3
- ( .data_in(data_in[3]),
- .data_out(clock_divider[3]),
- .clk(clk)
- can_register #(3) CLOCK_DIVIDER_REG_LOW
- ( .data_in(data_in[2:0]),
- .data_out(clock_divider[2:0]),
- .we(we_clock_divider_low),
- .clk(clk)
- assign extended_mode = clock_divider[7];
- assign clock_off = clock_divider[3];
- assign cd[2:0] = clock_divider[2:0];
- always @ (cd)
- begin
- case (cd) // synopsys_full_case synopsys_paralel_case
- 3'b000 : clkout_div <= 0;
- 3'b001 : clkout_div <= 1;
- 3'b010 : clkout_div <= 2;
- 3'b011 : clkout_div <= 3;
- 3'b100 : clkout_div <= 4;
- 3'b101 : clkout_div <= 5;
- 3'b110 : clkout_div <= 6;
- 3'b111 : clkout_div <= 0;
- endcase
- end
- begin
- if (rst)
- clkout_cnt <= 3'h0;
- else if (clkout_cnt == clkout_div)
- clkout_cnt <=#Tp 3'h0;
- else
- clkout_cnt <= clkout_cnt + 1'b1;
- end
- begin
- if (rst)
- clkout_tmp <= 1'b0;
- clkout_tmp <=#Tp ~clkout_tmp;
- end
- always @ (cd or clkout_tmp or clock_off)
- begin
- if (clock_off)
- clkout <=#Tp 1'b1;
- else
- clkout <=#Tp clkout_tmp;
- end
- assign clkout = clock_off ? 1'b1 : ((&cd)? clk : clkout_tmp);
- //从寄存器中读数据
- always @ ( addr or read or extended_mode or mode or bus_timing_0 or bus_timing_1 or clock_divider
- or
- acceptance_code_0 or acceptance_code_1 or acceptance_code_2 or acceptance_code_3
- or
- acceptance_mask_0 or acceptance_mask_1 or acceptance_mask_2 or acceptance_mask_3
- or
- reset_mode or tx_data_0 or tx_data_1 or tx_data_2 or tx_data_3 or tx_data_4 or
- tx_data_5 or tx_data_6 or tx_data_7 or tx_data_8 or tx_data_9 or status or
- error_warning_limit or rx_err_cnt or tx_err_cnt or irq_en_ext or irq_reg or
- mode_ext or
- arbitration_lost_capture or rx_message_counter or mode_basic or
- error_capture_code
- begin
- if(read) // read
- begin
- if (extended_mode) // EXTENDED mode (Different register map depends on mode)
- begin
- case(addr)
- 8'd0 : data_out_tmp <= {4'b0000, mode_ext[3:1], mode[0]};
- 8'd1 : data_out_tmp <= 8'h0;
- 8'd2 : data_out_tmp <= status;
- 8'd3 : data_out_tmp <= irq_reg;
- 8'd4 : data_out_tmp <= irq_en_ext;
- 8'd6 : data_out_tmp <= bus_timing_0;
- 8'd7 : data_out_tmp <= bus_timing_1;
- 8'd11 : data_out_tmp <= {3'h0, arbitration_lost_capture[4:0]};
- 8'd12 : data_out_tmp <= error_capture_code;
- 8'd13 : data_out_tmp <= error_warning_limit;
- 8'd14 : data_out_tmp <= rx_err_cnt;
- 8'd15 : data_out_tmp <= tx_err_cnt;
- 8'd16 : data_out_tmp <= acceptance_code_0;
- 8'd17 : data_out_tmp <= acceptance_code_1;
- 8'd18 : data_out_tmp <= acceptance_code_2;
- 8'd19 : data_out_tmp <= acceptance_code_3;
- 8'd20 : data_out_tmp <= acceptance_mask_0;
- 8'd21 : data_out_tmp <= acceptance_mask_1;
- 8'd22 : data_out_tmp <= acceptance_mask_2;
- 8'd23 : data_out_tmp <= acceptance_mask_3;
- 8'd24 : data_out_tmp <= 8'h0;
- 8'd25 : data_out_tmp <= 8'h0;
- 8'd26 : data_out_tmp <= 8'h0;
- 8'd27 : data_out_tmp <= 8'h0;
- 8'd28 : data_out_tmp <= 8'h0;
- 8'd29 : data_out_tmp <= {1'b0, rx_message_counter};
- 8'd31 : data_out_tmp <= clock_divider;
- default: data_out_tmp <= 8'h0;
- endcase
- end
- else // BASIC mode
- begin
- case(addr)
- 8'd0 : data_out_tmp <= {3'b001, mode_basic[4:1], mode[0]};
- 8'd1 : data_out_tmp <= 8'hff;
- 8'd3 : data_out_tmp <= {4'hf, irq_reg[3:0]};
- 8'd4 : data_out_tmp <= reset_mode? acceptance_code_0 : 8'hff;
- 8'd5 : data_out_tmp <= reset_mode? acceptance_mask_0 : 8'hff;
- 8'd6 : data_out_tmp <= reset_mode? bus_timing_0 : 8'hff;
- 8'd7 : data_out_tmp <= reset_mode? bus_timing_1 : 8'hff;
- 8'd10 : data_out_tmp <= reset_mode? 8'hff : tx_data_0;
- 8'd11 : data_out_tmp <= reset_mode? 8'hff : tx_data_1;
- 8'd12 : data_out_tmp <= reset_mode? 8'hff : tx_data_2;
- 8'd13 : data_out_tmp <= reset_mode? 8'hff : tx_data_3;
- 8'd14 : data_out_tmp <= reset_mode? 8'hff : tx_data_4;
- 8'd15 : data_out_tmp <= reset_mode? 8'hff : tx_data_5;
- 8'd16 : data_out_tmp <= reset_mode? 8'hff : tx_data_6;
- 8'd17 : data_out_tmp <= reset_mode? 8'hff : tx_data_7;
- 8'd18 : data_out_tmp <= reset_mode? 8'hff : tx_data_8;
- 8'd19 : data_out_tmp <= reset_mode? 8'hff : tx_data_9;
- endcase
- end
- end
- else
- data_out_tmp <= 8'h0;
- end
- begin
- if (rst)
- data_out <= 0;
- else if (read)
- data_out <=#Tp data_out_tmp;
- end
复制代码
2018-12-20 11:34:59
淘帖0
