大家好,我想用34410A测量电阻(2线),我希望尽可能快地记录数据,那么如何在1秒内记录超过几千个数据。
我可以使用intuilink软件,还是必须对设备进行编程? 你能否告诉我如何设置34410A以获得每秒10,000次的速度? 非常感谢Alex 以上来自于谷歌翻译 以下为原文 Hi All, I want to measure resistor (2 wire) with 34410A ,and I hope to record the data as faster as possible ,so how can i record more than several thousands data in 1 second. Can I use the intuilink software , or must I program the device? and could you kindly tell me how to set 34410A to get 10,000 times per second speed? thanks a lot Alex |
1个回答
您好,以下是为了通过远程接口实现最大读取速度所需的一般SCPI命令:“conf:res 1000”定义测量的正确范围,1000欧姆纯粹是填充“形式:数据真实,32
“格式化数据,使其通过二进制文件通过总线发送”sense:res:nplc .001“设置最小测量的最小NPLC”sens:res:零:自动关闭“关闭Autozero”disp off“关闭显示 (产生一个最小的差异,我认为这是可选的)“trig:del 0”将触发延迟设置为0“samp:count 50000”或者你想要的读数,再次50000只是这个例子的填充物“trig:sour imm “将您的触发源设置为您想要的功能,我立即使用”init; * wai“使仪器等待触发状态,一接收就会触发。 * wai在处理下一个命令之前完成仪器“data:remove?50000”从仪器中删除读数,数据作为二进制块返回有几个不同的程序可用于编程设备,Matlab,C ++,VEE,C# ,VB.net等...如果你没有偏好,我建议你尝试使用命令专家工具。 www.agilent.com/find/commandexpert如果您不想编程,可以使用内置的网络gui,只需在您的网络浏览器中输入您的仪器的IP地址即可启动gui。 请参阅附件最后一个选项是新的DMM连接实用程序,并使用数字化模式。 我不确定这个实用程序允许你走多快,你可能能够达到全速,还没有尝试过。 http://www.agilent.com/find/DMMUtilitysoftware 以上来自于谷歌翻译 以下为原文 Hello, Here is the general SCPI comands you need in order to achieve the max read speed over a remote interface: "conf:res 1000" define the correct range for your measurement, 1000 ohms is purely a filler "form:data real,32" Format the data so it is sent over the bus via binary "sense:res:nplc .001" Set the minimum NPLC for fastest measurements "sens:res:zero:auto off" Turn off Autozero "disp off" Turn off the display (makes a minimal difference I would consider this optional) "trig:del 0" Set the trigger delay to 0 "samp:count 50000" Or your desired number of readings, again 50000 is just a filler for this example "trig:sour imm" Set your trigger source to your desired function, I used immediate "init;*wai" Puts the instrument in a wait for trigger state, will trigger as soon as one is received. *wai makes the instrument finish before processing next command "data:remove? 50000" Remove readings from the instrument, data comes back as a binary block There are several different programs you could use to program the device, Matlab, C++ , VEE, C#, VB.net, etc... If you don't have a preference, I suggest you try using the command expert tool. www.agilent.com/find/commandexpert If you don't want to program at all you can use the built in web gui, just type in the IP address of your instrument into your web browser to pull up the gui. See attached The last option is the new DMM connectivity utility, and use the digitizing mode. I'm not sure how fast this utility will allow you to go, you may be able to achive full speed, haven't tried it yet. http://www.agilent.com/find/DMMUtilitysoftware 附件
只有小组成员才能发言,加入小组>>
2097 浏览 1 评论
1854 浏览 1 评论
1713 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2257浏览 0评论
GMT+8, 2024-4-24 22:12 , Processed in 1.137875 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
