当我试图在Ubuntu的Synplify中调用xilinx for P& R时,它说XILINX变量尚未设置。
我把它分配到vivado中的bin文件夹,但似乎是错误的。 看起来Synplify使用它来查找xtclsh,这是我在vivado中找不到的。 那么,对于ISE和vivado,XILINX应该分别引用哪些文件夹? 以上来自于谷歌翻译 以下为原文 When I was trying to call xilinx for P&R in Synplify in Ubuntu, it said the XILINX variable had not been set. I assigned it to the bin folder in vivado, but it seems to be wrong. It looks like Synplify uses it to find xtclsh, which I can't find in vivado. So, for both ISE AND vivado, which folders should XILINX refer to, separately? |
4个回答
xtclsh是一个ISE shell - 它不是Vivado的一部分。
因此,如果Synplify试图调用xtclsh并且您希望使用Vivado,那么您的Synplify设置就会出现问题。 Avrum 以上来自于谷歌翻译 以下为原文 xtclsh is an ISE shell - it is not part of Vivado. So if Synplify is trying to invoke xtclsh and you are expecting to use Vivado, then there is something messed up about your Synplify setup. Avrum |
最简单的方法是从Vivado安装运行settings64.sh脚本 检查此文件夹,即C: Xilinx Vivado 2016.2 参考此AR http://www.xilinx.com/support/answers/47821.htm 检查这些链接 http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_2/iil.pdf https://forums.xilinx.com/t5/Installation-and-Licensing/RHEL5-64-bit-ISE-13-1-Environment-Variable-setup/td-p/148454 升 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 The easiest way is to run the settings64.sh script from Vivado installation check this folder i.e. C:XilinxVivado2016.2 Refer this ARs http://www.xilinx.com/support/answers/47821.htm check these links http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_2/iil.pdf https://forums.xilinx.com/t5/Installation-and-Licensing/RHEL5-64-bit-ISE-13-1-Environment-Variable-setup/td-p/148454 l Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我正在运行synplify J-2015.03。
是否意味着此版本不支持vivado? 我转向ISE,但仍然找不到xtclsh ...... 以上来自于谷歌翻译 以下为原文 I'm running synplify J-2015.03. Does it mean vivado is not supported by this version? I turned to ISE, but still could not find xtclsh... |
我检查了settings64.sh。
它的工作似乎是将安装目录添加到PATH,而synplify则要求XILINX。 在您给出的第3个链接中,op使用xinfo来获取XILINX的值。 我不知道如何运行xinfo,但试图在Windows中运行它,在输出文件中它指向两个目录: -------------------------------------- 赛灵思 13.2 ISE_DS 常见 和 赛灵思 13.2 ISE_DS ISE BIN -------------------------------------- 所以我在Ubuntu中添加了这样的定义,并执行了settings64.sh,但在synplify中的P& R中仍然失败了: 以上来自于谷歌翻译 以下为原文 I checked settings64.sh. It's job seems to be adding the installation directory to PATH, whereas synplify asks for XILINX. In the 3rd link you gave, the op uses xinfo to get the value of XILINX. I have no idea how to run xinfo, but tried to run it in windows, and in the output file it points to two directories: -------------------------------------- Xilinx13.2ISE_DScommon and Xilinx13.2ISE_DSISEbin -------------------------------------- So I added such definition in Ubuntu, and executed settings64.sh, but still failed in P&R in synplify: |
只有小组成员才能发言,加入小组>>
2163 浏览 7 评论
2606 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2079 浏览 9 评论
3151 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2196 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
425浏览 1评论
1526浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2178浏览 0评论
511浏览 0评论
1642浏览 0评论
GMT+8, 2024-4-25 19:07 , Processed in 1.097322 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
