我注意到,接通电源大约需要500毫秒,以从PSoC4的内部Opamp(作为电压跟随器配置)获得有效输出。
在这个(长)时间之后的进一步行为也是有趣的:在输出信号中有一点过冲和一个尖峰。 我的问题是,在启动后,我需要输出信号,因为有一些外部电路(比较器等)依赖于信号。是否可以在接通电源后立即启动“Opamps”,或者是否需要使用外部Opamps? 以上来自于百度翻译 以下为原文 I noticed that it takes approximately 500ms after power on to get a valid output from the internal Opamp of the Psoc4 (configured as voltage follower) The further behavior after this (long) time is interesting too: there is a bit of overshooting and a spike in the output signal. My problem is that I need the output signal immediately after startup because there is some external circuit (comparators etc.) which rely on the signal. Is it possible to start the Opamps "immediately" after power on or is it necessary to use external Opamps? |
3个回答
你好,
我有一个非常类似的问题,你的“500毫秒后启动延迟”问题,一段时间前,结果是问题是与我使用WCO。请看一下这个窗体盘,因为这也可以解释你的500毫秒延迟。 启动延迟问题 干杯, 迈克 以上来自于百度翻译 以下为原文 Hi, I had a very similar issue to your "500msec after start up delay" issue some time ago, and it turns out the issue was related to me using the WCO. Have a look at this formus discssion, as this might account for your 500msec delay as well Start up delay issue Cheers, Mike |
hzdembed 发表于 2018-12-17 20:06 谢谢! 所以可以把时间缩短到10毫秒。你尝试过更快的启动吗? 以上来自于百度翻译 以下为原文 Thanks! so it s possible to reduce the time to 10ms. Have you tried to get even faster startup? |
我从来没有考虑过我是否可以加快速度超越我需要的10MSEC时间。从内存中,我看到大约5MSEC延迟之间的CPU电源和我的PWM信号变得活跃,这是远远不够快,我想要的。 了解芯片启动内部工作的人可能会指出,如果5MSEC对你来说不够快的话,可以让事情更快一点。 以上来自于百度翻译 以下为原文 I never looked into whether I could speed things up beyond the ~10msec timeframe I needed. From memory, I was seeing about a 5msec delay between the CPU powering up and my PWM signal becoming active, which was more than quick enough for what I wanted. Someone that knows more about the internal workings of the chip start up might be able to point to a way to make things a little quicker if 5msec isn't quick enough for you |
只有小组成员才能发言,加入小组>>
713个成员聚集在这个小组
加入小组1888 浏览 1 评论
1637 浏览 1 评论
3392 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1556 浏览 6 评论
1371 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
170浏览 2评论
170浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
304浏览 2评论
323浏览 1评论
45浏览 1评论
GMT+8, 2024-3-29 05:55 , Processed in 0.696963 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
