扫一扫,分享给好友
请协助解决以下问题。
我的计算机崩溃了,所以我无法返回许可证Vivado WebPack.I重新安装Windows 10再次安装vivado。 我从Xiling(许可证管理)页面下载了现有许可证,但无法加载此许可证,并显示错误消息“无法将许可证权限加载到可信存储中......”合成步骤(ZedBoard)失败,错误未找到许可证 Vivado License Manager不会在“查看/借用/还原/返回许可”部分下列出任何许可 xlicclientmgr -p“下载 Xilinx_License.xml” 失败: 错误:API函数60009失败,结果51307No存储了此响应的请求 响应处理失败。最可能的原因是此响应已被处理。处理响应时退出(4)错误。 xlicclientmgr -l SeqNo状态日期时间参考8待定2015-10-02 20:56“”19待定2015-10-13 18:10“” 列出了2个复合请求中的2个。 xlicclientmgr -v查看应用程序可信存储。 如果不信任你。 D如果禁用。 。 fulfillmentType。 。 。 到期计数Fulfillmentid ProductId 可信存储中没有履行记录。 谢谢, 哔叽 Xilinx_License.xml 3 KB 以上来自于谷歌翻译 以下为原文 Please assist with the following problem. My computer crashed recentry so I was unable to return a license Vivado WebPack. I reinstalled windows 10 installed vivado again. I downloaded existing license from Xiling (License Management) page but can't load this license with an error message "Unable to load License Rights into trusted storage..." Synthesis step (ZedBoard) fails with error no license found Vivado License Manager Doesn't list any licenses under View/Borrow/Restore/Return License sections xlicclientmgr -p "DownloadsXilinx_License.xml" Failed with: ERROR: API function 60009 failed, result 51307 No stored request for this response Response processing failed. The most likely reason is that this response has already been processed. Exit(4) error when processing response. xlicclientmgr -l SeqNo Status Date Time Reference 8 Pending 2015-10-02 20:56 "" 19 Pending 2015-10-13 18:10 "" Listed 2 of 2 composite requests. xlicclientmgr -v Viewing application trusted storage. U if untrusted . D if disabled . . fulfillmentType . . . Expiry Count FulfillmentId ProductId No fulfillment records in trusted storage. Thank you, Serge Xilinx_License.xml 3 KB |
2个回答
嗨,检查这个讨论类似问题的线程.https://forums.xilinx.com/t5/Installation-and-Licensing/Re-Unable-to-access-activation-based-Vivado-license/td-p/566927
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Check this thread where similar issue is discussed. https://forums.xilinx.com/t5/Installation-and-Licensing/Re-Unable-to-access-activation-based-Vivado-license/td-p/566927Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
嗨Vijay,
谢谢您的回复。 你指的是哪个帖子? 如果您建议联系xilinx,我已经尝试联系他们。 但是因为我的电子邮件不是公司的,而且它是免费的许可证,他们的建议是去自己,并使用论坛以及在线资源,因此我的帖子。 如果您在帖子中提到第二个链接,那么我的请求没有履行ID。 如果我错过了什么,请告诉我。 哔叽 以上来自于谷歌翻译 以下为原文 Hi Vijay, Thank you for your reply. Which post in the thread are you referring to? If you suggest contact xilinx, I 've already tried to contact them. But because my email is not corporate and it is a free license, their suggestion was to go and get f... myself, and use forum instead as well as online resources, hence my post. If you were referring to second link in the post in that case I don't have a fulfilment id for my request. Please let me know if I missed something. Serge |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-19 22:21 , Processed in 1.071165 second(s), Total 73, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
