我的机器中的硬盘驱动器已更改,我的许可证(Vivado 2015.2.1的激活)现在失败了。
正如其他帖子中所提到的,我进入了“管理许可证”选项卡并选择了许可证并单击了“修改许可证”。 不幸的是没有任何事情发生,所以我不能继续其他任何事情(迁移许可证等) 提前致谢, 丰富。 以上来自于谷歌翻译 以下为原文 The hard drive was changed in my machine and my license (activation for Vivado 2015.2.1) now fails. As mentioned in other posts I went to the Manage Licenses tab and selected the license and clicked Modify License. Unfortunately nothing happens so I can't proceed with anything else (migrate license, etc.) Thanks in advance, Rich. |
6个回答
嗨,您需要重新托管许可证。
请检查以下AR以获取procedure.http://www.xilinx.com/support/answers/61960.html 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, You will need to rehost the license. Please check the following AR for procedure. http://www.xilinx.com/support/answers/61960.htmlThanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
喜@ richkopelow
你可以运行以下命令并共享输出吗? xlicclientmgr -v“format = long” 以上来自于谷歌翻译 以下为原文 hi @richkopelow Can you run the below command and share the output? xlicclientmgr -v "format=long" |
谢谢@pulim,这是输出...注意:为了让我的“董事会”在运行,我抓住了一个eval许可证,它已经工作了n天。
xlicclientmgr -v“format = long” 查看应用程序可信存储.--------------------------------------------- ---------------------------------- Fulfillment Id:211845749 Fulfillment Type:6 Publisher Activation Trust Flags:0x6 ** BROKEN **恢复状态:已启用权利ID:产品编号:209856468到期日期:永久服务器链:Server1功能线:INCREMENT Vivado_WebPACK xilinxd 2016.08 permanent 9999 E5D747244FA7 VENDOR_STRING = TRUSTED_STORAGE,richkopelow,Vivado_WebPACK,软件,永久,_211075025_0_0_528 ISSUER =“Xilinx Inc”START = 2015年8月12日TS_OKPACKAGE Vivado_WebPACK xilinxd 2016.08 5F31C34C62D8 COMPONENTS =“SDK V_WebPACK”OPTIONS = SUITE -------------------------------------------------- ----------------------------- Fulfillment Id:211917179 Fulfillment Type:6 Publisher Activation Trust Flags:0x7 Fully Trusted Status:Enabled Entitlement Id :产品编号:209856469到期日期:12-nov-2015服务器链:Server1功能线:INCREMENT Vivado_System_Edition_Eval xilinxd 2016.10 12-nov-2015 9999 24FB1813F494 VENDOR_STRING = TRUSTED_STORAGE,richkopelow,Vivado_System_Edition_Eval,软件,评估,_211075025_0_0_643 ISSUER =“Xilinx Inc”START = 2015年10月12日TS_OKINCREMENT SDK xilinxd 2016.10 12-nov-2015 9999 8F82AF994FB5 VENDOR_STRING = TRUSTED_STORAGE,richkopelow,SDK,软件,评估,_211075025_0_0_821 ISSUER =“Xilinx Inc”START = 12-Oct -2015 TS_OKPACKAGE Vivado_System_Edition_Eval xilinxd 2016.10 2441E3877FBD COMPONENTS =“SysGen仿真实施分析器HLS 综合”选项=套件 已浏览2条履行记录中的2条。 E:赛灵思 Vivado 2015.2 BIN> 以上来自于谷歌翻译 以下为原文 Thanks @pulim, here is the output... Note: to get my "board in hand" running I grabbed an eval license which is working for n more days. xlicclientmgr -v "format=long" Viewing application trusted storage. ------------------------------------------------------------------------------- Fulfillment Id : 211845749 Fulfillment Type : 6 Publisher Activation Trust Flags : 0x6 **BROKEN** Restore Status : Enabled Entitlement Id : Product Id : 209856468 Expiration Date : permanent Server chain : Server1 Feature Line(s) : INCREMENT Vivado_WebPACK xilinxd 2016.08 permanent 9999 E5D747244FA7 VENDOR_STRING=TRUSTED_STORAGE,richkopelow,Vivado_WebPACK,software,permanent,_211 075025_0_0_528 ISSUER="Xilinx Inc" START=12-Aug-2015 TS_OK PACKAGE Vivado_WebPACK xilinxd 2016.08 5F31C34C62D8 COMPONENTS="SDK V_WebPACK" OPTIONS=SUITE ------------------------------------------------------------------------------- Fulfillment Id : 211917179 Fulfillment Type : 6 Publisher Activation Trust Flags : 0x7 Fully Trusted Status : Enabled Entitlement Id : Product Id : 209856469 Expiration Date : 12-nov-2015 Server chain : Server1 Feature Line(s) : INCREMENT Vivado_System_Edition_Eval xilinxd 2016.10 12-nov-2015 9999 24FB1813F494 VENDOR_STRING=TRUSTED_STORAGE,richkopelow,Vivado_System_Edition_Eval,software,ev aluation,_211075025_0_0_643 ISSUER="Xilinx Inc" START=12-Oct-2015 TS_OK INCREMENT SDK xilinxd 2016.10 12-nov-2015 9999 8F82AF994FB5 VENDOR_STRING=TRUSTED_STORAGE,richkopelow,SDK,software,evaluation,_211075025_0_0 _821 ISSUER="Xilinx Inc" START=12-Oct-2015 TS_OK PACKAGE Vivado_System_Edition_Eval xilinxd 2016.10 2441E3877FBD COMPONENTS="SysGen Simulation Implementation Analyzer HLS Synthesis" OPTIONS=SUITE Viewed 2 of 2 fulfillment records. e:XilinxVivado2015.2bin> |
喜@ richkopelow
用于共享输出.Tandpack许可证是对您机器上硬盘更换的破坏。 在更换硬盘之前,您需要返回许可证。 以下AR详细说明了许可证被破坏或不受信任的原因。 http://www.xilinx.com/support/answers/63683.html 以上来自于谷歌翻译 以下为原文 hi @richkopelow Thaks for sharing the output.The webpack license is broken due to the change of hard drive on your machine. Before changing the harddrive you need to return the license. The below AR has the details on the reasons for license to be broken or untrusted. http://www.xilinx.com/support/answers/63683.html |
@pulimYes。
事实上,这就是为什么我将帖子命名为“硬盘改变后的许可证失败”。 我不太确定在过去已经发生的硬盘更改之前我应该如何继续返还许可证。 许可证可以退回我的帐户吗? 谢谢, 丰富。 以上来自于谷歌翻译 以下为原文 @pulim Yes. In fact that is why I titled the post "license failure after hard drive change." I'm not quite sure how I should proceed returning the license prior to a hard drive change that has already happened in the past. Can the license be returned to my account? Thanks, Rich. |
嗨@richkopelow
您可以在http://www.xilinx.com/support/service-portal.html上打开解释您的问题的服务请求 请查看此ARhttp://www.xilinx.com/support/answers/64535.html 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @richkopelow You can open service request explaining your issue here http://www.xilinx.com/support/service-portal.html Check this AR http://www.xilinx.com/support/answers/64535.html Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
只有小组成员才能发言,加入小组>>
2162 浏览 7 评论
2605 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2077 浏览 9 评论
3149 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2192 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
423浏览 1评论
1523浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2177浏览 0评论
508浏览 0评论
1638浏览 0评论
GMT+8, 2024-4-24 02:13 , Processed in 0.921728 second(s), Total 50, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
