你好,获得NWA的实际温度是否可行?
我使用DCOM连接到NWA并使用labview来控制设备。 亲切的问候ruben编辑:rabber于2014年7月3日上午2:46 以上来自于谷歌翻译 以下为原文 hello, is it posible to get the acctual temperatur oft the NWA? im connected to the NWA with DCOM and use LabView to control the device. with Kind regards ruben Edited by: rabber on Jul 3, 2014 2:46 AM |
8个回答
我们有一个查询位于接收器微电路上的温度传感器的命令(见下文),但是你的PNA-L(N5230A)没有合适的硬件。
温度传感器与PNA-X型号的接收器以及一些新的PNA型号(N522x)一起引入。 意义:温度是多少? (只读)返回接收器微电路的温度。 适用于除N5244A和N5245A型号外的所有PNA-X和N522x型号。 了解有关接收器温度的更多信息 参数选择CELSius或FAHRenheit示例SENS:TEMP? CELS感觉:温度? fahrenheit返回类型数字默认值不适用 以上来自于谷歌翻译 以下为原文 we do have a command for querying a temperature sensor located on the receiver microcircuit (see below), but your PNA-L (N5230A) does not have the right hardware. the temperature sensor was introduced with the receivers in the PNA-X models and also in some new PNA models (N522x). SENSe:TEMPerature? (Read-only) Returns the temperature on the Receiver microcircuit. Available on all PNA-X and N522x models except the N5244A and N5245A models. Learn more about Receiver Temperature. Parameters Choose from CELSius or FAHRenheit Examples SENS:TEMP? CELS sense:temperature? fahrenheit Return Type Numeric Default Not Applicable |
Topcbpcba 发表于 2018-12-13 07:14 我刚刚更新了PNAHelp以排除N523x型号。 http://na.tm.agilent.com/pna/help/latest/Programming/GP-IB_Command_Finder/Sense/Temperature.htm 以上来自于谷歌翻译 以下为原文 I just updated PNAHelp to exclude the N523x models. http://na.tm.agilent.com/pna/help/latest/Programming/GP-IB_Command_Finder/Sense/Temperature.htm |
testd018 发表于 2018-12-13 08:00 是否有可能通过DCOM获取温度(抱歉在第一个GPIB写入,但它不能与LabView一起使用)现在我们与DCOM thx联系以获得帮助 以上来自于谷歌翻译 以下为原文 is there a possibility to get the temperature via DCOM (sorry write at first GPIB that was the first idee but it doesnt work with LabView) now we are connected with DCOM thx for the help |
734747535qwe 发表于 2018-12-13 08:18 您遇到的问题不在于软件界面。 您没有用于感应N5230A PNA-L温度的_ *右硬件* _。 如果单击gfarrel发布的链接,您可以看到具有正确硬件的型号列表。 以上来自于谷歌翻译 以下为原文 the issue that you have is not with the software interface. You do not have the _*right hardware*_ for sensing the temperature in your N5230A PNA-L. If you click on the link that gfarrel posted you can see a list of model numbers that do have the right hardware. |
Topcbpcba 发表于 2018-12-13 08:34 嘿嘿那些能够正确阅读的人显然有优势;) 以上来自于谷歌翻译 以下为原文 hehe thx somebody who can read correctly is clearly in advantage ;) |
只有小组成员才能发言,加入小组>>
2082 浏览 1 评论
1846 浏览 1 评论
1700 浏览 5 评论
2563 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1547 浏览 4 评论
关于Keysight x1149 Boundary Scan Analyzer
350浏览 0评论
1386浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
262浏览 0评论
2248浏览 0评论
1103浏览 0评论
GMT+8, 2024-3-29 17:30 , Processed in 1.111264 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
