扫一扫,分享给好友
您好,是否可以使用labview完全锁定NWA。
我使用LabView控制NWA并在LabView中安全测量但我想在LabView程序运行时锁定设备。 亲切的问候ruben 以上来自于谷歌翻译 以下为原文 hello, is it possible to completely lock the NWA with LabView. I control the NWA with LabView and safe the measurement in LabView but i want to lock the device if the LabView Programm is running. with Kind regards ruben |
5个回答
假设您正在使用PNA(在您引用N5230A的其他帖子中),如果您使用SCPI控制仪器,前面板键会自动锁定(进入远程模式),但如果有人按下它们,它们可以再次激活
本地密钥(内存硬键)。 N5230A没有触摸屏,因此只要您不插入鼠标或键盘,用户就无法使用菜单操作盒子。 以上来自于谷歌翻译 以下为原文 Assuming you are using a PNA (in your other posts you referred to a N5230A) if you are using SCPI to control the instrument, the front-panel keys automatically lock (goes into remote mode), but they can activate again if someone presses the local key (the memory hardkey). The N5230A does not have a touch screen, so as long as you don't plug in a mouse or keyboard, users won't be able to manipulate the box using the menus. |
Topcbpcba 发表于 2018-12-13 07:19 是的,你是对的我使用N5230A。 但我通过labview与DCOM和控件建立了联系。 鼠标和键盘插入...完全锁定设备是不可能的? 如果没有,是否有可能通过DCOM将设备设置为远程模式? 以上来自于谷歌翻译 以下为原文 yes you are right i use the N5230A. but i am connected about DCOM and controls with labview. mouse and keyboard are plugged in... completely lock the device is not possible? if not is there any possibility to set the device to remote mode via DCOM? |
734747535qwe 发表于 2018-12-13 07:38 使用DCOM,您实际上可以更好地控制。 使用命令IApplication4.LocalLockoutState = TRUE或FALSE来锁定屏幕,前面板甚至使用鼠标和键盘。 你可以在_ *在线帮助中找到关于这个命令的更多信息* _ 以上来自于谷歌翻译 以下为原文 with DCOM you actually have better control. use the command IApplication4.LocalLockoutState = TRUE or FALSE to lock the screen, front panel and even the use of mouse and keyboard. you can find out more about this command in the _*online help*_ |
Topcbpcba 发表于 2018-12-13 07:57 * thx为你的帮助*真的很酷它的工作:)我使用命令“IApplication”而不是“IApplication * 4 *”,并没有命令“LocalLockoutState”..... 以上来自于谷歌翻译 以下为原文 *thx for your help* really cool it works :) i used the command "IApplication" and not "IApplication*4*" and there was no command "LocalLockoutState"..... |
Topcbpcba 发表于 2018-12-13 07:57 。编辑:拉伯于2014年7月4日上午4:41 以上来自于谷歌翻译 以下为原文 . Edited by: rabber on Jul 4, 2014 4:41 AM |
只有小组成员才能发言,加入小组>>
2097 浏览 1 评论
1854 浏览 1 评论
1713 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2257浏览 0评论
GMT+8, 2024-4-24 22:06 , Processed in 1.017855 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
