嗨,艾利打破了我的眼球寻找这个东西,但没有发现我想能够做手工制作的跳跃跳跃等类似的东西。通常在汇编程序上有“。”或“$i”,但这些似乎都不起作用。将其用于MPASMX(PIC16),但对于其他人来说也很好。
以上来自于百度翻译 以下为原文 Hi, all I've broken my eyeballs searching for this stuff but found nothing I want to be able to do manually crafted PCrelative jumps etc and similar stuff. Usuall on assembler there is "." or "$_", but none of those seems to work. Also, it would be nice to know about the rest of automatic variables. I need it for mpasmx ( for PIC16 ), but it would be also nice to know for others. |
5个回答
美元应该起作用。至于自动变量,你到底是什么意思?
以上来自于百度翻译 以下为原文 $ should work. As for automatic variables, what do you mean exactly? |
类似的“$”,你提到AsSbBeLever在安装过程中不断更新。我一时想不起来,但是如果“$”不是单独的,那么最好知道还有什么可用的。
以上来自于百度翻译 以下为原文 variables like that "$" you mentioned that asssembler keeps updating as it goes through the assembling process. I couldn't think of any at the moment, but if "$" is not alone, it would be nice to know what else is available. |
“$”不是变量,而是返回当前程序计数器的运算符。
以上来自于百度翻译 以下为原文 The '$' is not a variable, it is an operator that returns the current program counter. |
如果你有MASM文档,你早就知道了。
以上来自于百度翻译 以下为原文 You would have known that if you had the masm docs. |
如果你有MPLABX,那么你就有了MPASM文档,你只需要去找Micc:程序文件(x86) Microchip MPLABXv3.26MPASMXDOCSMPASMMMPLIKIUGUSORIGUIDED。PDFLATE适当地更新版本号。
以上来自于百度翻译 以下为原文 If you have MPLABX, then you have the MPASM docs, you just have to go looking for them C:Program Files (x86)MicrochipMPLABXv3.26mpasmxdocsMPASM_MPLINK_User_Guide.pdf Just update the version number as appropriate. |
只有小组成员才能发言,加入小组>>
4825 浏览 9 评论
1831 浏览 8 评论
1748 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2955 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2060 浏览 5 评论
461浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
364浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1799浏览 0评论
GMT+8, 2024-4-25 12:00 , Processed in 1.281701 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
