我将PSoC6项目移植到Keil FDK(5.24)中。我遵循“AN219434”,在创建者的帮助下帮助主题。我只使用了pSOC6的CM0创建了一个简单的项目。
我可以在MK中完成这个项目,但是KEIL生成的HEX文件的记录与创建者非常不同,不能被PSoC编程识别(失败)!HEX文件解析失败。未知记录类型。我从Keil和创建者那里附加了HEX。请告知。谢谢 CE220169S.Calto.H.Zip 9.8 K CE220169KeIL.H.Zip 8.3 K 以上来自于百度翻译 以下为原文 I am porting PSOC6 projects into KEIL MDK(5.24). I follows the "AN219434" and help topics in the HELP of creator. I created a simple project using CM0 of PSOC6 only. I can complie the project in MDK well but the record in the Hex file generated from KEIL is much different as Creator, and cannot be recognized by PSOC programmed (FAILED! Hex File parsing failure. Unknown record type.). I attached the hexs from KEIL and Creator. Please advise. Thanks
5个回答
让我看看我能想出什么办法。在这一点上,我确认PSoC程序员失败了,正如Keil HEX文件所描述的那样。我需要把这个例子移植到Keil中,看看我是否可以复制你的十六进制文件。
吉姆 以上来自于百度翻译 以下为原文 Let me see what I can figure out. At this point I confirm that PSoC Programmer fails as described with the Keil hex file. I need to port the example into Keil and see if I can replicate your HEX file. Jim |
只是一个快速跟进。我们正在探索。我会随时通知你的。
以上来自于百度翻译 以下为原文 Just a quick follow up. We are exploring. I'll keep you posted. |
你好,JCUI,
我检查了KEIL生成的HEX文件。与Creator生成的HEX文件的主要区别在于,有一行记录类型“0x05”,用于指定对象文件的执行起始地址。 例如,使用下面的行,执行起始地址是0x100000 0C1。 :040000 05100000 0C126 我认为PSoC程序员应该忽略“0x05”的记录类型。 郝 以上来自于百度翻译 以下为原文 Hi JCUI, I checked the hex file generated by Keil. The main difference with hex file generated by Creator is there is one line with record type '0x05' which means for specifying execution start address for the object file. For example with the following line, the execution start address is 0x100000C1. :04000005100000C126 I think PSoC programmer should ignore record type of '0x05'. Hao |
2011jiangzhou 发表于 2018-12-13 11:21 谢谢郝!我很欣赏更新。代码示例作者将在星期一看一看——他目前正在商务旅行。 以上来自于百度翻译 以下为原文 Thanks Hao! I appreciate the update. The code example author is going to take a look on Monday - he's on business travel at the moment. |
事实证明,这是预期的行为。我对PSoC程序员的内部设计有了一些了解。它不是设计为使用纯十六进制文件。CyPress工具(PSoC Creator)生成标准的HEX文件,加上一些附加信息来标识预期的目标,并提供快速校验和。实际上,它使标准的HEX文件更加健壮——它不能终止在错误的芯片上并导致失败。
因此,由第三方IDE创建的十六进制文件,使用该方的程序员。 我将研究支持标准HEX文件的想法,但是它有很多潜在的影响。PSoC程序员多年来一直这样工作,它是一个脚本化工具。我们无法知道谁已经建立了依赖于解析PSoC程序员HEX文件的脚本或命令行工具(这是有据可查的)。 所以现在,它就是这样运作的。我很欣赏这份报告和学习机会,并向你道歉,因为它并不像你预期的那样有效。 我要标记这个答案。如果你还有其他问题,请告诉我。 以上来自于百度翻译 以下为原文 As it turns out, this is expected behavior. I've learned a little about the internal design of PSoC Programmer. It is not designed to use a pure hex file. Cypress tools (PSoC Creator) generate a standard hex file plus some additional information to identify the intended target, and to provide a quick checksum. In effect, it makes the standard hex file more robust - it can't end up on the wrong chip and cause failure. So, a hex file created by a 3rd party IDE, use that party's programmer. I will look into the idea of ALSO supporting standard hex files, but that has lots of potential repercussions. PSoC Programmer has worked like this for years, and it is a scriptable tool. We have no way of knowing who has built what scripts or command line tools that rely on parsing the PSoC Programmer hex file (which is well documented). So for now, that's how it works. I appreciate the report, and the learning opportunity, and apologize that it did not work the way you expected. I'm going to mark this answered. Let me know if you have any other questions. |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1652 浏览 1 评论
3405 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-23 18:09 , Processed in 0.704365 second(s), Total 80, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
