我买了一张zybo 7000 SoC和一张兑换券。
最初我在Ubuntu 14.04上安装了2015.2 vivado设计套件并生成了.lic文件。 后来我卸载了2015.2并安装了2104.4版本的vivado设计套件。 我在这里按照相同的步骤安装许可证文件。 我多次尝试删除.lic文件并再次生成它但仍然看到一个错误,说sysnthesis'失败了。 显示许可证不支持综合时出错。 ([共同:15-345])错误 以上来自于谷歌翻译 以下为原文 I bought a zybo 7000 SoC along with a redeem voucher. Initially I installed 2015.2 vivado design suite on Ubuntu 14.04 and generated .lic file. Later I uninstalled 2015.2 and installed 2104.4 version vivado design suite. I followed the same procedure here installing the license file. I tried several times deleting the .lic file and generating it again but still I see an error saying that sysnthesis' is failed. Error showing that the license doesn't support for synthesis. ([Common:15-345]) error |
5个回答
Hello @ akhilchandra,要使用Vivado,您需要生成并激活基于激活的许可证(.xml)文件而不是(.lic)文件。
要了解该过程,您可以查看此视频 http://www.xilinx.com/training/vivado/vivado-licensing-and-activation-overview.htm 此链接也具有逐步过程。 http://www.xilinx.com/tools/faq.htm 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @akhilchandra, To use Vivado, you need to generate and activate activation based license (.xml) file instead of (.lic) file. To know the procedure, you can have a look at this video http://www.xilinx.com/training/vivado/vivado-licensing-and-activation-overview.htm This link also has the stepwise procedure. http://www.xilinx.com/tools/faq.htm Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
但是当我尝试在xilinx.com/getlicense中这样做时,我无法在网页中选择基于激活的许可证
以上来自于谷歌翻译 以下为原文 But when I tried to do so in the xilinx.com/getlicense I cannot select activation based license in the webpage |
喜@ akhilchandra
您需要从Vivado许可证管理器访问xilinx许可站点。 打开Vivado许可证管理器 - >获取许可证 - >选择vivado webpack license - >立即连接。 这将导航您进入Xilinx许可站点。 登录详细信息,现在您将能够在激活许可证部分看到Vivado webpack许可证 以上来自于谷歌翻译 以下为原文 hi @akhilchandra You need to go to xilinx licensing site from Vivado license manager. Open Vivado license manager -> Obtain license -> select vivado webpack license -> connect now. This will navigate you to the Xilinx licenseing site. Login with details and now you will be able to see Vivado webpack license under activation based licenses section |
下面的激活许可部分被禁用,因为Vivado License Manager未用于启动此Web会话,或者因为已使用此唯一请求ID生成激活许可证。
请找到附件 以上来自于谷歌翻译 以下为原文 The activation licensing section below is disabled either because Vivado License Manager was not used to initiate this web session or because an Activation license has already been generated using this unique request ID. Please find the attachment |
我还在这里提供了这个链接http://www.xilinx.com/tools/faq.htm
让我假设我已经下载了reference.xml文件,但在哪里可以找到它? 我收到了包含.lic文件的邮件,而不是任何其他文件。 如果此文件不是通过电子邮件发送的,我可以在ubuntu 14.04中找到它 关心阿希尔 @pulim @ashishd 以上来自于谷歌翻译 以下为原文 I also refferd this link here http://www.xilinx.com/tools/faq.htm Let me assume that I have donwloaded reference.xml file but where can i find it? I recieved a mail including .lic file and not any other files. If this file is not sent through email where can i find it in ubuntu 14.04 Regards Akhil @pulim @ashishd |
只有小组成员才能发言,加入小组>>
2134 浏览 7 评论
2590 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2063 浏览 9 评论
3135 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2166 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
399浏览 1评论
1503浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2164浏览 0评论
495浏览 0评论
1618浏览 0评论
GMT+8, 2024-3-29 05:24 , Processed in 0.894625 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
