您好,我正在使用固件A.09.90.01运行N5244A PNA-X。
我尝试使用以下类型的通道运行'Cal All':-5窄带SMC通道-5宽带SMC通道-5转换器通道的噪声系数因此总共有15个通道。 我正在使用2个ecals:2.4mm和2.9mm E cal套件。 几乎需要5个小时才能完成校准。 然而,当它到达最后一步(在通过适配器表征步骤之后)以保存校准时,应用程序崩溃了! (请参阅随附的png)。 我已将崩溃日志附加到zip文件中。 当我重新启动应用程序并转到cal set manager时,我没有任何东西可以挽救,因为根本没有保存校准集寄存器。 我的问题是,在任何时候我都可以“全部加速”的频道数量/类型是否有限制,所以我可以避免这种不愉快的情况。 此外,作为UI功能增强功能,当下一步准备就绪时,是否有办法在“全部校准”过程中发出声音警报? 在功率校准和下一步之间约为3.5小时,我不想一直轮询该站。 rok 08_26_2013-CAL ALL CRASH_MSG2.PNG113.9 KB835x_D2013_8_26_T18_7_54_406.zip173.1 KB 以上来自于谷歌翻译 以下为原文 Hello, I'm running the N5244A PNA-X with firmware A.09.90.01. I tried running the 'Cal All' using the following types of channels: -5 narrowband SMC channels -5 wideband SMC channels -5 noise figure for converter channels So a total of 15 channels in all. I am using 2 ecals: A 2.4mm and a 2.9mm E cal kit. It took nearly 5 hours to nearly finish the calibration. However, when it got to the last step (after the thru adapter characterization step) to save the calibration, the application crashed! (please see attached png). I've attached the crash log in a zip file. When I restarted the application and went to the cal set manager, there was nothing I could salvage, since no cal set registers was saved at all,. My question is whether there is a limit on the number/type of channels I can 'Cal All' at any one time, so I can avoid this unpleasant situation. Also, as a UI feature enhancement, is there a way to put an audible alert during the 'Cal All' process when the next step is ready to go? Between power cal and the next step was about 3.5 hours, and I don't want to be polling the station all the time. rok 附件
4个回答
我认为只有2.92个ecals的错误;
固定在9.90.03或9.90.04。 问题是 - 在一个人 - 固件团队认为ecals只能有3.5,2.4和1.85连接器。 但现在他知道他们可以有任何连接器类型,所以他必须查询ecal连接器类型...抱歉。 附: 在设置复杂的校准情况时将所有点数设置为11或3,并通过校准一次以确保其工作而不必永远等待是个好主意。 以上来自于谷歌翻译 以下为原文 I think there was a bug only for 2.92 ecals; fixed in 9.90.03 or 9.90.04. The trouble was -someone- in the firmware team thought ecals could only have 3.5, 2.4 and 1.85 connectors. But now he knows that they can have any connector type and so he has to query the ecal for connector type... Sorry. P.S. Good idea when setting up a complicated calibration situation to set all the number of points to 11 or 3, and run through the cal once to make sure it works without having to wait forever. |
> {quote:title = rok写道:} {quote}>你好,>>我正在运行固件A.09.90.01的N5244A PNA-X。
我尝试使用以下类型的通道运行'Cal All':>> -5窄带SMC通道> -5宽带SMC通道> -5转换器通道的噪声系数>所以总共有15个通道。 >>我使用2个ecals:2.4mm和2.9mm E cal套件。 >>接近完成校准花了将近5个小时。 您可以发布您的州(或通过PM发送)吗? 当你到达cal的摘要页面时,它说它需要多少分? 如果所有通道之间的频率没有太多重叠,并且它们都有很多点,并且有1/3的通道是噪声系数,那么最终可能需要5小时的校准,但我们总是感兴趣 在看到这些现实生活中的极端用例,看看是否有什么我们可以优化以减少测量时间。 以上来自于谷歌翻译 以下为原文 > {quote:title=rok wrote:}{quote} > Hello, > > I'm running the N5244A PNA-X with firmware A.09.90.01. I tried running the 'Cal All' using the following types of channels: > > -5 narrowband SMC channels > -5 wideband SMC channels > -5 noise figure for converter channels > So a total of 15 channels in all. > > I am using 2 ecals: A 2.4mm and a 2.9mm E cal kit. > > It took nearly 5 hours to nearly finish the calibration. would it be possible for you to post your state (or send it via PM)? when you get to the summary page of the cal, how many points does it say it needs to cal? if there is not much overlap in frequencies among all the channels and they all have lots of points and with 1/3 of the channels being noise figure, it is possible to end up with a cal that takes 5 hours, but we are always interested in seeing these real life extreme use cases to see if there is something we can optimize to reduce the measurement time. |
嗨,谢谢你的回复。
我将升级固件以查看它是否有助于这种情况。 但是,在固件页面上,它只有A.09.90.02固件。 所以我想我必须等待.03或.04。 对于daras:功率校准的点数为:31115。我可以通过PM发送状态文件,供团队分析。 问题是如何为您执行PM? 我之前没有这样做过。 谢谢,rokEdited:rok于2013年8月27日上午11:20 以上来自于谷歌翻译 以下为原文 Hi, Thanks for the replies. I'll upgrade the firmware to see if it helps the situation. However, on the firmware page,it only has the A.09.90.02 firmware. So I guess I'll have to wait for the .03 or.04. For daras: The number of points for the power calibration was: 31115. I can send the state file via PM for your team's analysis. The question is how do I perform a PM to you? I haven't done that before. Thanks, rok Edited by: rok on Aug 27, 2013 11:20 AM |
只需点击我的名字(在PNA-X图片上方信息的左侧窗格中),您将获得顶部链接以发送私信。 在PM,只需给我你的电子邮件,我就会给你发送我的官方无线电邮件,你可以安全地发送任何附件。 以上来自于谷歌翻译 以下为原文 just click on my name (on the left pane of the message above the picture of the PNA-X) and you'll get link on top to send a private message. in the PM just give me your email and I'll email you with my official agilent email, to which you can securely send any attachments. |
只有小组成员才能发言,加入小组>>
2097 浏览 1 评论
1854 浏览 1 评论
1713 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2257浏览 0评论
GMT+8, 2024-4-24 19:36 , Processed in 1.315845 second(s), Total 48, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
