嗨,我只需更换54810示波器上的衰减器,并需要更新联系计数。
有谁知道在哪里获得infinium服务磁盘更新衰减器垂直联系计数。 谢谢'米奇 以上来自于谷歌翻译 以下为原文 Hi, I just replace the attenuator on my 54810 scope and need to update the contact count. Does anyone know where to get infinium service disk to update attenuater vertical contact count. Thanks' Mickey |
13个回答
您好Mickey,您不需要服务磁盘,只需按照以下步骤操作:1。连接键盘并运行示波器后,按下并结束示波器应用程序。
2.使用Windows资源管理器并在C: scope文件夹中创建名为service.bat的批处理文件。 批处理文件包含:d:如果存在c: scope bin hp5481X.exe hp5481X scope / scope / hpib / service如果存在d: hp5484X.exe hp5484X scope / scope / hpib / service 3.进入自检 菜单并选中服务扩展名框。 4现在选择范围自检的下拉菜单,然后选择“Atten Set”5。按开始按钮。 这应该让你在那里我想。 使用/ service开关启动范围应用程序是什么诀窍。 松鸦 以上来自于谷歌翻译 以下为原文 Hi Mickey, You don't need the service disk, just follow these steps: 1. With a keyboard connected and the scope running, press and end the scope application. 2. Use windows explorer and create a batch file called service.bat in the C:scope folder. The batch file contains: d: If exist c:scopebinhp5481X.exe hp5481X scope /scope /hpib /service If exist d:hp5484X.exe hp5484X scope /scope /hpib /service 3. Go into the self test menu and check the box for service extensions. 4 Now select the pulldown menu for scope self tests and select "Atten Set" 5. Press Start button. That should get you there I think. Launching the scope application with the /service switch is what does the trick. Jay |
chrisjohn 发表于 2018-12-12 08:52 没工作。 只是为了确认批处理文件只包含以下条目对吗? d:如果存在c: scope bin hp5481X.exe hp5481X scope / scope / hpib / service如果存在d: hp5484X.exe hp5484X scope / scope / hpib / service 以上来自于谷歌翻译 以下为原文 Didn't work. Just to confirm batch file contains only the following entries right ? d: If exist c:scopebinhp5481X.exe hp5481X scope /scope /hpib /service If exist d:hp5484X.exe hp5484X scope /scope /hpib /service |
那很奇怪。 范围应用程序是否已启动? 范围背面的VIN#是什么,以及安装了多少内存? 是否有d:ramdisk驱动器,它是否有范围应用程序? 以上来自于谷歌翻译 以下为原文 That's odd. Did the scope application launch? What is the VIN # on the back of the scope, and how much memory is installed? Is there a d: ramdisk drive, and does it have the scope application on it? |
对你的问题。 - 是范围应用确实启动了。 - VIN#033 - Ramdrive yes = d: - 是的,范围应用程序在d: - 256Mb上 以上来自于谷歌翻译 以下为原文 To your questions. - Yes scope application did launch. - VIN#033 - Ramdrive yes = d: - Yes the scope application is on the d: - 256Mb |
wangcong12138 发表于 2018-12-12 09:24 在自检下,选中服务扩展的复选框。 然后你应该能够选择衰减器接触计数 以上来自于谷歌翻译 以下为原文 Under self tests, check the box for service extensions. Then you should be able to select attenuator contact counts |
wangcong12138 发表于 2018-12-12 09:24 在自检下,选中服务扩展的复选框。 然后你应该能够选择衰减器接触计数。 以上来自于谷歌翻译 以下为原文 Under self tests, check the box for service extensions. Then you should be able to select attenuator contact counts. |
wangcong12138 发表于 2018-12-12 09:24 在自检下,选中服务扩展的复选框。 然后你应该能够选择衰减器接触计数。 以上来自于谷歌翻译 以下为原文 Under the self tests, check the box for service extensions. Then you should be able to select attenuator contact counts. |
wangcong12138 发表于 2018-12-12 09:24 > {quote:title = mickey007写道:} {quote}>提出你的问题。 >> - 是范围应用确实启动了。 > - VIN#033> - Ramdrive yes = d:> - 是的范围应用程序在d:> - 256Mb抱歉所有重复的帖子 - 我收到错误,并认为他们没有被发布! 无论如何,在自检下,选中服务扩展的框。 然后你应该可以从下拉菜单中选择“Atten Set”。 完成后,点击“开始测试”。编辑:Jay W于2013年9月23日上午3:47 以上来自于谷歌翻译 以下为原文 > {quote:title=mickey007 wrote:}{quote} > To your questions. > > - Yes scope application did launch. > - VIN#033 > - Ramdrive yes = d: > - Yes the scope application is on the d: > - 256Mb Sorry about all the duplicate posts - I was getting an error and thought they weren't getting posted! Anyway, Under the self tests, check the box for service extensions. Then you should be able to select "Atten Set" from the pulldown menu. Once that is done click on "Start Test.". Edited by: Jay W on Sep 23, 2013 3:47 AM |
chrisjohn 发表于 2018-12-12 10:52 重置BIOS后它确实有效。编辑:mickey007于2013年9月22日晚上9:30 以上来自于谷歌翻译 以下为原文 It did work after resetting the bios. Edited by: mickey007 on Sep 22, 2013 9:30 PM |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 23:37 , Processed in 1.115719 second(s), Total 81, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
