嗨,我正在使用带有IVI驱动程序和C#编程语言的Agilent E3646A(2通道)PS我在从电源读取测量时遇到问题。
* _Code:_ * PS.Initialize(“ASRL1 :: INSTR”,true,true); PS.Outputs.Item [“Output1”]。ApplyVoltageCurrent(3.0,0.1); double measuredValue = PS.Outputs.Item [“Output1”]。Measure(AgilentE36xxMeasurementTypeEnum.AgilentE36xxMeasurementCurrent); 我收到错误 - “VISA错误=操作完成前超时已过期”。 1. PS连接到ARSL1,所有其他命令与测量读数分开。 2.我用E3640A(只有一个通道)尝试过相同的代码,工作正常。 3.尝试使用GPIB的E3646A,它工作正常。 我想使用串口而不是GPIB请帮助Arnon 以上来自于谷歌翻译 以下为原文 Hi I'm using Agilent E3646A (2 Channels) PS with IVI driver and C# programming language I have problems reading measurement from the power supply. *_Code:_* PS.Initialize("ASRL1::INSTR", true, true); PS.Outputs.Item["Output1"].ApplyVoltageCurrent(3.0, 0.1); double measuredValue = PS.Outputs.Item["Output1"].Measure(AgilentE36xxMeasurementTypeEnum.AgilentE36xxMeasurementCurrent); I getting error - "VISA error = Timeout expired before operation completed." 1. the PS connected to ARSL1 , all other commands working apart from measurement reading. 2. I have tried the same line of code with E3640A (only one channel) and it is working fine. 3. tried E3646A with GPIB and it is working fine. I want to use the serial port and not GPIB please help Arnon |
1个回答
您好,我已将此记录为我们的IVI驱动程序上的错误。
目前,解决方法是使用属于IVI驱动程序的passthrough命令。 对于那个很抱歉。 以上来自于谷歌翻译 以下为原文 Hello, I have logged this as a bug on our IVI driver. For now, the workaround would be to use the passthrough commands that are part of the IVI driver. Sorry about that. |
只有小组成员才能发言,加入小组>>
2082 浏览 1 评论
1845 浏览 1 评论
1700 浏览 5 评论
2563 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1546 浏览 4 评论
关于Keysight x1149 Boundary Scan Analyzer
349浏览 0评论
1385浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
261浏览 0评论
2248浏览 0评论
1102浏览 0评论
GMT+8, 2024-3-28 17:48 , Processed in 1.091177 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
