嗨,每个人都知道PIC16F1887的功率消耗在500千赫和/或1兆赫使用它的HimtoSc?不幸的是,表7-2:在数据表的第599页上的电源电流对于16 MHz以下的任何情况都不显示HftimeC电流(也不做任何图表)。它只显示了HfToToC的功耗:32 MHz -2.6Ma(3V)16 MHz -1.4Ma(3V)表33-8(P 606)声称“低功率优化HfTimTc频率”为1 MHz和2 MHz。YAH,好,听起来不错,但是1 MHz的低电平是多少?是100还是200还是300 UA?如果任何人都有PIC16F18XXX,并且知道或可以测量500千赫兹和/或1兆赫的功率消耗在3V左右,我将非常感激。这将有助于确定这种时髦、功能丰富的MCU是否适合我的低功耗项目(在大约500 kHz下运行大约25%的时间)。非常感谢,卫国明。
以上来自于百度翻译 以下为原文 Hi everyone Does anybody happen to know the power consumption of the PIC16F18877 at 500 kHz and/or 1 MHz using its HFINTOSC? Unfortunately, TABLE 37-2: SUPPLY CURRENT on p. 599 of the datasheet does not show HFINTOSC current for anything below 16 MHz (nor do any charts). It only shows power consumption for the HFINTOSC at: 32 MHz - 2.6mA (3V) 16 MHz - 1.4mA (3V) TABLE 37-8 (p. 606) claims “low-Power optimized HFINTOSC frequency” for 1 MHz and 2 MHz. Yah, okay, sounds good, but how low is low for 1 MHz? Is it 100 or 200 or 300uA? If anyone out there has a PIC16F18xxx and knows, or could measure, the power consumption for 500 kHz and/or 1 MHz at around 3V I would be very grateful. It would help to determine if this snazzy, features-rich MCU is suitable for my low power project (operates at 500 kHz about 25% of the time). Thank you very much, Jake |
3个回答
您好,如果您使用3.3V电源,更喜欢“LF”版本,它没有内部调节器(PIC16LF1887)。您可以使用Quest-HPC板轻松地进行这些电流测量(您甚至可以将PIC16LF1887放在该套件上)。我为最近的PIC16或PIC18做这个。这个套件具有片上调试器(不需要外部PACTIT3)。使用MCC插件更快地生成代码。如果你有经验,一天之内你可以做各种功率测量。
以上来自于百度翻译 以下为原文 Hi, If you use 3.3V power supply, prefer the "LF" version which has no internal regulator ( PIC16LF18877 ). You could do these current measurements easily using the Curiosity HPC board (you can even put the PIC16LF18877 on that kit). I do this for recent PIC16 or PIC18. This kit has on chip debugger (no need for external Pickit3). Use MCC plugin to generate code faster. If you are experienced, within one day you can do various power measurements Regards |
谢谢你的回复。也许我应该说:16HF18XXX或16LF15XXX或16LF19XXX @ 1兆赫,因为它们都有相同的HFIFToC设计。我不欢迎想到必须购买一个特殊的董事会和混乱的配置和设置,以获得我认为是基本规格的寿司。在数据表中找到了大多数其他PIC MCU(和其他MCU),为什么不为16F1XXXX家庭?(功耗)@ 500千赫,1兆赫,4兆赫,8兆赫。所有的数据表都对此保持沉默。我所做的——也许应该更清楚——是一个基于数据表的高级评估。我喜欢16F1XXXX家庭的各种铃声和口哨,但是需要知道更多关于低于16 MHz的功耗。用160F1XXXX或16LF1XXXX在1兆赫(或500千赫)使用HFIFTROC的电力消耗,我将非常感激…
以上来自于百度翻译 以下为原文 Thank you for your reply. Perhaps I should have stated: 16LF18xxx or 16LF15xxx or 16LF19xxx @ 1 MHz using the HFINTOSC since they all have the same HFINTOSC design. I do not welcome the thought of having to buy a special board and messing around with configuration and setup to get what I consider to be basic specs that should be in the datasheet ;-( Power consumption @ 500 kHz, 1 MHz, 4 MHz, and 8 MHz are found in the datasheets for most other PIC MCUs (and other MCUs), why not for the 16F1xxxx families? All their datasheets are silent on this. What I am doing---and perhaps should have been clearer about it---is a high-level, datasheet-based initial assessment. I like the various bells and whistles the 16F1xxxx families have but need to know more about power consumption below 16 MHz. So, if someone knows the power consumption of any 16F1xxxx or 16LF1xxxx at 1 MHz (or 500 kHz) using the HFINTOSC, I would be most grateful.... |
我不知道,也许这是一个疯狂的想法,但你有没有考虑直接问微芯片?
以上来自于百度翻译 以下为原文 I don't know and maybe this is a wild idea but have you considered asking Microchip directly? |
只有小组成员才能发言,加入小组>>
4779 浏览 9 评论
1815 浏览 8 评论
1733 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2941 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2043 浏览 5 评论
419浏览 1评论
1101浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
344浏览 0评论
253浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1751浏览 0评论
GMT+8, 2024-3-29 07:36 , Processed in 0.977966 second(s), Total 47, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
