扫一扫,分享给好友
您好,我在vivado 2014.3设计套件安装时遇到了问题。
我尝试了Windows 64的Web安装和完整的产品安装,在我下载它们并单击安装文件后没有任何反应。 我正在使用Windows 7 64位家庭版。 我想知道发生了什么,因为我能够安装Vivado 2014.4没有问题。 以上来自于谷歌翻译 以下为原文 Hello, I had a problem with vivado 2014.3 design suite installation. I tried the web install for windows 64 and the full product installation and after I downloaded them and click on the setup file nothing happens. I am using windows 7 64 bit home edition. I want to figure what happened since I was able to install Vivado 2014.4 with no problems. |
8个回答
我格式化了我的计算机,并且能够使用Windows 7 Home Edition Service Pack 1安装版本2014.3.1
感谢回复 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 I formatted my computer and I was able to install version 2014.3.1 with Windows 7 Home Edition Service Pack 1 Thanks for replying View solution in original post |
嗨,你下载了哪一个?
是vivado 2014.3更新1还是vivado 2014.3完全安装?您需要下载并安装vivado 2014.3完整安装.Xilinx工具不支持Fyi..home版本。 谢谢,迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Which one did you download? Is it vivado 2014.3 update 1 or vivado 2014.3 full installation? You need to download and install vivado 2014.3 full installation. Fyi..home edition is not supported with xilinx tools. Thanks, Deepika.Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
你好@joseb10
这是一个回答同一问题的答案记录:http://www.xilinx.com/support/answers/60410.html 此处记录了此类问题的另一个原因:http://www.xilinx.com/support/answers/61981.html 此外,当您拥有最新版本的工具,即Vivado 2014.4时,很想知道安装Vivado 2014.3.1的原因 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @joseb10 Here is an answer record that talks about the same issue: http://www.xilinx.com/support/answers/60410.html One more reason for this type of issue is documented here: http://www.xilinx.com/support/answers/61981.html Also, curious to know the reason for installing Vivado 2014.3.1 when you have the latest version of tools i.e., Vivado 2014.4 Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
你好。
感谢回复。 原因是我正在上课,教授要求提供那个版本的Vivado。 当我无法安装时,我安装了2014.4。 以上来自于谷歌翻译 以下为原文 Hello. Thanks for replying. The reason is that I am taking a class and the professor asked for that version of Vivado. When I couldnt install it, I installed 2014.4. |
嗨@ joseb10
你下载了哪些安装文件? 它是第一个(Vivado 2014.3更新1)还是第三个(Vivado设计套件2014.3.1)以黄色突出显示? 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi @joseb10 Which installation files did you download? Is it the first one (Vivado 2014.3 update 1) or third one (Vivado design suite 2014.3.1) highlighted in yellow below? Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
Xilinx_Vivado_SDK_Win_2014.3.1_1031_1
完整的产品安装。 以上来自于谷歌翻译 以下为原文 Xilinx_Vivado_SDK_Win_2014.3.1_1031_1 full product installation. |
你好@joseb10
你检查了上一篇文章中提供的答案记录了吗? 如果在安装时仍有问题,请共享install.log文件。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @joseb10 Did you check the answer record provided in previous post? If you still have issues in installing, share the install.log file. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
感谢回复 以上来自于谷歌翻译 以下为原文 I formatted my computer and I was able to install version 2014.3.1 with Windows 7 Home Edition Service Pack 1 Thanks for replying |
只有小组成员才能发言,加入小组>>
2163 浏览 7 评论
2605 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2078 浏览 9 评论
3149 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2193 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
423浏览 1评论
1523浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2177浏览 0评论
508浏览 0评论
1638浏览 0评论
GMT+8, 2024-4-24 06:02 , Processed in 0.981458 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
