我在IC-CAP 2013的文档中读到,可以将从非IC-CAP环境测量的数据导入到IC-CAP中,但是,我真的不能直截了当地说明这是如何完成的(应该提到我
我是IC-CAP的新手。 我有一个GaN HEMT晶体管的DC-IV,多偏置S参数和CW RF(NVNA数据)测量我想做一个模型; 至于现在,我使用ADS中的测量数据制作了自己的模型。 我对准确性并不完全满意,并希望看看我是否可以使用IC-CAP中的一个提取包做得更好。 由于我已经拥有测量数据,我认为最有效的时间用途是重复使用这些数据,我今天也通过DAC工具在ADS中使用这些数据。 但是如何将这些数据整合到IC-CAP中呢? 据我了解,ADS无法将数据导出为* .mdm格式; 是否有可能以某种方式从ADS生成的数据集文件中读取数据? 或者可以用于此目的的任何其他脚本? 问候,d。 以上来自于谷歌翻译 以下为原文 I read in the documentation of IC-CAP 2013 that it's possible to import data measured from a non-IC-CAP environment into IC-CAP, however, I can't really say it's intuitive how this is done (should be mentioned that I'm new to IC-CAP). I have DC-IV, multi-bias S-parameter, and CW RF (NVNA data) measurements of a GaN HEMT transistor I'd like to make a model of; as for now I've made my own model using the measured data in ADS. I'm not fully satisfied with the accuracy, and would like to see if I can do any better using one of the extraction packages in IC-CAP. Since I already have the measurement data, I think the most effective use of time is to re-use this data, which I per today also use in ADS via the DAC-tool. But how can I incorporate this data into IC-CAP? As far as I understand, ADS can't export data to the *.mdm format; is it possible to somehow read data from the data set files that ADS generates? Or any other script one can use for this purpose? Regards, d. |
2个回答
你好ð。
这个问题最好直接发送到电子邮件:[eesof_support@agilent.com],这样我们就可以完全讨论你的文件和情况。 在不知道完整的文件/数据细节/背景的情况下,我建议您考虑以下方法:1。使用ADS数据文件工具(关闭原理图),将您的数据导出为* .s2p或citifile或mdif格式2。 在ICCAP中,请参阅以下示例:示例> demo_features> 5_PEL_PROGRAMING> 1_DATA_IMPORT_EXPORT> 2_READ_WRITE_DATAFILES,在那里,请参阅各种文件夹和示例文件,以便从s2p,mdif等格式将数据导入ICCAP。 希望有所帮助。 请随时通过电子邮件与我们联系:[eesof_support@agilent.com],我们可以进一步详细讨论。 最好的问候Else 以上来自于谷歌翻译 以下为原文 Hello d. This question would be best directed to Email: [eesof_support@agilent.com], so we can discuss your files and situation fully. Without knowing the full file/data details/background, I would suggest you could consider the following approach: 1. use the ADS Data File Tool (off schematic), to export the your data to *.s2p or citifile or mdif format 2. in ICCAP, refer to examples found under: Examples > demo_features > 5_PEL_PROGRAMING > 1_DATA_IMPORT_EXPORT > 2_READ_WRITE_DATAFILES and under there, see the various folders and example files for importing data to ICCAP from s2p, mdif, etc. formats. Hope that helps. Please feel free to contact us at Email: [eesof_support@agilent.com] and we can discuss in further detail. Best regards Else |
victorlekwk 发表于 2018-12-10 16:51 感谢Else的快速回复。 我以某种方式跳过在PEL_PROGRAMMING目录中查找相关示例。 但邮件发送了! 问候,d。 以上来自于谷歌翻译 以下为原文 Thanks for the quick reply Else. I somehow skipped looking in the PEL_PROGRAMMING directory for relevant examples. But mail sent! Regards, d. |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 14:46 , Processed in 1.275549 second(s), Total 76, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
