hi:
大家好,遇到一个I2C的问题,请大家帮分析一下,不胜感激! 系统使用I2C接2片 MPC23017实现GPIO的扩展,使用STM32F072RB 的I2C 2,引脚GPIO都配置了AF ,且I2C初始化也是参考了ST的例子。 发送数据时i2c_expand_gpio_writeBuffer函数里,while(I2C_GetFlagStatus(GPIO_EXT_I2C, I2C_ISR_TXIS) == RESET) 直到超时一直得不到TXIS置位,请大家帮分析下。 uint8_t i2c_expand_gpio_writeBuffer(uint8_t i2c_chip_addr,uint8_t* pBuffer, uint16_t WriteAddr, uint16_t* NumByteToWrite) { uint32_t DataNum = 0; uint32_t i2ctimeout = 0; /* Configure slave address, nbytes, reload and generate start */ I2C_TransferHandling(GPIO_EXT_I2C, i2c_chip_addr, 1, I2C_Reload_Mode, I2C_Generate_Start_Write); /* Wait until TXIS flag is set */ i2cTimeout = GPIO_EXT_I2C_LONG_TIMEOUT; while(I2C_GetFlagStatus(GPIO_EXT_I2C, I2C_ISR_TXIS) == RESET) { if((i2cTimeout--) == 0) return I2C_ERROR_TIMEOUT; } /* Send address */ I2C_SendData(GPIO_EXT_I2C, (uint8_t)WriteAddr); /* Wait until TCR flag is set */ i2cTimeout = GPIO_EXT_I2C_LONG_TIMEOUT; while(I2C_GetFlagStatus(GPIO_EXT_I2C, I2C_ISR_TCR) == RESET) { if((i2cTimeout--) == 0) return I2C_ERROR_TIMEOUT; } /* Update CR2 : set Slave Address , set write request, generate Start and set end mode */ I2C_TransferHandling(GPIO_EXT_I2C, i2c_chip_addr, (uint8_t)(*NumByteToWrite), I2C_AutoEnd_Mode, I2C_No_StartStop); while (DataNum != (*NumByteToWrite)) { /* Wait until TXIS flag is set */ i2cTimeout = GPIO_EXT_I2C_LONG_TIMEOUT; while(I2C_GetFlagStatus(GPIO_EXT_I2C, I2C_ISR_TXIS) == RESET) { if((i2cTimeout--) == 0) return I2C_ERROR_TIMEOUT; } /* Write data to TXDR */ I2C_SendData(GPIO_EXT_I2C, (uint8_t)(pBuffer[DataNum])); /* Update number of transmitted data */ DataNum++; } /* Wait until STOPF flag is set */ i2cTimeout = GPIO_EXT_I2C_LONG_TIMEOUT; while(I2C_GetFlagStatus(GPIO_EXT_I2C, I2C_ISR_STOPF) == RESET) { if((i2cTimeout--) == 0) return I2C_ERROR_TIMEOUT; } /* Clear STOPF flag */ I2C_ClearFlag(GPIO_EXT_I2C, I2C_ICR_STOPCF); i2c_expand_gpio_waitStandbyState(i2c_chip_addr); /* If all operations OK, return sEE_OK (0) */ return OK; } |
5个回答
void i2c_expand_gpio_Init(void)
{ I2C_InitTypeDef I2C_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; /* Configure the I2C clock source. The clock is derived from the HSI */ RCC_I2CCLKConfig(RCC_I2C1CLK_HSI); /* GPIO_EXT_I2C_SCL_GPIO_CLK and GPIO_EXT_I2C_SDA_GPIO_CLK Periph clock enable */ RCC_AHBPeriphClockCmd(GPIO_EXT_I2C_SCL_GPIO_CLK | GPIO_EXT_I2C_SDA_GPIO_CLK, ENABLE); /* GPIO_EXT_I2C Periph clock enable */ RCC_APB1PeriphClockCmd(GPIO_EXT_I2C_CLK, ENABLE); /* Connect PXx to I2C_SCL*/ GPIO_PinAFConfig(GPIO_EXT_I2C_SCL_GPIO_PORT, GPIO_EXT_I2C_SCL_SOURCE, GPIO_EXT_I2C_SCL_AF); /* Connect PXx to I2C_SDA*/ GPIO_PinAFConfig(GPIO_EXT_I2C_SDA_GPIO_PORT, GPIO_EXT_I2C_SDA_SOURCE, GPIO_EXT_I2C_SDA_AF); /* GPIO configuration */ /* Configure GPIO_EXT_I2C pins: SCL */ GPIO_InitStructure.GPIO_Pin = GPIO_EXT_I2C_SCL_PIN; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_OD; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIO_EXT_I2C_SCL_GPIO_PORT, &GPIO_InitStructure); /* Configure GPIO_EXT_I2C pins: SDA */ GPIO_InitStructure.GPIO_Pin = GPIO_EXT_I2C_SDA_PIN; GPIO_Init(GPIO_EXT_I2C_SDA_GPIO_PORT, &GPIO_InitStructure); /* I2C configuration */ /* GPIO_EXT_I2C configuration */ I2C_InitStructure.I2C_Mode = I2C_Mode_I2C; I2C_InitStructure.I2C_AnalogFilter = I2C_AnalogFilter_Enable; I2C_InitStructure.I2C_DigitalFilter = 0x00; I2C_InitStructure.I2C_OwnAddress1 = 0x00; I2C_InitStructure.I2C_Ack = I2C_Ack_Enable; I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit; I2C_InitStructure.I2C_Timing = GPIO_EXT_I2C_TIMING; /* Apply GPIO_EXT_I2C configuration after enabling it */ I2C_Init(GPIO_EXT_I2C, &I2C_InitStructure); /* GPIO_EXT_I2C Peripheral Enable */ I2C_Cmd(GPIO_EXT_I2C, ENABLE); /*Init I2C Slave MPC23017, all port is output*/ mpc23017Init(); } 这是我的I2C初始化,端口 和 I2C 2的选择宏定义,已经检查好多遍了,不会有什么问题。 |
GPIO_EXT_I2C_TIMING 我使用了ST的工具excel 和 Cube 按照APB1的外设时钟值生成过,但是没什么效果。
你 I2C 使用的是 HSI 时钟,你却用 APB1 时钟来生成 TIMING ?
另外你时钟配置的是多少? 超过 400K 需要打开 SYSCFG 的 FastMode 控制位。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
242 浏览 1 评论
664 浏览 0 评论
MCU友好过渡MPU,米尔基于STM32MP135开发板裸机开发应用笔记
600 浏览 0 评论
自定义系统时钟频率后,用库函数和微带两种方式点亮LED灯,为什么灯的闪烁频率不一致?
1389 浏览 2 评论
1612 浏览 2 评论
GMT+8, 2024-4-18 18:57 , Processed in 0.732636 second(s), Total 71, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
