扫一扫,分享给好友
我主要使用Linux。
大多。 但有时我必须使用Windows。 在安装2014.1之前,我想我会清理我的笔记本电脑的Xilinx cruft。 添加/删除程序告诉我,我安装了多个版本的DocNav。 我卸载了第一个,但第二个不会卸载 - 说它的目录已经消失了。 这在“添加/删除程序”中留下了孤立的DocNav条目。 虽然Xilinx很好地将Vivado安装分为Vivado / 2013.4,Vivado / 2014.1等,但DocNav始终安装在同一目录中。 我认为这是这个问题的根源。 为什么不分离DocNav安装呢? 以上来自于谷歌翻译 以下为原文 I mostly use Linux. Mostly. But sometimes I have to use Windows. Before installing 2014.1, I thought I would clean up my laptop's Xilinx cruft. Add/Remove Programs told me I had multiple versions of DocNav installed. I uninstalled the first, but the second would not uninstall -- saying its directory was already gone. This left an orphaned DocNav entry in Add/Remove Programs. While Xilinx nicely segregates Vivado installs into Vivado/2013.4, Vivado/2014.1, etc..., DocNav is always installed in the same directory. I think that is the root of this problem. Why not segregate DocNav installs too? |
2个回答
嗨,
DocNav是一个单独的独立安装。 您可以从以下链接下载:http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2013-4.html 您还可以选择将其安装在其他位置。 见下面的快照: 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, DocNav is a separate standalone install. You can download it from the link: http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2013-4.html You also have a option to install it in a different location. See below snapshot: Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,
当您尝试卸载时,我认为您应该尝试从该位置卸载,如下所示。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, When you try to uninstall i think you should try uninstalling from the location as shown below. Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-20 05:33 , Processed in 0.891427 second(s), Total 45, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
