发 帖
【四旋翼飞行器】76小时吃透四轴算法!史上最强软硬结合实战项目,👉戳此立抢👈
[经验] stm32f4串口3提示NE错误的解决办法
2018-12-6 16:17:06  1090 STM32
分享
2
今天在调试时,遇到个棘手的问题,分享解决方法给大家,
我使用HAL库,一个让人抓狂的烂库啊,想骂娘,一直骂都不解气的烂库。
串口+DMA,官网407的DMA例程移植过来的,不需要过多说明,上代码即可
void HAL_UART_MspInit(UART_HandleTypeDef* huart)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(huart->Instance==USART3)
  /* USER CODE BEGIN USART3_MspInit 0 */
  /* USER CODE END USART3_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_USART3_CLK_ENABLE();
    /**USART3 GPIO Configuration
    PB10     ------> USART3_TX
    PB11     ------> USART3_RX
    GPIO_InitStruct.Pin = GPIO_PIN_10|GPIO_PIN_11;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF7_USART3;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
    /*##-3- Configure the DMA streams ##########################################*/
  /* Configure the DMA handler for Transmission process */
  hdma_usart3_tx.Instance                 = USARTx_TX_DMA_STREAM;
  hdma_usart3_tx.Init.Channel             = USARTx_TX_DMA_CHANNEL;
  hdma_usart3_tx.Init.Direction           = DMA_MEMORY_TO_PERIPH;
  hdma_usart3_tx.Init.PeriphInc           = DMA_PINC_DISABLE;
  hdma_usart3_tx.Init.MemInc              = DMA_MINC_ENABLE;
  hdma_usart3_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
  hdma_usart3_tx.Init.MemDataAlignment    = DMA_MDATAALIGN_BYTE;
  hdma_usart3_tx.Init.Mode                = DMA_NORMAL;
  hdma_usart3_tx.Init.Priority            = DMA_PRIORITY_LOW;
  hdma_usart3_tx.Init.FIFOMode            = DMA_FIFOMODE_DISABLE;
  hdma_usart3_tx.Init.FIFOThreshold       = DMA_FIFO_THRESHOLD_FULL;
  hdma_usart3_tx.Init.MemBurst            = DMA_MBURST_INC4;
  hdma_usart3_tx.Init.PeriphBurst         = DMA_PBURST_INC4;
  HAL_DMA_Init(&hdma_usart3_tx);
  /* Associate the initialized DMA handle to the UART handle */
  __HAL_LINKDMA(huart, hdmatx, hdma_usart3_tx);
  /* Associate the initialized DMA handle to the the UART handle */
  __HAL_LINKDMA(huart, hdmarx, hdma_usart3_rx);
  /*##-4- Configure the NVIC for DMA #########################################*/
  /* NVIC configuration for DMA transfer complete interrupt (USARTx_TX) */
  HAL_NVIC_SetPriority(DMA1_Stream3_IRQn, 0, 1);
  HAL_NVIC_EnableIRQ(DMA1_Stream3_IRQn);
  /* USER CODE BEGIN USART3_MspInit 1 */
    HAL_NVIC_SetPriority(USART3_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(USART3_IRQn);
  /* USER CODE END USART3_MspInit 1 */
/* USART3 init function */
static void MX_USART3_UART_Init(void)
  huart3.Instance = USART3;
  huart3.Init.BaudRate = 115200*2;
  huart3.Init.WordLength = UART_WORDLENGTH_8B;
  huart3.Init.StopBits = UART_STOPBITS_1;
  huart3.Init.Parity = UART_PARITY_NONE;
  huart3.Init.Mode = UART_MODE_TX_RX;
  huart3.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart3.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart3) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
以上是初始化代码
使用的DMA发送,中断接收,
串口是和4G模块通讯,具体哪个厂家的就不说了,只能说很low。
在配置模块时,出现了如图所示,
再次上电没有错误了,就接上f4的串口,开始调试,顿时来个下马威啊,一直在反复进入串口中断,单步跟踪,先是 Framing error,后来一直是 Noise detected flag,Overrun error这2个错误,相当于进入死循环了,急得我直骂娘啊,百度一下,基本没有收获,能知道是硬件问题,就上了示波器,果然是波形出问题了,f4的串口是使用串口助手调试了N遍的,肯定没问题,只能把4G模块的波特率降低一个档次,因为之前使用115200(出厂默认值)一直没出问题,果然是没问题,又再次把波特率升到230400,直到在调试软件上没有任何错误,反复测试都OK,才放心大胆的使用,果然,一切正常了,权当发个水贴,给大家分享一下经验了。
补充一下,之前是忙里偷闲写的,没有总结的太充分。
具体原因是4G模块在初始化过程中会一直打印,使用串口助手发现全是FF或F7,也就是乱码,导致串口一直接收错误信号,但是能退出,但是模块的初始化太久近3分钟,导致一个死机的假象,模块还没有完全初始化完毕,我的板卡已经初始化完成,开始透传数据,因为波特率230400比较快了,模块处理不过来了,就一直报错,之前其实没有完全解决,后来我调试过程中有出现了,就静下心来仔细研究代码,发现有处代码有问题,就是清理TC标志,去除清TC标志部分代码,把mcu控制4G模块的reset功能去除,让模块先启动,板卡加个比较大的延时后再进行外设初始化就彻底解决了。
zrl12123456 2018-12-6 16:44:16
之前出错的原因是什么呢
回复
举报
MicroLCD 2018-12-6 18:07:23
不错的经验分享!
回复
举报
王栋春 2018-12-6 21:37:44
错在何处
1回复
举报
lee_st 2018-12-7 00:02:09
错误原因,刚补充了
回复
举报
lee_st 2018-12-7 00:07:57
使用DMA过程中一定不能清理TC的标志,我是自己挖坑,自己跳
回复
举报
lee_st 2018-12-7 00:15:02
在使用dma过程中,不能清理TC标志,那是自己挖坑
回复
举报
高级模式
您需要登录后才可以回帖 登录 | 注册
发经验
课程
    关闭
    站长推荐 上一条 /8 下一条
    快速回复 返回顶部 返回列表
